Xtreme-fi (ebay) 63MM Throttle body
Rating: |
Product Information
| MSRP: |
$100.00 |
| Average Price: |
$113.67 |
| Manufacturer: |
Xtreme-fi (ebay) |
| Recommended? |
They do a real nice job on boring out. Its 63mm all the way through and they replace the butterfly with a lighter weight one.
raedioactiveman's Reviews
03-29-2011, 07:28 PM |
Price: $160.00 Pros: n/a Cons: n/a Recommended? No
Comments: Beware of xtremefi. They never refunded my core deposit and kept my core. They are crooks. Simply google reviews of them and/or check out the BBB.org to find out more.
They are getting away with it on ebay because buyers give them a review once they receive the product and not after they receive their core refund.
turbovelocity's Reviews
Price: $75.00 Pros: cheap price , good build quality Cons: with my stroker engine and 2000 intake manifold , it can get a little touchy on throttle response Recommended? Yes
Comments: Recieved product quickly , nice smooth bore job all bolt holes clean and threads in great shape . Nice jump in performance when paired with other mods such as cold air intake , ignition and exhaust.
searchall27's Reviews
Price: $35.00 Pros: Great Cons: none Recommended? Yes
Comments: No problems easy to install.
Sterner09's Reviews
Price: $184.00 Pros: came with the spacer Cons: was oem condition Recommended? Yes
Comments: was only 140 after the core charge.
XJmaine97's Reviews
Price: $70.00 Pros: Increased acceleration in mid-RPM ranges, increased gas mileage Cons: none yet, no whistling or anything Recommended? Yes
Comments: I got a bored out stock throttle body from Leigh Performance, very fast shipping and a very clean TB. After returning my core I think the total cost was around $70.00. One of the easiest and best mods I've added to my DD stocker yet.
Unlimited04's Reviews
Price: $80.00 Pros: Quality workmanship, allows slightly less pressure drop across intake manifold, engine revs a bit more willingly, especially in higher rpms Cons: Customer service is poor, core return not likely to actually happen - just keep your TB and sell it outright Recommended? Yes
Comments: Overall a good upgrade for less than $100. Don't expect the core return to happen - just keep your existing TB and sell it outright. Breaths a bit better at higher RPMs and results in less pressure drop across the manifold. Not much, more info in TJ CAI FAQ - only saves about 2 HP at WOT. Definitely a better option than name brand expensive options.
xantasm's Reviews
Price: $240.00 Pros: Custom brass throttle blade – 50% thinner than stock
Bored to 63mm – stock necks down to 52mm
Halved throttle shaft w/ low profile high strength screws
Semi-polished air inlet
Easy to install in about ½ hour
Cons: Customer service is absolute garbage, core's are not refunded. DO NOT SEND YOUR CORE TO THIS GUY Recommended? Yes
Comments: Custom brass throttle blade – 50% thinner than stock
With a stock 4.0L motor I noticed a more full response throughout the gear range on my 05 LJ with a 6 spd. Acceleration is improved in city and freeway driving in that the lag in response normally felt when trying to accelerate in a situation such as passing is greatly reduced. I would deffinately recommend this product and the price is much lower than brand name competitors. I would warn anyone buying one of these thought that the customer service from extremefi is horrible. They didnt refund my core for two months and when I got upset with them about it they refused to refund it and made me pay shipping to have the core shipped back to me. Four months later, still waiting on my core. If you buy one of their throttle bodies, do yourself a favor and sell your core here on JF.
CrazyWJ242's Reviews
12-28-2008, 09:59 PM |
Price: $100.00 Recommended? Yes
Comments: works fine, replaced plate screws with countersunk screws for just that much more air flow
zackXJ's Reviews
10-19-2008, 12:10 PM |
Price: $90.00 Recommended? Yes
Comments: So far, it seems like it's freed up a lot of horsepower. It's easier to pass on the highway, because it seems to downshift much quicker and with more oomph.
TDedeo_2001_XJ's Reviews
10-09-2008, 10:15 PM |
Price: $50.00 Recommended? Yes
Comments: Works well. Easy install. Notice a quick "whistle" on acceleration. Had to provide the factory one as a replacement. Easy to work with.
NalinMFG's Reviews
06-09-2008, 03:55 PM |
Recommended? Yes
Comments: they have used factory throttle bodies that they bore out, you send them your old one in the box they ship you the bored one in. everything lines up perfect, and it looks completly stock. real simple bolt on. all the intake/performance stuff people argue about? youre making the hole bigger that lets air into your engine. seriosuly, why wouldnt this work. i can feel a difference and i recomend buying this.
TslAtticus's Reviews
05-26-2008, 12:05 PM |
Price: $80.00 Recommended? Yes
Comments: Helped throttle response greatly and doesn't whistle like i've heard the other bored out TB's do.
