Rugged Ridge Polished Aluminum Air Intake Kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Induction Next Product
Rating:
Product Information
MSRP: $199.99
Average Price: $140.87
Manufacturer: Rugged Ridge
Recommended?
Yes: 7 / No: 1
Company Website: http://www.ruggedridgeoffroad.com
Want more horsepower, better throttle response, and improved acceleration? A Rugged Ridge Air Intake System can boost your performance, while helping you keep extra cash in your wallet. Our polished aluminum mandrel bent intake tube replaces the restrictive factory air box to help improve fuel economy and performance. A black powder coated heat shield separates the filter from engine heat, dirt and debris, as cold air is drawn through a high-flow conical air filter. Unlike other reusable air filters, our dry panel design never needs oiling, which keeps your air flow sensor from being damaged by excess oil! The simple bolt on installation gives you power you can feel, adding up to 10HP and 12ft lbs or torque, depending on application. Fits 98-06 with or w/0 AC. Fits 1997 w/o AC.
None
Renodemona
Renodemona's Reviews
10-30-2013, 11:45 PM
Price: $74.99
Pros: Looks sharp, comes with synthetic fiber air cleaner that lasts 15K miles
Cons: Needs a riser/tube to clear the vacuum accessories on some carbs, does not come pre-drilled for a hot air input port. does not have a vent attachment for vented oil cap
Recommended? Yes
Comments: Really great and relatively inexpensive item that replaces the stock and constricting air box on any Jeep V-8. Tough construction and a VERY nice air cleaner make this a better deal than a similar K&N product that is priced at least $50 more. Does need a bit of drilling/fabricating if you want to keep the heated air functional though. May need a spacer depending on which carb your engine has, but they are about $5 on Ebay.
RobSheaTJ
RobSheaTJ's Reviews
10-24-2012, 08:25 PM
Price: $160.00
Pros: Colder air, mean sound, slightly improved performance
Cons: Flimsy, elbow too close to negative battery terminal
Recommended? Yes
Comments: For the price this is a good cold air intake. At full throttle the sound is nice but that sort of defeats the purpose of using it to save gas. It looks nice and the heat shield cools the air a bit.
For criticism, the tube is too close to the battery terminal and it's not too securely attached like the factory box.
If I'd had more money, I would have gotten a better intake. But for the price, this is a decent product.
RobertVL
RobertVL's Reviews
05-11-2012, 05:03 AM
Price: $156.00
Pros: Easy to install, smoother idle, more power, economy improvement and nice note.
Cons: bottom mount on heat sheild easily broken
Recommended? Yes
Comments: Very good product overall and does what it claims. Bottom mount is poorly designed but after replacing it with a rubber exhaust mount costing $5.95 Aust no more problems. Noticeably smoother power delivery with a nice note.
bradmc
bradmc's Reviews
08-10-2011, 03:35 PM
Price: $187.99
Pros: cheap
Cons: tube to air isolator box mount is poorly made
Recommended? No
Comments: The price was right, but I got what I paid for. There is a stud bolt that mounts the polished intake tube to the new air box with a rubber isolation bushing to allow for engine movement and vibration. The angle of the bolt and the way it attaches to the airtube is poor at best. It has come loose several times so far, which allows the tube to bounce around excessively, which in turn, shook the filter element loose from the intake tube.
I didn't want to spend the money for the K&N or AirRaid units, so I went with this one since it was so much cheaper. Wish I had gone with the Rusty's Airtube instead.
Kilcrease
Kilcrease's Reviews
01-19-2011, 01:44 PM
Price: $163.00
Pros: more torque and throttle response
Cons: loose wires and threads in the filter good thing i noticed them.
Recommended? Yes
Comments: Increased torque and throttle response. Looks great under the hood, and I noticed a couple miles per gallon extra while driving 250 miles straight on the interstate. This paired up with an exhaust gives you some extra horsepower. Definitely has better get-up-and-go to pass someone now.
dscabra
dscabra's Reviews
01-16-2011, 01:11 AM
Price: $160.00
Pros: Looks good and seemed to help with throtle response and low-end torque
Cons: Noisy when the Jeep is first started.
Recommended? Yes
Comments: Installed the intake and TBS in about 20 minutes. I was hoping for increased fuel economy and increased power. Got the power, but no change in fuel economy.
RDaniel2405
RDaniel2405's Reviews
12-27-2010, 07:53 PM
Price: $179.99
Pros: Great price compared to other similar intakes, super easy install '' 20-25 min ''
Cons: none yet
Recommended? Yes
Comments: I got this for 179 from quadratec "military discount". Great looking intake and easy to install. Sounds good and noticed a bit more power. My jeep in 6th gear will gain speed when i use to down shift to speed up.
The only thing i did to add to this kit is, installed a water proof air filter cover from outerwears. That was around 25 bucks. Just to have piece of mind wine driving in heavy rain and puddle stomping.
ThreadForumRepliesLast Post
k & N intake Induction 14 07-04-2015 04:50 PM
K&N FIPK Air Intake Kit Induction 5 10-08-2014 04:20 PM
Rugged Ridge Stainless Steel 409 Headers 14 08-27-2013 01:51 PM
K&N Generation II Air Intake Induction 2 09-24-2010 02:24 PM
