gary01's Reviews
Price: $249.00 Pros: Easy install Cons: none for me Recommended? Yes
Comments: Easy install, and you can feel the power increase. Solid and good looking. Do your research and you will buy one. Seems to be the best yuck for the buck if you shop it.
Cooltuck91's Reviews
Price: $220.00 Pros: Good are flow and filter Cons: none Recommended? Yes
Comments: I have had this intake for almost a year now and from what i can tell it definitely helps. I get better throttle response and fuel millage. It was pretty easy to get in. I have AC in my jeep so i had to bend some of the tubes but otherwise piece of cake.
Msprain10's Reviews
Price: $120.00 Pros: Sound, performance, throttle body Cons: water/dirt/dust easily access it Recommended? Yes
Comments: I needed an aftermarket intake to install on my inner fender wall of my tube fender. So i went with this one as it had the best reviews. I also put a outer wears pre filter on it.
conceitedjake's Reviews
Price: $150.00 Pros: Improved throttle response and a little quicker....for a 2.5. Cons: None. Recommended? Yes
Comments: The butt dyno registered a drastic improvement in perceived performance. I'm sure it actually did help but its still only a 2.5
Weelz's Reviews
Price: $250.00 Pros: --Easy to install.
--Looks good.
--Opens up space in the engine compartment for other stuff, including hyline tube fenders, etc.
--Low maintenance (filter rarely needs cleaning, and is "dry") Cons: --Kit includes a 1" throttle body spacer, which may or may not be useless, and which can cause hood clearance issues if you also install a MML. Recommended? Yes
Comments: For the reasons listed above, it's a good product.
Jeeprin's Reviews
Price: $200.00 Pros: Improved throttle response, potentially better MPG, improved HP Cons: None Recommended? Yes
Comments: Easy install, good fit. Horrible directions.... Go to projectJK for a more detailed description of how to install if necessary
tim04tj's Reviews
Price: $275.00 Pros: Easy install . Great fit and finish Cons: At about 2000 RPM the intake whistles . Recommended? Yes
Comments: Great product .
rockymntedition's Reviews
Price: $273.99 Pros: Better proformance Cons: get dirty easily Recommended? Yes
Comments: Increases exceleration, great sound
limeking's Reviews
Price: $50.00 Pros: no oil Cons: bigger than the k and n Recommended? Yes
Comments: It is actually just the filter, they dri Flow one on the k and N intake.
Joe2478's Reviews
Price: $298.99 Pros: Easy to install Cons: None Recommended? Yes
Comments: First thing I ever do with a new vehicle is put one of these in it. Quickest/easiest upgrade I've found you can install in a vehicle right after you pull it off the lot. I'm in no way mechanically inclined but I was even able to install it myself. This is my 2nd Jeep with one & the 3rd I've installed.
vonmuse's Reviews
Price: $205.99 Pros: nice sound Cons: well poor gas mileage due to the fact I hit the gas all the time to hear it scream Recommended? Yes
Comments: really easy to install
dm33buckeyes's Reviews
Price: $100.00 Pros: Good Cons: None Recommended? Yes
Comments: Came on the Jeep when ibought it.
rubithebeast's Reviews
Price: $300.00 Pros: may have added a bit of power. came with throttle body spacer that gave it more of a deep sound when on the throttle hard. Cons: gets dirty faster Recommended? Yes
Comments: typical cold air intake only real difference is it came with a dryflow filter which is "supposed" to be better.
gotmudd1's Reviews
Price: $250.00 Pros: Easy to install
More power Cons: expensive Recommended? Yes
Comments: around 2300 RPM's the engine sounds like a V8. Does not move like a V8 though
YWU
 Junior Member |
YWU's Reviews
Price: $248.00 Pros: Sounds cool. Looks cool Cons: Concern about open getting filter wet/muddy Recommended? Yes
Comments: I don't know if I get more HP or MPGs but it sounds great.
00jeepred's Reviews
Price: $300.00 Pros: abotu a i mpg jump. Cons: expensive, prone to water. Recommended? Yes
Comments: Easy to install. TB spacer pretty much useless but it comes with it why not? Sounds good. dry elemet is nice for dusty conditions.
outlaw8383's Reviews
Price: $40.00 Pros: PVC will last forever Cons: none Recommended? Yes
Comments: PVC piping with a APC Cone filter
TINTINUAE's Reviews
Price: $289.00 Pros: Excellent power gains compared to K&N, plus no need to oil and only needs cleaning every 30,000 miles. Cons: Can't think of any. Recommended? Yes
Comments: The item is brilliant, I am very impressed with how my mid-range torque improved over the K&N intake, plus I only need to clean it every 30,000 miles with a cleaning solution with no oiling required.
Very much worth the money.
