Hypertech Inc. Max Energy Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Chips Next Product
Rating:
Product Information
MSRP: $420.00
Average Price: $310.20
Manufacturer: Hypertech Inc.
Recommended?
Yes: 15 / No: 1
The Max Energy Power Programmer extracts every bit of energy possible out of every molecule of fuel giving you more mpg at part throttle and more power at wide open throttle. All this and more... Only from Hypertech!
- Maximum Horsepower & Torque
- Improved Fuel Economy
- Internet Updateable (USB included)
- 50-State Emissions Legal·Easy Plug-And-Play Installation
None
banshee06
banshee06's Reviews
12-27-2015, 05:19 PM
Price: $120.00
Pros: easy to use
Cons: better options for reprogramming
Recommended? Yes
Comments: bought it on sale cause it was the only one that I could find that would work for the 4.7l
rulother
rulother's Reviews
06-05-2014, 12:50 PM
Price: $295.00
Pros: MPG went up by 2.5 and you can feel the difference in acceleration and shifting.
Cons: None
Recommended? Yes
Comments: Purchased off AutoAnything.com
60perry
60perry's Reviews
12-07-2012, 05:38 PM
Price: $200.00
Pros: EASY USEAGE
Cons: N/A
Recommended? Yes
Comments: The Max Energy kit was a great investment. I have seen a MPG increase and a power range change for the better. Easy to use and very well worth it.
wes3232
wes3232's Reviews
08-04-2012, 10:09 PM
Price: $299.00
Pros: I just installed this today I will update as I find out more info.
Cons: none yet pricey
Recommended? Yes
Comments: I am trying this out. Not to sure how to take it so far. It worked to calibrate my tire size. I have a 300 mile trip tomorrow so I will update later in the week.
BillyZim
BillyZim's Reviews
07-31-2012, 12:30 AM
Price: $309.00
Pros: Extra mpg's. Better acceleration.
Cons: price.
Recommended? Yes
Comments: Can't go wrong with this.
jragan89
jragan89's Reviews
05-24-2012, 01:52 AM
Price: $350.00
Pros: noticeable power increase, more MPG if you have a light foot
Cons: none
Recommended? Yes
Comments: if you want the best product, buy the MAX ENERGY, and not the ECON. the ECON in the same tuner but without the "extra" stuff. i.e. speedo calibrator, tranny mod, ect. the econ is a single option tuner that gives you more power and better MPG if you dont floor it
AZJeeper2
AZJeeper2's Reviews
12-28-2011, 10:28 AM
Price: $370.00
Pros: Great new features Tune works well
Cons: Like most competitors, need to plug in to access some new features
Recommended? Yes
Comments: This review is for the beta version with the new features for the 2007-2010 JK. There are a maze of new options. Not too difficult to navigate once you get used to them.
DTCS: Get right to reading and clearing!
Preferences: A couple of nice options for English/Metric units, and for wrapping menus.
Engine Tuning: Same as before - Stock, Regular, and Premium tunes
Top Speed: Not real exciting, but functional. You can set your top speed to match your tires up to ZR (way faster than the Jeep could do in a free-fall).
Rev Limit: I haven't found a use for this feature.
Thermostat: Just like before.
Idle RPM: Three options: 4LO, Normal, and Winch.
4LO allows you to set the default idle speed when you are crawling. I set mine up a bit to get it closer to the TC stall speed.
Normal is for the default idle. Don't see much reason to mess with that setting.
Winch - if I could give three thumbs up, I would! This works great with the PowerPlant winch, even in compressor mode! Nice to have the Jeep automatically go to 1600 RPM (or whatever you want to set it to) when there's an electrical load on the engine.
Throttle body: The Viper TB is too close to voodoo magic for my tastes, but if you believe in it the tune should help your "limp mode" issues.
Throttle response: This is another really cool feature. You can chose the "Hypertech" suggested defaults or tune to your liking. WAY nicer driving with just a little tweaking. This option could keep me busy for a very long time fine-tuning since there are so many options to choose from.
TPMS: I've been waiting a very long time for this option! Set mine to 10 PSI. I run between 12-15 PSI when on the trail. This should tell me if a popped a bead (wish I had beadlocks, but that's for the future).
