Go Back JeepForum.com > Reviews > Engine > Throttle Body > Howell Engine Development TBI Kit
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Howell Engine Development TBI Kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Throttle Body Next Product
Rating:
Product Information
MSRP: $1,000,000,000.00
Average Price: $35,715,317.32
Manufacturer: Howell Engine Development
Recommended?
Yes: 27 / No: 1
This kit will only fit AMC or after market intake manifolds that have the Holley bolt pattern. Air filter not included and must be purchased separately. Howell Throttle Body Fuel Injection Kits have owners reporting smooth operating on all angles and inclines and improved starting and drivability with noticable power gain. Gas mileage improvements vary depending on the condition of the replaced carburetor. Since the system operates in a closed loop using the oxygen sensor to maintain an average 14.7:1 air to fuel ratio, improved gas mileage can be expected. The benefits of this Throttle Body Fuel Injection system over the competition, is the almost exclusive use of GM parts making them available through any GM dealer worldwide, should you experience trouble on the road. All GM on-board diagnostics and limp-home features are retained and, with our service manual, you can troubleshoot most problems yourself. You get the benefit of millions of dollars of durability development by GM, used to perfect their late model vehicles, at no additional cost. This kit is installed with the production distributor. Production GM TBI air cleaner can be used or several aftermarket designs can be adapted
Page 1 of 2 1 2 > Last »
gunrun45
gunrun45's Reviews
01-08-2012, 10:17 AM
Price: $1,000.00
Pros: Imediate increase in throttle response and no more issues on hills or altitude differences. I also got to toss the maze of smog lines and keep in smog legal in CA. Jus needed to keep the cat, canister, egr and PCV
Cons: It can take a bit to get it it really dialed in if you're picky like me. I didn't have a prom code reader so it was more trial and error for me. Buy a prom code reader and be done with it. It's a no brained after that.
Recommended? Yes
Comments: Great product that really made a serious improvement in the jeep! I recommend it to everybody I know who has one
rsg1963
Junior Member
rsg1963's Reviews
11-17-2011, 08:37 AM
Price: $1,100.00
Pros: Reliability, cold starting, off-camber running.
Cons: None
Recommended? Yes
Comments: One of the best upgrades I've ever made to a Jeep. I should have done this a very long time ago. Wheeling has never been easier, cold weather starting is a snap and that's saying something for Jeeps!
todbld
todbld's Reviews
10-30-2011, 12:26 AM
Price: $1,200.00
Pros: Great fuel economy, always starts, No running rich, easy install, unlocked lot of power.
Cons: None
Recommended? Yes
Comments: I bought the Howell TBI last spring to replace my rebuilt carb. I was tired of the 8 miles to the gallon that I was getting. Plus it always smelled of gas in the cab. It was super easy to install, I did it in about 6 hours over to evenings. I decided against the Mopar kit due to a few vendors detailing a bunch of problems with the factory kits. I have taken it into elevation and had no trouble at all. I ask the guys at Howell to flash me a chip for altitude incase I ever run into trouble up in the mountains. I had been to 12,000 foot and the jeep ran great with the stock program. I think it is a great kit for the price.
thegladiator
thegladiator's Reviews
09-26-2011, 10:05 AM
Price: $1,199.00
Pros: got rid of the stalls on the slopes
Cons: none yet
Recommended? Yes
Comments: Been Deployed since before this was installed. Hope to come home to a totally easier to keep runnin Jeep
Jacoby22
Jacoby22's Reviews
08-30-2011, 02:16 PM
Price: $1,300.00
Pros: Start Up First Try,Passed Emissions No Problem.
Cons: None Yet
Recommended? Yes
Comments: Easy install took about 4 hours total! only problem I ran into was with the cto switch, wasnt correct from PO. So make sure you have the correct one in there.
debri81
debri81's Reviews
06-18-2011, 09:58 PM
Price: $800.00
Pros: Runs great
Cons: No compliants
Recommended? Yes
Comments: To save some cash I got several bone yard TBI's and rebuilt one of them keeping the other as a spare. Save several hundred. I added a Clifford intake and Jacobs Milemaster ignition and Ultra coil at the same time. I should have installed the TBI kit and got it working and dialed in the then went and added the other items. But I had pulled the motor to rebuild it and then had to try and remember what connected to what... Major PITA but self inflicted. No digital cameras back then...
85McJeep
85McJeep's Reviews
09-16-2010, 12:53 PM
Price: $1,200.00
Pros: Performance
Cons: Tuning it...
Recommended? Yes
Comments: Jeep drives much better, specifically on the highway. Better fuel economy. Easy to install, I am not a mechanic. A little difficult to tune...they don't tell you that you need a larger fuel return line.
mlittle
Junior Member
mlittle's Reviews
08-03-2010, 07:07 PM
Price: $1,200.00
Pros: engine performs better, better gas mileage
Cons: wiring harness too short, mounting bracket not included for MAP sensor, instructions were very general, should use knock sensor and control timing
Recommended? Yes
Comments: The wiring harness supplied with the kit is just barley long enough to reach all the components, this prevents a neat installation as all the wiring is stretched.
I also don't care for the use of hose and screw clamps for the connections of fuel lines to the throttle body, I don't feel that they are safe over the long term.
I would have preferred the Mopar system but could not afford it.
Karma
Karma's Reviews
07-11-2010, 08:32 PM
Price: $1,200.00
Pros: Starts in all weather, perfect idle, never stalls due to trail angles, engine will run down to 300 RPM which is a huge advantage.
