Go Back JeepForum.com > Reviews > Engine > Carburetors > Edelbrock Performer 600 cfm
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Edelbrock Performer 600 cfm Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Carburetors Next Product
Rating:
Product Information
MSRP: $400.00
Average Price: $238.63
Manufacturer: Edelbrock
Recommended?
Yes: 17 / No: 2
Edelbrock's Performer carburetors feature two-piece, all-aluminum construction for cooler operating temperatures and less warping. There are no gaskets below the fuel bowl level for fewer leaks, and no plastic parts or power valves to blow out. The carbs use easily changed metering rods for precise tuning, and the primary venturi booster is a bottom-feed design for smoother acceleration and better drivability. Also included with every Edelbrock carburetor you will receive a owner's manual. These manuals consist of two sections; Section 1, Theory of Operation and tuning procedures which will help you be prepared to develop your own individualized calibration. Section 2, Tuning procedures will take you through a step-by-step procedure that will enable you to achieve a desirable calibration. For added ease of tuning, a Calibration reference chart for your model of carburetor will be included.
arkiemurph
arkiemurph's Reviews
03-17-2011, 08:03 PM
Price: $300.00
Pros: Easy to work on.
Cons: Not great on inclines
Recommended? Yes
Comments: Thought I covered it. Good carbs, gas mileage ok, easy to work on. Sittin on an edelbrock intake.
benderman
benderman's Reviews
12-12-2010, 04:59 PM
Price: $100.00
Pros: AFB
Cons: AFB
Recommended? Yes
Comments: good 4bbl design, Not a fan of the AFB CHoke design, Which it has a stepper plate instead of cam design
jeeptree2112
jeeptree2112's Reviews
11-25-2010, 11:39 AM
Price: $300.00
Pros: 4brl
Cons: ???
Recommended? Yes
Comments: Easy to tune
easy to remove and rebuild
great customer service at edelbrock...
jeeptree2112
11-25-2010, 11:32 AM
Price: $317.00
Pros: 4brl
Cons: ??
Recommended? Yes
Comments: Big carb but does the job
Easy to work on
new rods to richen it up
arkiemurph
11-06-2010, 07:56 PM
Price: $300.00
Cons: flooooods
Recommended? Yes
Comments: Easy to work on, can be modified to help keep it from flooding on inclines.
otterred
otterred's Reviews
07-26-2010, 08:36 PM
Price: $100.00
Pros: In expensive
Cons: Carter Manual Choke design
Recommended? Yes
Comments: I was hoping by getting a manual choke I would have the advantage of a idle stepper(?) but the design doesn't facilitate use of idle stepper without choke plate engaging.
BobbyBlakFinger
BobbyBlakFinger's Reviews
06-08-2010, 11:47 AM
Price: $1.00
Pros: Extra Horsepower
Cons: You gotta feed the horses
Recommended? Yes
Comments: Not sure on price it came with the Jeep. It runs great if you keep it clean and maintained. I've had to clean the float bowls twice. Not really that abnormal.
darren9975
darren9975's Reviews
03-20-2010, 05:31 AM
Price: $275.00
Pros: Easy to adjust, and works out of the box
Cons: It sucks on the trail, any incline and it cuts out.
Recommended? No
Comments: This carb is great for street, I would not recommend it for a trail rig. On inclines it cuts out and it seem to get shaken up easy.
dadroofs
dadroofs's Reviews
11-29-2009, 11:06 AM
Price: $150.00
Pros: works fine
Cons: hills and angles
Recommended? Yes
Comments: Going to make the switch to EFI someday so I don't have to worry about climbing hills
CaliDaze
CaliDaze's Reviews
11-01-2009, 06:12 PM
Price: $250.00
Pros: Factory tune started right up, easy tunning, Leaves room to upgrade a stock 304.
Cons: Stalls out on Steep inclines, Needs edelbrocks off road needle seat.
Recommended? Yes
Comments: Through it on and it started right up. Tune the air/fuel and little to get better vacuum and that was it. It really opened up my 304. Add the edelbrock intake and some headers and its a pretty good package. I have really bad gas mileage though. Still trying to figure that out. But that was a problem before the new carb.
EvulutioN
EvulutioN's Reviews
07-31-2009, 11:11 PM
Price: $125.00
Pros: Easy Tuning - Reliable
Cons: Off-road Sputter, Just time to fix this problem...
Recommended? Yes
Comments: Purchased the unit used with the Manifold. It worked flawlessly. PO installed spring-loaded needles which work very well. Tuning was only a little tedious but overall the product has been rock-solid, even though it was used.
smoke52458
smoke52458's Reviews
05-11-2009, 12:07 PM
Price: $350.00
Pros: Great horse-power
Cons: Loves gasoline
Recommended? Yes
Comments: I installed the Edelbrock performer on my 1975 CJ5 7-years ago and have not had any problems with the performance. This carburetor pack alot of power. I installed a 2" throttle body last year which seems to work well with the system.
chet44
Senior Member......NOT!!
chet44's Reviews
01-18-2009, 09:33 PM
Cons: minimal adjustments without tearing it apart and replacing parts
Recommended? Yes
Comments: I dropped a ATK 304 rebuilt long block in the Jeep, did a rebuild on the carb (came with the Jeep), added a electric choke. Filled the float bowls, and she started right up. I was only 2 degrees ATDC on the timing when I re-installed the distributor. Not bad for a first timer, although my dad is a retired mechanic and he's been working with me on the Jeep.
seventythree
seventythree's Reviews
01-13-2009, 09:34 PM
Price: $400.00
Recommended? Yes
Comments: works great on the street, not so much on steep ascents or descents, it's purdy
cbushrun
cbushrun's Reviews
10-16-2008, 03:53 PM
Pros: easy to work on and understand, drives great
Cons: terrible off road, will load up on incline/declines
Recommended? No
Comments: Its a great carburator for on road use, although its not great for mileage. Easy to work on but sucks for off road use.
JFlanny11
JFlanny11's Reviews
08-08-2008, 04:52 PM
Price: $375.00
Recommended? Yes
Comments: Unit works well....Solved a lot of Problems, Good upgrade from stock carb! Performer Intake and Cam make for a world of diffrence as a package!
iownaniroc
iownaniroc's Reviews
07-03-2008, 12:29 AM
Recommended? Yes
Comments: Came with my Jeep so I don't really know if it is any good or not. I get extremely bad gas mileage but I know it needs to be re-jetted too. Works fine for me!
Erik719
Erik719's Reviews
05-20-2008, 08:23 PM
Price: $150.00
Recommended? Yes
Comments: Great. Lots of power. Had a hard time adjusting it though.------------------------------------
puggles
puggles's Reviews
04-13-2008, 03:50 PM
Price: $325.00
Recommended? Yes
Comments: Really kicks after the RPM'S go up
ThreadForumRepliesLast Post
Edelbrock Shorty Headers with TiTech coating Headers 6 11-16-2009 11:47 AM
Edelbrock Shorty Headers with TiTech coating Exhaust 1 11-13-2008 06:38 PM
Glock Forum
