Go Back JeepForum.com > Reviews > Engine > Internal Parts > Royal Purple 5W30 Full Synthetic Motor Oil
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Royal Purple 5W30 Full Synthetic Motor Oil Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Internal Parts Next Product
Rating:
Product Information
MSRP: $13.97
Average Price: $15.42
Manufacturer: Royal Purple
Recommended?
Yes: 9 / No: 0
Specially formulated SAE grades suitable for engines from trucking to general transportation to motorcycles. Excellent for today's injected motors. Motors stay cleaner and cooler, resulting in better gas mileage, superior engine protection, and longer oil life. API certified.
Kitchen
When in doubt whip it out
Kitchen's Reviews
12-25-2010, 08:03 PM
Price: $65.00
Pros: Good protection
Cons: $$$$
Recommended? Yes
Comments: Great stuff
FaT00CaJuN
FaT00CaJuN's Reviews
09-11-2009, 10:32 PM
Price: $8.00
Pros: helps with engine idle and restores some compression for power boost
Cons: expensive
Recommended? Yes
Comments: (06 TJ) Haven't noticed much. i use 10w30 since I'm in the south. i have noticed a little power gain and alot better idle. nothing on the fuel millage though.
CJ7Rubicon
CJ7Rubicon's Reviews
11-06-2008, 06:10 PM
Price: $6.00
Recommended? Yes
Comments: actually 10w30 is what I run.Been running it since a total rebuild from startup and seems fine.
wrangler_usmc
wrangler_usmc's Reviews
09-25-2008, 11:34 AM
Cons: Finding 6 quarts in one location!
Recommended? Yes
Comments: I had been running Mobil 1 with pretty good success. Decided to swap out to RP because of all the good things I kept hearing.
I had been running Mobil 1 in the engine, diff's, trans (till I read Stu's comments at www.stu-offroad.com about the GL-5 misprint for the AX-15). When I switched, I went to RP in EVERYTHING. Specifically with the engine oil I've noticed a little more valve tap. MPG is comparable to what I had before...not worse. This might work better for someone else. I'll probably go back to running Mobil 1 or try Redline.
cowboy63b
cowboy63b's Reviews
09-09-2008, 03:29 AM
Price: $13.97
Recommended? Yes
Comments: i really didn't notice anything in the seat-o-pants dyno, but put it on a chassis dyno, with royal purple in everything, and i got a 7 hp gain across the board.
2drcherokee
2drcherokee's Reviews
08-07-2008, 06:22 PM
Price: $7.00
Recommended? Yes
Comments: a great product. noticeable increase in power and in mpgs. also helps to fix most minor seal problems
ajmorell
ajmorell's Reviews
05-20-2008, 04:11 PM
Price: $7.00
Recommended? Yes
Comments: I changed over to RP from Mobil one about a year ago after I heard Mobil 1 was no longer a true "full-synthetic" (not sure if that is true or not). I run about 8-10k change intervals and couldn't be happier with RP.
fscrig75
fscrig75's Reviews
05-04-2008, 07:58 AM
Price: $1.00
Recommended? Yes
Comments: The XJ is old. So I splurge a bit on the oil, its the engine's blood. Just need to shop around for some deals to find it a bit cheaper.
Panici
(O|||||||O)
Panici's Reviews
04-21-2008, 09:56 PM
Pros: Purple when first put in. Full Synthetic.
Cons: Expensive. I cannot get it locally.
Recommended? Yes
Comments: Seems to be a good quality oil. I've heard good reviews.
We'll see how it looks when I change it. It also seemed to quiet down the 4.0 just a little.
ThreadForumRepliesLast Post
Daystar 1" riser motor mount Motor Mounts 4 07-30-2010 01:51 PM
Mobil Mobil-1 Synthetic Oils Internal Parts 20 08-14-2009 10:23 PM
Novak SBC Jeep Motor Mounts Motor Mounts 3 02-08-2009 10:07 PM
Purple hornie CJ side pipes Exhaust 3 05-11-2008 01:02 PM
K&N Full Intake Induction 0 04-12-2008 02:59 PM
Glock Forum
