Volant 4.7 Air intake system Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Induction Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $277.08
Manufacturer: Volant
Recommended?
Yes: 15 / No: 0
-Intake for the 4.7L Jeep Grand Cherokees
-improves gas milages
-improves power
-nice rumble
-easy install
None
Camster7
Camster7's Reviews
06-11-2014, 12:56 PM
Price: $300.00
Pros: Great sound, adds power
Cons: adds a small drone
Recommended? Yes
Comments: Great look to add color to the engine bay whilst adding power
TimeWellWasted
TimeWellWasted's Reviews
03-30-2014, 12:17 PM
Price: $1.00
Pros: not sure
Cons: not sure
Recommended? Yes
Comments: Was already installed when bought jeep
Coyote56
Coyote56's Reviews
08-06-2013, 06:49 PM
Price: $700.00
Pros: With the cap on the CAI the snorkel works as a insurance policy against hydrolock. Can remove cap on CAI when not off roading and the snorkel acts like a ram air in addition to the bigger intake/filter box in the engine bay
Cons: have to remove bolts on snorkel mount to remove passenger door. Only takes about 30 seconds, so no biggy.
Recommended? Yes
Comments: I got the Volant CAI/Snorkel system for my Jeep TJ second hand. I love it, no complaints.
Jarod5
Jarod5's Reviews
07-19-2012, 05:18 PM
Price: $150.00
Pros: lots of air flow
Cons: none
Recommended? Yes
Comments: very good looking product. Lots of air flow thru it. Needs aftermarket exhaust too.
JK4x4Wrangler
JK4x4Wrangler's Reviews
03-12-2012, 06:08 PM
Price: $250.00
Pros: Super easy to install, give a little extra power in acceleration.
Cons: Cleaning the filter. Voltant made their filter reusable so you don't have to replace it, but when it comes time to clean it (every 6 months or so for me) your out of commission for about half the day.
Recommended? Yes
Comments: Great product. Super easy to install. Gives a noticeable power boost with a mean sound around 3k RPM. Easy to clean filter but it takes you out of commission for a few hours when you have to do it, overall great product would def recommend.
rubicon1983
rubicon1983's Reviews
02-17-2012, 11:14 PM
Price: $300.00
Pros: wicked
Cons: no cons
Recommended? Yes
Comments: awesome snorkal luv sound
i recommend to anyone
pbshooter
pbshooter's Reviews
03-27-2010, 12:45 AM
Price: $285.00
Pros: Increase in horsepower.
Cons: Expensive
Recommended? Yes
Comments: There is a noticeable increase in horsepower during acceleration. It's nothing too significant, but better than stock none-the-less. This product works best with a throttle body spacer.
tfsimpkins
tfsimpkins's Reviews
11-12-2009, 12:14 PM
Price: $300.00
Pros: Looks good. Sounds good. Increases horsepower. Has an additional port for the snorkel attachment and/or acts as a water drain. Easy to install. Easy to clean.
Cons: Priced too high. Hard to find find blue filter oil.
Recommended? Yes
Comments: Volant Air Duct: Factory air inlet ducts use sound baffles and awkward bends which restrict flow. The Cross-Link polyethylene air ducts are sculptured to give the engine less restrictive breathing. Incorporating larger diameters and unique bends, that can't be duplicated with metal ducts, allow for maximum airflow velocity and throttle response.
Volant Pro 5 Filter: Many of Volant intakes come with this cleanable and reusable high grade cotton filter media with five-layers of protection. It reduces air restriction and increases engine output by using precision pleat geometry, that optimizes airflow throughout the intake system
FaT00CaJuN
FaT00CaJuN's Reviews
09-06-2009, 01:28 AM
Price: $300.00
Pros: Great power and throttle response and fuel millage
Cons: cleaning the filter. read review for more about this problem
Recommended? Yes
Comments: (06 TJ) OK here we go. installing is easy. make sure you push the tube all the way up to the box or the hotline on your ac will melt it. it works great, i have excellent throttle response power and gas millage. i haven't installed the snorkel yet but if you're worried about water getting into it due to where the opening is located, don't. the snorkel hole on the side acts as a drain for the box. now cleaning the air filter isn't a fun task. break out the tools. you have to pull the support bar that goes over it and unscrew the top of the box then unscrew the filter and pull it out. repeat backwards to reinstall. took awhile for it to come in the mail. good quality. haven't had a issue with it yet besides cleaning it but the way the box is made you don't have to clean it often.
JROD99TJ
JROD99TJ's Reviews
02-14-2009, 11:44 PM
Recommended? Yes
Comments: easy to clean, istalled by prior owner, good fit. -------------------
Richfromla
Richfromla's Reviews
11-25-2008, 10:30 PM
Recommended? Yes
Comments: actually i got the 17013 for TJs
atsoca
atsoca's Reviews
11-15-2008, 10:00 AM
Price: $250.00
Recommended? Yes
Comments: Gives more mid range pickup than low end. GREAT sound. may have increased milage a bit but it is hard to tell cause you like the sound!
starflyer
starflyer's Reviews
09-29-2008, 04:27 AM
Price: $250.00
Recommended? Yes
Comments: This is for the 3.8L, it wasn't listed in the product menu. Volant did an excellent job with performance, looks, and price with this air intake.
blatod
blatod's Reviews
05-03-2008, 09:31 PM
Price: $300.00
Recommended? Yes
Comments: 3.8 cold air intake - very impressed, easy to install. More throaty sound.
99redwj
99redwj's Reviews
10-29-2006, 01:56 AM
Price: $215.98
Pros: niceintake sound,power&gas are up
Cons: no heat-shield
Recommended? Yes
Comments: I bought this product a few weeks ago and i must say that it doesn't disapoint.So far i have improved gas milage and power.The install took all of 15-30 mins and if you but this product you'll love it
Matthew
here's mine
ThreadForumRepliesLast Post
Banks Ram-Air Intake System Induction 44 04-29-2017 10:27 AM
k & N intake Induction 14 07-04-2015 03:50 PM
Airaid QuickFit™ Series Intake System Induction 5 11-08-2014 07:09 PM
Airaid Intake System #310-158 Induction 77 08-12-2014 08:26 PM
Insys - USA Cold Air Intake System Induction 1 01-24-2009 09:56 PM
