1989 2.5 swapped into 2000 Jeep Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Throttle Body
Rating: None
Product Information
I recently swap a 1989 2.5l into my 2000 Jeep that had a 2.5l in it also. I took off all the wiring harness from the 89 and put my tj harness on. Also took of the old throttle body injection and put my tj fuel injection on. After the swap it started up good idled great test drive was good also. But when I went to drive it home it began to sputter like it didn't have enough fuel at crossing speed around 3500 rpms it would bog intel it died no matter how much gas I would give it. Had a code for high voltage fuel regulation so replaced that and now it will not start. I unplugged the battery when I replaced the fuel pump and since I did that they're no codes. fuel, spark, and compression are all where it's supposed to be. Has anyone on this forum ever done anything like this? I've replaced crank position sensor, throttle body sensor checked voltage on the fuel pump checked every ground connection, put new ignition coil.
None
