Notices
K&N 77 Series Cold Air Intake Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Induction Next Product
Rating:
Product Information
Average Price: $267.60
Manufacturer: K&N
Recommended?
Yes: 10 / No: 0
Built for performance and show utilizing the highest quality components, the K&N 77 Series High-Flow Performance Kit is a free-flowing mandrel-bent aluminum tube induction system designed for Trucks and Sport Utility Vehicles. 77-Series intakes have a polished aluminum finish. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow. This allows your vehicle's engine to inhale a larger amount of air than the OEM air filter assembly. More air means more usable power and acceleration throughout the engine's RPM range. The filters on these kits are washable and reusable. Most of our intake kits are relatively easy to install using tools commonly available (see installation instructions)
None
Jeepcherokee09
Jeepcherokee09's Reviews
11-29-2014, 09:53 AM
Price: $300.00
Pros: Better throttle response and mean sound when the pedal is to the metal!
Cons: Under normal acceleration makes high pitched whistle sound but you get use to it.
Recommended? Yes
Comments: I found this intake for a steal price on craigslist and it was in great condition. The install was easy except for getting the intakes body into position to line up with everything was tricky. The install took about an hour and a half (this includes searching for tools in the garage and drinking beer). After the install the Jeep has a more deeper sound when you give it gas. However don't be alarmed that it is not gonna be a huge difference when you start it up and just casually drive down the road. The throttle response is much better. When you put the pedal to the metal this is when you will notice the difference! She roars!! The only negative thing about it is the annoying high pitched whistle under normal driving but you get use to it to the point that you don't even notice.
GC10LTD
GC10LTD's Reviews
03-10-2014, 04:34 PM
Price: $286.99
Pros: Makes it louder and helps on the MPG's
Cons: Doesn't connect to the throttle body, it uses stock airbox.
Recommended? Yes
Comments: I like the K&N 77 Series. It helped me from 12 mpg in city to mid 15's. It gives the V6 a nice sound, and looks sharp! Only downside is it uses the stock airbox unlike the 57 Series FIPK intake for the WK. For the money it is worht it if you are going for looks. Im going to uninstall and get a Injen intake instead. Its all about what you really want out of it
violators
violators's Reviews
08-19-2013, 11:57 PM
Price: $300.00
Pros: amazing sound
Cons: air pipe runs across engine and heats up lots
Recommended? Yes
Comments: installation was fairly easy, I really wish the intake pipe didn't run across the hot engine, as we all know that heat kills hp.
2012JETLIMITED
2012JETLIMITED's Reviews
07-07-2013, 06:42 PM
Price: $200.00
Pros: Easy install, better performance, mpg.
Cons: none
Recommended? Yes
Comments: Intake was very easy to install, increase in performance. A little increase in mpg is you can stay off the gas! Sounds great when your right foot is a little heavy. Notice a difference while passing at high way speeds.
RebelMS38WK
RebelMS38WK's Reviews
01-10-2013, 02:20 AM
Price: $310.00
Pros: Looks and sounds good
Cons: Makes me waste gas even more cause I like the way it sounds
Recommended? Yes
Comments: Not to hard to install and looks really good. I defiantly notice an increase in Horse-power and quicker throttle response
BigBlue7
BigBlue7's Reviews
02-07-2012, 08:37 AM
Price: $250.00
Pros: Excellent price, and $25 gift card, from StreetSideAuto.com, cheapest out there!!! Excellent results More HP Better MPG Better sounding engine Simple install
Cons: None
Recommended? Yes
Comments: Don't hate on my results. I have increased my fuel economy by an average of 2MPG. My JKU is stock, and before I added, I was getting avg 15 to 16, now 17 to 18. I don't work for K&N!!!! Just trying to help the complainers out there.
weber20
weber20's Reviews
07-04-2011, 11:00 AM
Price: $299.00
Pros: Sounds great, more horsepower, better MPG, easy to install
Cons: none
Recommended? Yes
Comments: me and my buddy installed this kit in just over an hour right in my driveway, it was very simple, the only part we struggled on was removing a few screws holding the stock filter box because they were under the fender and sometimes had the plastic fenders covering them, i would recommend having 2 sets of the sockets, its a great product and in the end i would more than happily refer this product to other WJ owners
Christ45
Christ45's Reviews
10-05-2010, 12:09 PM
Price: $250.00
Pros: Performance. Looks.
Cons: Whistles slightly
Recommended? Yes
Comments: Under the hood it looks amazing! And it does give some much needed engine enhancing. I can actually feel the car react to me stepping on the gas!
Barbarian
Barbarian's Reviews
09-19-2010, 01:30 PM
Price: $180.00
Pros: Very noticeable horsepower. and mpg. Sounds great.
Cons: i heard in sloppy mud they can get a little dirty. havent had a problem yet thou.
Recommended? Yes
Comments: Great Product! noticeable gains. Along with exhaust and a steering stabilizer i can easily get 80+ on the highway. and get about 15-16 mpg on my 4.0L. makes exhaust sound great also. find them on ebay really cheap.
ThreadForumRepliesLast Post
K & N Cold Air Intake 57 Series (FIPK) Induction 82 04-05-2017 02:07 AM
K&N 57 Series FIPK Performance Intake Kit Induction 16 08-11-2015 12:14 PM
Airaid QuickFit™ Series Intake System Induction 5 11-08-2014 07:09 PM
K&N Cold Air Intake 57 Series Induction 5 05-12-2014 07:32 AM
K&N 57 Series FIPK > Performance Intake Kit Induction 4 11-09-2012 07:13 PM
