Superchips Max MicroTuner for Dodge Gas Trucks
Rating: |
Product Information
| MSRP: |
$350.00 |
| Average Price: |
$293.72 |
| Manufacturer: |
Superchips |
| Recommended? |
Perk up the performance of your Dakota with a performance tune from the Max MicroTuner. The Tuner plugs directly into the diagnostic port under the dash then offers three optimized calibrations to select. Whether you're cruising, towing or off-roading, a Superchips Tuner is the best choice.
Computer Plugs attaches to the computer port under the dash. Quick reprogramming with three different leves plus DTC readings.
KEY FEATURES
Increased Horsepower and Torque
Easy Installation
No Tools Necessary
Improved Fuel Economy
Optimized Driveability
Diagnostic Trouble Code Reading Capability
ADDITIONAL FEATURES
Enhance Shift Firmness
Eliminate Speed Limiter
Recalibrate Speedometer for Larger Tire Sizes
Adjust Rev Limits
Choose from Three Available Performance Settings
PERFORMANCE LEVELS
Performance Tune: 21HP and 19 ft/lbs torque
acgenrich6777's Reviews
Price: $329.00 Pros: It's easy to use, quick on changing over from stock to performance mode and back to gas saver mode. Updates are available by hooking up to computer. Finds fault codes if there are any. Can change the size tire in the programming which helps stay away from speeding tickets and it changes the fuel/air ratio, shift points, and more to meet the size tire on the vehicle. Cons: No Off Road mode. unable to fine tune fuel burn, O2 intake. Recommended? Yes
Comments: I like the Superchip for it's ease in changing over from one mode to another. During the week I keep my Jeep in "stock" mode. During long drives I change over to "gas saver". and on trails I put it to "performance" mode.
vada9's Reviews
Price: $227.00 Pros: Different tunes, Mileage XS, Towing, TPMS thresholds, Tire size comp Cons: none Recommended? Yes
Comments: Same as the pros..great programmer.
rubicon1983's Reviews
Price: $250.00 Pros: wicked orduct no cons Cons: awesome Recommended? Yes
Comments: awesome stuck 20-40 mpg and 22 lbs touque 25 to 30 hp
DAG6ER's Reviews
Price: $400.00 Pros: better gas milage and power Cons: price Recommended? Yes
Comments: Great chip for jeep... The flashpaq works very well in performance and gas milage
Thomahawk's Reviews
Price: $260.00 Pros: Gain in performence, tow settings, different tunes. Cons: dont know yet, recieved it today Recommended? Yes
Comments: good gain in torque and performence, puuls great uphill....
ThaPresident's Reviews
Price: $339.00 Pros: easy and quick power Cons: none, could always be cheaper Recommended? Yes
Comments: good pwer for the money, easy install and almost effortless.
redxj28's Reviews
Price: $300.00 Pros: works great, good increase in power and torque Cons: none Recommended? Yes
Comments: Superchip works great, especially on the high octane setting as long as you run 93.
redneckyoda86's Reviews
Price: $363.00 Pros: Easy to use. If you have any problems just call superchips and they work it out. Cons: Takes abit for the udate program to install on your computer. Recommended? Yes
Comments: I'm very glad that I bought this. I used the milage XS program and it has saved me alot in gas. I did have some trouble with it the first time I did use it. But all I did was called superchips told them what was wrong and they sent it to there techs and had it up and running 1-2 business days.
Z-man246's Reviews
Price: $0.01 Pros: Shift Points, ability to adjust the speedometer
Cons: None Recommended? Yes
Comments: No Comment
djx2005's Reviews
Price: $300.00 Pros: Felt a substantial increase in acceleration and throttle response. Cons: Didn't help gas mileage much. Recommended? Yes
Comments: The chips worth it if you have the extra money to spend. I personally wish that I saved the money and put it towards a lift.
Christ45's Reviews
Price: $335.00 Pros: Added torque, HP, and gass milage. Cons: None yet. Recommended? Yes
Comments: Superchips 3875 Flashpaq Tuner. Have not had enough time with it.
markxj2k's Reviews
Price: $329.00 Pros: Noticeable improvement in engine performance and vehicle drivability. Improved control when off-roading. Able to reprogram speedo for tire size and gear changes. Cons: Slow to use, missing features, no useful documentation Recommended? Yes
Comments: This is the Superchips Flashpaq for Jeep vehicles (no option listed). The sdtandard 87 tune made a big improvement, but the 93 tune (running 93 octane premium gas) is amazing. When I go off-roading I reprogram to the Crawl tune for better throttle control and torque. I also swap my OEM 32" tires for 35" tires when heading to the trails, and the Superchips lets me reprogram my speedometer for the different sizes.
My only complaints are that there are many things this tuner could do, that other devices already do, that Superchips just refuses to consider. But there is no single device that does it all, and Superchips is (currently) the most complete and affordable. Also, their documentation is practically non-existent.
MADGpr's Reviews
Price: $290.00 Pros: Improved engine performance. Cons: None Recommended? Yes
Comments: This product has way more features than I have used, but I bought if to improve the engine performance and it has delivered. I only wish I could purchase the mid-octane gas in order to use the mid-octane tune, but alas it isn't sold here.
mpdiecast's Reviews
Price: $300.00 Pros: Power, multiple programs to choose from, DTC code reader Cons: none Recommended? Yes
Comments: The Superchips Flashpaq Tuner was a good investment. The multiple choice of programs was a nice feature as I usually run on 87 octane fuel. It has programs for towing, 87 octane, 92 octane premium plus a few other user adjustable options. (tire size, gear change etc.) Also has a DTC code reader built in. Easy to install, only takes about 10 minutes while you sit in the drivers seat!
ekpowell's Reviews
Price: $300.00 Pros: Got a good deal off ebay on this Superchips flashpaq for JK Cons: They advertise that it does more than what it really does, but there are continuous updates being made. Recommended? Yes
Comments: Combined with exhause and intake, using the performance tune it does a decent job for minor performance increase. The tire size programming, cooling fan temp settings, transmission shifting improvements for an automatic in the performance tunes, and they just came out with TPMS adjustment are all nice features.
PastorSteve's Reviews
Price: $315.00 Pros: Easy to program and change Cons: none Recommended? Yes
Comments: Again proper choice not available I have the Superchips programmer and love it. It beats all other programmers for the JK hands down.
03wjeep's Reviews
09-02-2008, 09:30 PM |
Recommended? Yes
Comments: I had a Superchip on two of my Ford trucks. One gas 4.6 V8 and one 7.3 diesel, and i loved both of them. One option i like about the one for my jeep, is that like the diesel tuner, it has multiple stages.
jopolly3's Reviews
05-27-2008, 02:42 PM |
Price: $300.00 Recommended? Yes
Comments: By far the easiest way to up the power in a 4.7 its my favorite modification so far...
tjthomps's Reviews
03-12-2008, 11:55 PM |
Price: $350.00 Pros: Flexibility in programming Cons: Costly in my book and failed to diagnose speed sensor DTC Recommended? Yes
Comments: Works great has three programs, regular octain, tow, and high octain performance. I run the high octain (91) until the price of gas gets too high then I simply reprogram my computer for the regular octain program.
Switching programs is as basically as plug and play as you can get. The unit displays the instructions that are simple to follow.
I feel it has added a nice boost to my performance plus gives me DTC readings. However, it did not diagnose the speed sensor failure and I had to pay to have that failure diagnosed. I was not too happy for that.
Note: The unit is VIN locked to the vehicle that you program so there is no multiple use for this unit.
99 WJ Note: There is no spedo adjustment for tire size.
