Jeep 4.0 throttle body
Rating: |
Product Information
| MSRP: |
$40.00 |
| Average Price: |
$46.86 |
| Manufacturer: |
Jeep |
| Recommended? |
Factory 4.0 throttle body installed on the 2.5L.
26679cj7's Reviews
Price: $300.00 Pros: easy to install,hesco crank shaft pulley with magnetic pick up Cons: none Recommended? Yes
Comments: Hesco offers great products and even had and knew what electric fuel pump I needed for my swap,all parts I got from Hesco's have being of good quality.With out them I would still be lost and not wheeling.
Phreaq's Reviews
Price: $15.00 Pros: More air flow, better MPG possible, added with other easy mods for a nice HP+, cheep, CA Smog legal!!! Cons: Possibility of breaking a bolt for the idle air controller.
Possibility of breaking IAC gasket. Recommended? Yes
Comments: I found an INSTANT gain When I did this. I was able to moderately accelerate from 25MPH in 5th gear! This was sure to bog it down before.
Before swap:
2.5, ax-5, E-fan, 4.10, 32's
Clean the new TB, remove 2.5 TB with 10mm socket, Swap all your sensors over to the 4.0 TB. Be careful removing the bolts for the sensors. A Heat Gun may be required to melt the lock tight. Use the T20 torques! Pay attention to how the TPS is sprung when screws are removed. Reassemble.
I have found them to go for $10-15. I came across a couple for free but one was wrong year. Gaskets are cheep for TB. I don't know about the IAC gasket. I reused all gaskets.
nofearwindham's Reviews
Price: $10.00 Pros: Cheap, noticeable difference Cons: None Recommended? Yes
Comments: This was the cheapest most effective power add-on I did to my 2.5L. Even without grinding out the intake manifold i noticed the difference, especially in 5th gear(when i had 5th gear). bought off of ebay
kornonthekob99's Reviews
Price: $40.00 Pros: INCREASE AIR FLOW Cons: NEED TO SMOOTH OUT THE MATING SURFACE BETWEEN NEW THROTTLE BODY AND THE INTAKE MANIFOLD WITH A DREMEL TO MAXIMIZE EFFICIENCY Recommended? Yes
Comments: WITH TB AND 19 LB INJECTORS, A 2.5l JEEP CAN NOW MOVE AT HIGHER RPMS... SHOULD BE ONE OF FIRST 3 MODS DONE... START ON THE RIGHT FOOT
natedawg3256's Reviews
Price: $30.00 Pros: seems to help all around Cons: none Recommended? Yes
Comments: For what i spent it seems to help all around, It was a very easy swap only took about 15 mins to switch. that doesn't count cleaning. (junkyard TB)
mrmark's Reviews
Price: $1.00 Pros: n/a Cons: n/a Recommended? No
Comments: I didn't feel much of a change, if it cost any money I would say it's not worth it, but I had a 4.0 I was selling so I swapped to see. Both vehicles seemed to have the same power and ran just he same.
SQUARElights4me's Reviews
Price: $15.00 Pros: 99% bolt on. Just have to grind off the little tab on the bottom of the 4.0 TB. If you are feeling frisky you can grind the opening on the intake to fit the exact opening on the larger TB. For 15$ you cant beat a couple of HP and Ft/lbs of torque. You are not gaining much, BUT any little bit helps with the low out put 2.5L. Cons: need a grinder/grinding tool to grind off the tab. Recommended? Yes
Comments: For 15$ junkyard special, this upgrade IMO is worth it. I even re-used the sensors off of the donor 4.0 TB. If one of your sensors goes bad, you can just swap them off of your old 2.5 TB and save yourself 40-50$ from a new TPS or AIS sensor. I noticed a "peppier" throttle response and i actually feel the difference in 4th and 5th gear when i get hard on the throttle. (dont confuse description with roasting the tires or passing people in the fast lane, but it does HELP some)
YelloJeep's Reviews
Price: $30.00 Pros: Some more get up and go. Easy to do. Cons: SLIGHTLY higher RPM at idle. Recommended? Yes
Comments: VERY easy to do, and if you don't like it of it doesn't work out for whatever reason it is easy to undo. It is helpful to already have a TB spacer.
