Edelbrock Shorty Headers with TiTech coating
Rating: |
Product Information
| MSRP: |
$430.00 |
| Average Price: |
$311.78 |
| Manufacturer: |
Edelbrock |
| Recommended? |
This new Tri-Y design header will bolt directly to the factory exhaust system. "Using 1½" diameter 409 stainless steel primary tubes, a ½"-thick laser-cut port flange and ¼"-thick laser-cut collector flange, the new header improves performance for 4.0L 1991-1999 Jeep vehicles. "With the new TiTECH™ coating, headers will have heat stability to 1,600° F," Said Jack Mayberry, Edelbrock vice president of R&D. "At higher temperatures, the Ti-TECH™ coating will flux, becoming harder and more abrasion resistant, unlike organic coatings that chalk and lose adhesion with extreme heat."
Because Edelbrock listens to its customers, these new headers bolt directly to the factory crossover pipe with no cutting or welding required for installation. The tubing is mandrel-bent to help ensure superior flow.
pyro5613's Reviews
Price: $300.00 Pros: Sounds great Cons: gasket very delicate Recommended? Yes
Comments: Stock header had a crack about 180degrees around a single port so i decided that when i replaced i was going to upgrade. This header sounds great and insturctions, a buddie and a six pack make this an easy pull and replace afternoon job.
jeffarcher401's Reviews
Price: $399.00 Pros: super fit Cons: non yet Recommended? Yes
Comments: These have a thick flange and fit perfect. Will work with stock Y-pipe. Comes with optional heat tube attachment for air cleaner and they look great.
FST1994ZJ's Reviews
Price: $350.00 Pros: Easy install
Good material
Cons: little exspensive Recommended? Yes
Comments: I got these edelbrock hearers and installed them in my 5.2 to give it a meaner sound and some added horsepower. :] they just bolted right on my factory block no problems. they tend to wear away gaskets very quick :/
sarcasmo's Reviews
Price: $350.00 Pros: Compatible with emission controls systems. Cons: None Recommended? Yes
Comments: Comes with 'tree' attachment for smog/emission system attachment. Product is as advertised, less restrictive than the stock headers, good performance.
haves0090's Reviews
06-13-2009, 05:00 PM |
Price: $377.00 Pros: noticable power gain; affordable; lifetime warranty Cons: none Recommended? Yes
Comments: this header really worth the money. definately noticed a bit more power and it adds a nice rumble to your exhaust
99GeePTJ's Reviews
03-28-2009, 12:24 AM |
Price: $430.00 Recommended? Yes
Comments: Go with porcelain if you want, it lowers temperatures and increases HP. It may be unnoticable but for 50 bux more why not. I've purchased it, yet to install it and or rate it. Will let you know but I'm pretty sure it'll be great.
lilacsl2's Reviews
10-28-2008, 12:28 PM |
Price: $250.00 Recommended? Yes
Comments: Works great, easy inexpensive fix for the cracked factory header, made a difference in the tone of the exhaust, a little deeper sounding than factory.
nicolaimonkey's Reviews
06-03-2008, 09:25 PM |
Price: $349.00 Recommended? Yes
Comments: Awesome headers , much improved power and throttle response over stock , much more low end power , like between 1000 and 2500 rpm thus increasing fun-to-drive factor. very happy with purchase.
