HomeMade Custom coldair intake Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Induction Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $57.33
Manufacturer: HomeMade
Recommended?
Yes: 60 / No: 5
what i did here seein as i own an older RENIX 4.0L (no one makes **** for these engines so ya gotta do it your self)
any way i took a piece of 3" stainless exhaust pipe in a 12" length cut the needed holes for the hses from the airbox i brazzed on the needed fittings and went out and got the biggest K&N filter they had(6X9K&N w/3" mouth) slapped it all together and tossed that crappy old restrictive airbox and havent had a regret
None
Page 2 of 4 1 2 3 4 > Last
attackcammel
attackcammel's Reviews
12-22-2010, 07:14 PM
Price: $70.00
Pros: Gets the intake up into the cowl to prevent water injestion
Cons: slight whisle when you step on the trotle
Recommended? Yes
Comments: built this with parts from my local autoparts store i think it came out really good for such a cheap price
shad366
shad366's Reviews
12-19-2010, 05:23 PM
Price: $0.01
Pros: Fast; easy; made a world of difference.
Cons: Must replace filter sooner.
Recommended? Yes
Comments: Not really a product, but a mod. I took my airbox out, and the tube running from the airbox to the front of the car. I took the tube, and clipped all the pieces allowing air restriction off. I cut it so it would take air directly from the fan. When I started the car after I did all this, it ran incredibly smoother, with less vibration and less noise. Also, the throttle is a lot more responsive. I will be adding a cold air intake to the car soon, but for a temporary fix, this is awesome.
jhf56
jhf56's Reviews
10-14-2010, 09:03 PM
Price: $60.00
Pros: sounds good and added a few horses
Cons: none
Recommended? Yes
Comments: i went to advanced auto parts, picked up the stuff i needed and put it together. Very easy.
seXJ
seXJ's Reviews
08-05-2010, 05:01 PM
Price: $65.00
Pros: More power I think, and my jeep is a little louder
Cons: None
Recommended? Yes
Comments: Cold air intakes are expensive and this is a third of the price. I hated the blow by in the stock intake and now I never have to deal with that again. Also I never need to buy a new filter because you can wash it. The iceing on the cake was how easy and quick it is.
TJRubicon06
TJRubicon06's Reviews
07-08-2010, 04:32 AM
Price: $150.00
Pros: hard pipe induction for River Raider snorkle
Cons: none
Recommended? Yes
Comments: I made a hardpipe induction kit using 3" polished aluminum tubing from Spectre. It then connects to a 93 GM airbox that uses a cartridge AFE dryflow filter.
sh13lds21
sh13lds21's Reviews
06-10-2010, 03:13 AM
Price: $30.00
Pros: runs better, sounds awesome,
Cons: cant keep my foot out of it
Recommended? Yes
Comments: has an awesome sound through the whole rpm rang, it was cheap,
BlackDaddyZJ
BlackDaddyZJ's Reviews
02-16-2010, 01:29 AM
Price: $35.00
Pros: Easy to make, gets a lot of oohs and ahhs and questions
Cons: none that i can see
Recommended? Yes
Comments: i made it to the aesthetic pleasure of my eye and made sure the air was cold thats all haha
drwolcot
drwolcot's Reviews
02-04-2010, 03:27 PM
Price: $45.00
Pros: sounds good, easy install, looks good
Cons: could probably use a better filter
Recommended? Yes
Comments: I got my air intake from ebay it was cheap and gives the Jeep a good sound; it may not be a K&N but it still does its job. Would recommend changing the air filter with a quality one.
Blackdout00wj
Blackdout00wj's Reviews
01-20-2010, 12:11 AM
Price: $180.00
Pros: dual intake
Cons: need hood scoops
Recommended? Yes
Comments: Sounds really aggressive and feels stronger
NOC Bulldog
NOC Bulldog's Reviews
01-12-2010, 09:25 PM
Price: $1.00
Pros: stainless steel with rubber joints
Cons: none
Recommended? Yes
Comments: unknown what brand it is, previous owner put it in. pics available to those who want
60AnniversaryTJ
60AnniversaryTJ's Reviews
11-24-2009, 12:14 PM
Price: $80.00
Pros: ORIGINAL POST: Inexpensive modification that increased mileage and hp. UPDATE: Only increased mileage at high RPM; lowered mileage around town.
Cons: ORIGINAL POST: Won't see full potential without an exhaust modification. UPDATE: bad filtration, found fine silt inside cone/stainless
Recommended? No
Comments: ORIGINAL POST: Polished stainless, open ended dry cone filter, water resistant dust cover. Found most of the parts on eBay. Half of the cost was the pre-filter
UPDATE: Gained (recovered) nearly 3mpg around town, lost 1mpg at 65mph since going back to the stock airbox with AC Delco air filter installed.
mckenzie_t
mckenzie_t's Reviews
09-01-2009, 09:46 PM
Price: $50.00
Pros: cheappppp
Cons: none.
Recommended? Yes
Comments: cheap and easy to make. paid like 50 bucks for parts
MA98zj
MA98zj's Reviews
08-23-2009, 11:12 PM
Price: $50.00
Pros: sound, increase top-end hp, mpg's +2
Cons: none
Recommended? Yes
Comments: pvc, 6x9 spectre cone filter, aluminum roofing flashing as heat sheild
98cherokee19
98cherokee19's Reviews
08-20-2009, 08:58 PM
Price: $50.00
Pros: increase hp, better mpg, louder exhaust
Cons: none
Recommended? Yes
Comments: increase hp, better mpg, louder exhaust
rgjeep
rgjeep's Reviews
07-08-2009, 07:47 PM
Price: $14.00
Pros: Horsepower improvement
Cons: Hanging vaccum lines
Recommended? Yes
Comments: Already installed noticeable improvement over stock
JAWhitney
JAWhitney's Reviews
06-25-2009, 04:58 AM
Price: $50.00
Pros: more power and better gas mileage
Cons: isn's the best looking
Recommended? Yes
Comments: You can get it at any local shop and it is very affordable! 50$ bucks will cover the cost and a lil time.
The way I have mine mounted is a lil tacky, but hell! It works.
The performance gain is noticable enough to have fun with too. Bore out your throttle body for best results.
vansskaterfreek
vansskaterfreek's Reviews
06-14-2009, 11:51 AM
Price: $1.00
Pros: nice sound
Cons: suck up water is bad
Recommended? Yes
Comments: be careful not to suck water
swamp_runner
swamp_runner's Reviews
05-20-2009, 04:23 AM
Price: $30.00
Pros: effective
Cons: none so far...
Recommended? Yes
Comments: bought a universal apc cone filter, and a redline tube, then just cut the factory setup an clamped the new parts to it!
Kasanders-02TJ
Kasanders-02TJ's Reviews
05-11-2009, 10:45 AM
Price: $30.00
Pros: cheap way to get a pony or two
Cons: cant get rid of stock resignator above throttle boddy...(yet)
Recommended? Yes
Comments:
wojo4780
wojo4780's Reviews
02-23-2009, 01:07 PM
Price: $20.00
Recommended? Yes
Comments: why pay 200's and 300's when you can make it at home, easy to do and I felt more power, doesn't look bad either
ThreadForumRepliesLast Post
Custom - 3" Cool Air Intake Induction 25 05-18-2016 12:33 PM
k & N intake Induction 14 07-04-2015 03:50 PM
Custom Catback Exhaust 35 03-19-2015 08:22 PM
custom glasspack Exhaust 4 04-22-2013 11:09 AM
HomeMade Hollowed out airbox Induction 7 02-26-2009 09:10 PM