Cons: Except for price, none.
Recommended? Yes
Comments: Upgrading to the Howell TBI system may be be the best mod on my Jeep. The installation is not hard, and getting rid of the miles of vacuum lines I had with the Carter BBD carb is wonderful.
This TBI system has no drawbacks. Trail manners are perfect. It always starts quickly even in sub-zero temperatures (yes, we have extreme weather in the New Mexico mountains).
Do not expect huge power gains or improvements in gas mileage. There may be some improvements but they are small. I would not buy the Howell system for these gains. The main improvement is basic engine runability which is first class. The Howell tuns the 258 into a modern engine.
Howell makes a version of this kit that will pass California emissions tests.
L12graffix
L12graffix's Reviews
04-07-2010, 08:33 PM
Price: $1,200.00
Pros: So long carb and Pulse air system
Cons: cost
Recommended? Yes
Comments: With the CA emissions system it can replace the pulse air system on your CJ that you can't find parts for and runs so much better without the stock carb.
cthompson8846
cthompson8846's Reviews
03-05-2010, 11:39 PM
Price: $1.00
Pros: Turn Key
Cons: Idles high at times, I'm sure it's a vacuum problem just need to figure out where.
Recommended? Yes
Comments: Still working out some kinks, just need a little more time to figure it out.
LDStoddard
LDStoddard's Reviews
12-10-2009, 04:03 PM
Price: $1,800.00
Pros: Runs great
Cons: expensive....
Recommended? Yes
Comments: Great product if you plan to keep an "old" "non-injected" engine
ditchdog
ditchdog's Reviews
12-10-2009, 02:55 PM
Price: $1,300.00
Pros: Run's smooth
Cons: Install and getting it to run right was a nightmare.
Recommended? Yes
Comments: According to Howell, the TBI kit comes from them set at 12 lbs of fuel pressure. Mine was more around 18 lbs (floods the engine). Ended up having to run a fuel pressure regulator. If you install this kit, I would reccommend using a fuel pressure tester before you even fire the engine for the first time (on both the supply and return lines), just to see where your fuel pressure is at. Also, maybe its just my jeep, but on the return line it goes: carb/TBI, rubber line, steel line, rubber line again, and finally into the steel line that runs down the frame rail to the gas tank. I took off the first steel line and ran rubber line from the TBI to the steel line on the frame rail to reduce the amount of pressure on the return line as well as decrease the distance. Also had to use an adapter to reduce the size of the return rubber line so it would fit onto the return steel line on the frame rail. If you live in CA or other smog state, you will probably have to replace the catalytic converter as the stock cat is a 2-way converter with an air tube connect to the rest of the emmisions components. Since the TBI kit no longer needs the stock emissions components, you need to upgrade to 3-way cat and keep the air tube capped. Also, CA catalytic converters are the same as the other 49 states but have a different serial/product number that MUST be used only in CA. Thank you smog nazis.
cfernandez
cfernandez's Reviews
09-08-2009, 02:45 PM
Price: $1,200.00
Pros: Runs smoother and I don't worry about inclines or changes in elevation. Wasn't too hard to install.
Cons: $$$$$
Recommended? Yes
Comments: Make sure if you order the set-up from one of their distributers, such as 4WD or Quadratec that you call Howell first, might save you hassels down the road. Because I already had a MSD ignition box I should have received a converter from Howell with the kit I bought from 4WD. The guys from 4WD never asked me about my current setup and just gave me a kit from the catalog. Anyways, I eventually had to give it to a mechanic after I installed the kit because it did not run quite right and he called Howell and they sent the neccessary part to run off my MSD.
WITCHANDODDBALL
WITCHANDODDBALL's Reviews
03-24-2009, 02:02 AM
Price: $1,190.00
Recommended? Yes
Comments: WORKS GOOD HAD SOME FLOODING PROBLEMS THAT WENT AWAY. SOLVED STALLING PROBLEM I HAD WITH CARBURATION AND PASSED CALIFORNIA SMOG.
mugsy310
mugsy310's Reviews
03-18-2009, 11:29 PM
Price: $1,100.00
Recommended? Yes
Comments: Works great. Not an easy installation and wouldn't recommend it to someone with limited mechanical or electrical experience. But a great product and it has definitely helped the performance.
84 CJ7
84 CJ7's Reviews
01-10-2009, 06:52 AM
Price: $1,200.00
Recommended? Yes
Comments: Easy to install, cleans up the engine compartment tremendously. Runs better than the old carb. but that was a piece of crap. Can't seemt to make it quite running rich. Have replaced the chip 3 times and talked to Howell mahy times.
RetiredSERE
RetiredSERE's Reviews
09-08-2008, 01:23 PM
Price: $1,100.00
Recommended? Yes
Comments: Instructions could have used a little more diagrams and seperate the Calif Legal from all the other units. Easy to install and started on the first turn with old fuel and no timing adjustment.
gmakra
gmakra's Reviews
06-04-2008, 09:26 AM
Price: $1,300.00
Recommended? Yes
Comments: Good product easy to install though takes a bit of tinkering to make it run correctly
jbolty
ISO 9001 Compliant
jbolty's Reviews
04-29-2008, 10:10 AM
Price: $1,100.00
Recommended? Yes
Comments: Very happy with it so far. It runs better than new, more power, higher rpm and no flooding on hills.
ThreadForumRepliesLast Post
zMAX Engine Formula Internal Parts 2 03-18-2009 11:39 PM
Glock Forum
