Go Back JeepForum.com > Reviews > Engine > Chips > JET Performance Accu-Speed
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
JET Performance Accu-Speed Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Chips Next Product
Rating:
Product Information
MSRP: $250.00
Average Price: $187.50
Manufacturer: JET Performance
Recommended?
Yes: 3 / No: 0
The JET Accu-Speed for 93-up Jeeps modifies the vehicle speed sensor output readings to correct the speedometer after making gear ratio or tire size changes. Shift points in automatic transmissions are also corrected. The Accu-Speed connects to the transmission output speed sensor and is calibrated with the turn of a switch.
*The JET Accu-Speed is only available for automatic transmissions.
sdejulia
sdejulia's Reviews
03-31-2008, 09:19 AM
Recommended? Yes
Comments: I just put in a Stage 2 Jet chip and the gains aren't overly impressive but i wasn't expecting much.
EliteDJ02
EliteDJ02's Reviews
03-10-2008, 01:32 PM
Price: $250.00
Recommended? Yes
Comments: Well, I have a four cylinder and I noticed the chip a little but running 87 octane. When I put in 93 it peps up quite a bit. I like it, it helps with my larger tires
PhatJeeps
PhatJeeps's Reviews
08-04-2006, 08:43 PM
Price: $125.00
Pros: Easy installation, much improved drivability with large tires, accurate as proven by GPS!
Cons: It's a little expensive. Should be around $80 or so IMHO
Recommended? Yes
Comments: I was so tired of replacing speedo gears and using a programmer to adjust my shift points just right. The Jet Accu-Speed makes it so easy to get accurate speedometer, odometer, shift points, and even ABS timing again. Anyone can install the Accu-speed. It's that easy and it's a reliable product. I highly recommend it for the enthusiast or avid off-roader.
ThreadForumRepliesLast Post
CRT Performance HEI distributor Chips 2 11-03-2010 06:15 AM
Jet Performance Stage 1 Module Chips 23 09-27-2010 08:54 PM
Mopar Performance Exhaust Exhaust 1 07-07-2009 09:38 PM
CRT Performance HEI distributor Chips 0 02-28-2009 10:16 PM
EMPI Performance 38/38 DEG Carburetors 1 08-11-2008 11:40 PM
Glock Forum
