Go Back JeepForum.com > Reviews > Engine > Headers > Automotive Parts Network APN 4.0L headers
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Automotive Parts Network APN 4.0L headers Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Headers Next Product
Rating:
Product Information
Average Price: $150.75
Manufacturer: Automotive Parts Network
Recommended?
Yes: 12 / No: 1
Great replacement headers, 129$. Easy to put on with instructions. Changed the exhaust note for the better too, dropped the chaotic high pitch at high RPM shift. Really smoothed out the tone threw all RPMs.
http://www.automotivepartsnetwork.com/store/pc/AutoPart.asp?idProduct=20009
http://www.ineedparts.com/auto-parts/exhaust-parts/exhaust-manifolds/jeep-exhaust-manifold.html
95_xj_country
95_xj_country's Reviews
02-09-2012, 06:16 PM
Price: $129.00
Pros: good for price. better then stock. little more power too
Cons: nothing really
Recommended? Yes
Comments: was easy to put on, bolted right on. i got a little more power too
mbardeen
mbardeen's Reviews
09-14-2011, 06:25 PM
Price: $150.00
Pros: Drop in installation. Bolted right up with no problems
Cons: None
Recommended? Yes
Comments: This was my first major header install. It came with the gasket and hardware. It took my an afternoon to install, and everything bolted right up with no modifications. The welds look hefty and unlikely to crack.
The sound around 2500-3000 RPMs is intoxicating. I had hoped my gas mileage would get better, but I doubt it will -- the sound makes me want to step on the skinny pedal.
Can't say if there's many more ponies there, since my old manifold suffered from the 4.0 crack..
klrstew
My other veh is a 08KLR
klrstew's Reviews
07-14-2011, 12:30 PM
Price: $165.00
Pros: Cheap, Great quality and came with a gasket
Cons: None to speak of
Recommended? No
Comments: After reading a bunch of reviews and searching the web I finally decided on this one. I had the money for one of the Bigger named brand ones, but went with this. I couldn't be more happier. It was a decent install, had a little difficulty getting it into place (just like any header), but once I found the sweet spot popped right in. And, with the money I saved i got all new pipe front to rear and a new Thrusher muffler to boot.
manicjester3
Junior Member
manicjester3's Reviews
05-24-2011, 10:21 AM
Price: $160.00
Pros: Cheap, 321 Stainless, lifetime warranty
Cons: None so far
Recommended? Yes
Comments: Cheap header, solved my cracked header issue, lifetime warranty, fast shipping.
thebeast64
thebeast64's Reviews
04-12-2011, 04:27 PM
Price: $149.99
Pros: Sounds amazing, increased throttle response and more torque.
Cons: Hard to install. LOTS of grinding involved.
Recommended? Yes
Comments: I had the infamous cracked manifold problem associated with the 4.0 so I finally pulled the trigger and bought the APN header. It came very quickly and had all of the parts in the box. I took my time labeling everything during the tear down so that everything would go together smoothly. And it did, all except for the intake manifold, which I had to grind around 1/8th of an inch off of the outside of each port in order to get the thing to fit. Oh and DEFINITELY do step 2, even if you feel like you can fit the bolts in after the intake is on....you can't.
T4STE
T4STE's Reviews
01-12-2011, 10:46 PM
Price: $150.00
Pros: price is great. comes with gasket
Cons: some grinding off the intake manifold on some vehicles
Recommended? Yes
Comments: great replacement over stock manifold. some may notice some gains in the ponies
wvpv
wvpv's Reviews
12-07-2010, 07:43 PM
Price: $160.00
Pros: works well, cheap, sounds cool
Cons: Need to modify intake manifold to make it fit
Recommended? Yes
Comments: I installed this on my jeep shortly after buying it. Replaced cracked stock manifold. In order to make it fit I had to grind a hole between #4 and #5 tubes on my intake manifold, also had to grind outside tabs a tiny bit. This header sounds awesome. I can't really compare it to a stock manifold performance wise as my factory one was cracked. If this on breaks I will try the ebay manifold with the expansion tubing.
muttyranks
muttyranks's Reviews
11-09-2010, 07:41 PM
Price: $139.99
Pros: can't beat the price and well made
Cons: bitch to put on...have the grinder handy
Recommended? Yes
Comments: great replacement for the cracked exhaust manifold. not bad to put on, but needed to grind part of the intake manifold for these to fit on my 99 xj.
sounds great with the hi-flow cat and flo-pro exhaust.
mojog
mojog's Reviews
10-20-2010, 10:42 PM
Price: $140.00
Pros: cheap
Cons: none
Recommended? Yes
Comments: Awesome, no more spiff spiff noise from under the hood!
T4STE
T4STE's Reviews
05-03-2010, 08:18 PM
Price: $140.00
Pros: better design, stronger metal, GREAT PRICE
Cons: cant get to my door quick enough
Recommended? Yes
Comments: awesome product for a great price. if you still have the stock manifold, then replace with this immediately
ElGuapoBond
ElGuapoBond's Reviews
12-11-2009, 03:46 AM
Price: $100.00
Pros: Repairable with expansion joints and stainless...
Cons: none
Recommended? Yes
Comments: This is your generic stainless exhaust manifold with expansion joints commonly found on EBAY for a reasonable price and included new gasket and exhaust donut.
DeansWings
DeansWings's Reviews
08-15-2009, 03:17 PM
Price: $225.00
Pros: Sounds real mean. Mildly sharper throttle sponse which a big boost on high end performance
Cons: Pain in the rear to install
Recommended? Yes
Comments: I'm not sure if this header is the one I got, as I got them off ebay. Mine is 1 5/8" stainless steel. The high end performance increase and sound were very obvious. Definitely a good investment, especially since the stock exhaust manifolds are notorious for cracking
fourhiandfly
fourhiandfly's Reviews
07-07-2008, 01:28 PM
Pros: Cheap, looks like Banks reject
Cons: Tight fit, fat ears, tough to get to one stud
Recommended? Yes
Comments: I installed this in April, so far so good! Nice sound Great price! No fabrication needed (by my chinny chin chin). Ears are large and barely mated with intake.
I am very happy so far!!!
ThreadForumRepliesLast Post
Hooker 9403 - Hooker Headers Competition Headers Exhaust 2 11-11-2009 07:33 AM
Borla Headers Exhaust 6 09-15-2009 10:36 AM
Gibson JK Headers Headers 3 08-24-2009 09:04 PM
Gibson XJ headers Exhaust 0 08-17-2008 10:49 PM
Gibson JK Headers Exhaust 0 04-29-2008 11:23 AM
Glock Forum
