Spacer Throttle body space Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Throttle Body Next Product
Rating:
Product Information
MSRP: $140.00
Average Price: $64.29
Manufacturer: Spacer
Recommended?
Yes: 36 / No: 8
Throttle body space
None
Page 2 of 3 1 2 3 > Last
RKOTAREK
RKOTAREK's Reviews
07-27-2009, 03:13 PM
Price: $64.00
Pros: it makes a noticeable difference in low to mid range torque
Cons: it is a little loud sitting at lights
Recommended? Yes
Comments: It is a Power Aid throttle body spacer and took half an hour to install came with everything i need to install even a extra gasket for the throttle body. Doesn't effect gas mileage either positive or negative. this one doesn't have the high pitch noise when acceleration.
UrbanOffRoad124
UrbanOffRoad124's Reviews
06-03-2009, 03:06 AM
Price: $99.99
Pros: None, maybe the sound if you like that.
Cons: Waste of money
Recommended? Yes
Comments: This is for a '02 WJ w/ 4.7. The brackets provided were horrible, I had to make one piece myself. If I didn't spend 100 bucks, I would have thrown it away but I made it work. I don't think it did anything performance wise, it just whistles. Don't waste your money.
Russ_93YJ
Russ_93YJ's Reviews
05-28-2009, 06:20 PM
Price: $55.00
Pros: Includes all hardware for Wrangler or Cherokee auto or standard trans.
Cons: Available in the buff only
Recommended? Yes
Comments: New 2.5L,4.0L/4.6L stroker T-Body spacers. Bored to match the 63mm T-Body. Add to the flow, lower the torque curve by extending the distance between the intake valves and the throttle body(engineering!). The same as lengthening the intake runners for all the older motor heads.
TURBOLOVE96
TURBOLOVE96's Reviews
05-20-2009, 07:01 PM
Price: $35.00
Pros: Gave me more horse power
Cons: Still have to match the intake manifold size to match but not a problem with the product.
Recommended? Yes
Comments: Works great got it cheap and came with gaskets.
daking20
daking20's Reviews
03-29-2009, 03:53 PM
Price: $75.00
Recommended? Yes
Comments: No real notice...its a pretty good paper weight if you ask me haha. nothing crazy
xXArcticWolfXx
xXArcticWolfXx's Reviews
03-22-2009, 10:20 PM
Recommended? Yes
Comments: Throttle body spacer that came wtih my AEM Brute Force CAI. Not sure how much power it adds with the CAI and my new exhaust because I never drove without it after all the mods.
42spaz42
42spaz42's Reviews
03-01-2009, 09:40 PM
Price: $65.00
Recommended? No
Comments: Don't do it. If you doo save original bolts that are shorter so you can un do it.
gunnerharley
gunnerharley's Reviews
02-27-2009, 10:13 PM
Price: $50.00
Recommended? Yes
Comments: 1" Throttle body spacer, very easy install and seemed to improve performance.
go4x4it
go4x4it's Reviews
02-23-2009, 01:30 PM
Price: $58.00
Recommended? No
Comments: TransDapt Torque curve TBS from summit. Supposed to give you more torque in the power band. I see a small increase, but what i see more is a jump in fuel econ. from 12 to 15-16 ish
cx300
cx300's Reviews
12-27-2008, 11:33 PM
Price: $70.00
Recommended? Yes
Comments: .................................................. .........................
jmoney08
jmoney08's Reviews
12-20-2008, 09:58 AM
Price: $65.00
Recommended? Yes
Comments: This was an easy product to install, it took about 10 minutes to put it. Just remove the air flow tube from the throttle body, the put the spacer in, screw tube back down and your set. Added about 10 horses.
Sungard
Sungard's Reviews
12-19-2008, 06:52 AM
Price: $75.00
Recommended? Yes
Comments: Helix 62mm TBS great addition that works well with , AEM Brute Force Cold Air Induction System.Noticed increase in HP and torque, however a mild drop in milage, well worth it.
98-XJ-Nate
98-XJ-Nate's Reviews
10-21-2008, 10:54 PM
Recommended? Yes
Comments: came with my Jeep at the time of purchase.......................................... ....
JamJeeper05
JamJeeper05's Reviews
10-03-2008, 09:07 AM
Price: $65.00
Recommended? Yes
Comments: Not a huge difference over all. it helps with a little bit of low-end torque.
pulloptc
pulloptc's Reviews
07-19-2008, 07:38 PM
Recommended? No
Comments: Caused some TPS problems untill I dropped the idle speed. Since then has run great.
tangyPeej
tangyPeej's Reviews
07-17-2008, 10:45 PM
Price: $70.00
Recommended? Yes
Comments: really works well. it was a cheap upgrade and works well...took 5 min to put on. . .
jopolly3
jopolly3's Reviews
07-02-2008, 03:10 PM
Price: $80.00
Recommended? Yes
Comments: I had ordered a Helix Power Tower Plus a number of years ago and actually installed it last week. I do notice a slight increase in mpg (went from 17.1 to 18) i also have a K&N which supposedly makes it whistle under acceleration but its not too bad
jebmccall
jebmccall's Reviews
06-29-2008, 11:42 PM
Price: $140.00
Recommended? Yes
Comments: rustys throttle body spacer,intake tube, and kn 6x9 air filter, withg a kn 6x5 filter for the trails and intake kit kicks but
4R16
4R16's Reviews
06-26-2008, 06:42 PM
Price: $36.00
Pros: Sound good!
Cons: It was not free.
Recommended? Yes
Comments: I can feel a difference in mid range, but not anything huge. It sounds pretty cool, but is not annoying. I cant say as to fuel economy yet, because I only have about 25 miles on it, but I will post after I give it a fair shot to produce results, negative or positive.
JoeySnow70
JoeySnow70's Reviews
06-11-2008, 09:10 AM
Price: $25.00
Recommended? Yes
Comments: I Dint really feel any diference in MPG increase or power but im runing just a drop in performance filter and a snorkel, maybe it will work better with a cold air intake.
ThreadForumRepliesLast Post
Jeep 4.0 throttle body Throttle Body 29 10-17-2015 12:05 AM
Rustys Offroad Throttle body spacer Throttle Body 15 10-13-2015 11:46 AM
TBS JEEP WRANGLER TJ THROTTLE BODY SPACER 2.5L 4.0L 91-04 Throttle Body 7 02-11-2012 08:50 PM
factory throttle body Throttle Body 4 02-19-2009 08:44 PM
L&b racing , (ebay id res069tu) JEEP 62MM THROTTLE BODY SPACER 2.5L 4.0L 1991-2004 Throttle Body 0 10-25-2006 04:40 AM