RKOTAREK's Reviews
Price: $150.00 Pros: faster acceleration, 1 mpg better fuel mileage. just sounds meaner. Cons: did a smoke test of the vacuum system on my jeep and the throttle body around the butterfly valve shaft leaks a good amount but nothing too crazy. Recommended? Yes
Comments: I found this 63mm throttle body on line for about $150 . put it on in like 15min and right away on the first test drive noticed a difference
YelloJeep's Reviews
Price: $15.00 Pros: Immediate power gain for little money and minutes of installation. Cons: Slight idle increase (1100RPM?) Don't yet know how it will effect gas mileage. Recommended? Yes
Comments: Cheap and easy and I noticed a difference immediately. If you don't like the results you can put the old TB back on in minutes.
YelloJeep's Reviews
Price: $15.00 Pros: cheap power gain Cons: Slight increase in idle RPM...don't know yet how it will effect gas mileage. Recommended? Yes
Comments: It was quick and easy and I could tell a difference right away. Also, it was very inexpensive. One of those things where if it doesn't work well it only takes minutes to put things back the way they were.
T4STE's Reviews
Price: $5.00 Pros: great once you bore it to 60mm Cons: none whatsoever Recommended? Yes
Comments: works well and its free if you do it yourself
dhc6's Reviews
01-30-2010, 04:59 PM |
Price: $25.00 Pros: a clean throttle body Cons: none Recommended? No
Comments: I just put a 4.0 throttle body on my 2.5 yj. It took about 25 miles of city shopping for the rpms to settle down (just touching the throttle and it would jump up to 2000rpms then settle down). Everything is normal now. I do not see any power improvements though. I do not see any power declines, so it stays on.
Nitro_Man's Reviews
Price: $25.00 Pros: sTOCK FROM THE BONE YARD Cons: none Recommended? Yes
Comments: eASY INSTALL DIRECTIONS ON THIS WEBSITE. Just swap out sensors and it was good to go,
r_unda's Reviews
Price: $25.00 Pros: none Cons: none Recommended? No
Comments: Did not really notice any change in performance
RichN's Reviews
Price: $90.00 Pros: More power Cons: None as of yet Recommended? Yes
Comments: A little something to add more power is good for everybody. No complaints as of yet, great workmanship and StrokedJeeps is super easy to deal with.
Cdn96XJ's Reviews
Price: $30.00 Pros: Noticable torque increase Cons: None. Recommended? Yes
Comments: I took my throttle body to a non-automotive machine shop. Removed the butterfly and told him to match the bottom 55mm with the top 60mm without passing the butterfly shaft position. He did it in 20 minutes for $30 cash. Couldn't be happier.
1993redjeepyj's Reviews
Price: $40.00 Pros: cheap, can get it at any bone yard, bolt right on. Cons: none Recommended? Yes
Comments: Installing the 4.o throttle body on the 2.5 was very easy. just remove the 4 bolts and remove the 2.5 tb from the intake. remove the iac and tps sensor from the 2.5 and install on the 4.0. Then just reinstall. very straight forward
aspecialdad's Reviews
Price: $75.00 Pros: adds a nice sound, also increased fuel milage Cons: none Recommended? Yes
Comments: I put this on a few years back when I added my K&N Filter set up.
With both units installed increased my fuel mileage by 3-4 mpg am very happy with the set up.
It was a quick easy install took maybe 30min from start to finish.
TURBOLOVE96's Reviews
Price: $25.00 Pros: Gave me more power and a quick easy install Cons: none yet Recommended? Yes
Comments: I got mine used off ebay and havn't had any problems with it.