Two qwerks with the TPMS setting I discovered:
I had a low tire before I started (TPMS light on). No matter how I set the option, the light would not go out. I put back the factory tune and aired up all of the tires so the light went out. Now it seems to work great. So, be sure you are starting out "clean" before selecting this option. BTW - the lowest setting is 2 PSI. Would be nice to have "Disable" as an option.
Setting the TPMS to a different threshold doesn't give me the "Install Tuning" option. If I select another option it comes up. A bug, maybe?
Tire Size: Same as before.
Axle Ratio: Same as before.
Vehicle Options: Need to plug in the tuner and have the engine running for these to work. Not practical for me to have the tuner in the vehicle at all times, especially when wheeling. The plug gets in the way. It's not a low-profile plug like the Aeroforce gauge (which I prefer to leave plugged in). It looks like the lockers all engage - no option for "front dig". It would be far better if the options could be worked into the existing switches. Maybe that's not possible. I won't be using this option often, if at all.
Overall I'm very pleased with the new features.
SCOUTGC26
SCOUTGC26's Reviews
12-22-2011, 08:40 PM
Price: $350.00
Pros: Allows Tuning with 2 settings. Premium and Regular. Also reads and clears codes, allows for adjustments when changing tire size and gear ratio.
Cons: none so far
Recommended? Yes
Comments: Installed this product right after purchasing my 2006 WK with the 4.7L and QDII. Didnt have to much time with the stock settings but with the tune i can already tell the difference between stock and upgraded. Throttle response is much better. Shift points also feel smoother. I have noticed a small difference in sound at idle as well. Would def. recommend for anyone looking to improve power, throttle response, and MPGs.
percichm
percichm's Reviews
08-08-2009, 03:24 AM
Price: $220.00
Pros: Added about 2 mpg and a little top end hp
Cons: Not a ton of adjustments you can make.
Recommended? Yes
Comments: I think that the hypertech max energy is a good product if you can find it for the right price. I was able to find one for $220, so I think it was a good deal. I did see them for $350-400, if it cost that much, it would probably not be worth it.
MelloYello32
MelloYello32's Reviews
06-16-2009, 09:42 PM
Price: $325.00
Pros: better gas mileage and hp
Cons: pricey
Recommended? Yes
Comments: mild effects seen.
RAISEDUPRUBI
RAISEDUPRUBI's Reviews
05-22-2009, 06:11 PM
Price: $280.00
Pros: recalibrated everything perfect. Has adjustment for tires,gears, and sport ot normal tune. Also set your shift points to optimize your shift points in an auto based on your mods. Perfect Calibration
Cons: none yet
Recommended? Yes
Comments: Does what it claims to do and does it well. It tyrned my Rubi into running at its max potential with what I got. Couldnt be happier. Easy to do as well. 25 min and your back on the road....
98sarXJ
98sarXJ's Reviews
04-03-2009, 05:52 AM
Pros: slight power increase above 3,000 on 91 octane
Cons: high cost and very few options for a xj
Recommended? No
Comments: bought for a 98 xj. it only has changes for red line, top speed, and regular and premium fuel program. i didn't notice much increase in power, and almost none below 3,000rpm.
pingdat
pingdat's Reviews
11-06-2008, 09:12 PM
Price: $420.00
Recommended? Yes
Comments: Decent product, for power the only thing I noticed was a little better throttle response but it is giving me about 2 MPG more.
HemiTrix
HemiTrix's Reviews
10-01-2008, 09:21 AM
Price: $375.00
Recommended? Yes
Comments: First bought the hyperpac through AutoAnything, it was defective and wiped my ecu. Had to tow to the dealer to reflash my computer. Then bought the MaxEnergy from Advance Auto, using the 91 octane tune, slight increase in MPG, nice power increase.
copperRR
copperRR's Reviews
09-08-2008, 08:14 AM
Price: $379.00
Recommended? Yes
Comments: quick and easy all kind of diffrent settings and makes more power and torque.
tgrt
tgrt's Reviews
05-01-2008, 10:52 AM
Price: $360.99
Recommended? Yes
Comments: Although I didn't notice the power boost with regular fuel I did notice significant improvement in throttle response and smoother shifting. There may be a mileage benefit, but I haven't had it installed long enough to know. I bought the programmer primarly to program my speedometer when I get the larger tires and gears installed.
ThreadForumRepliesLast Post
Hypertech Inc. Dodge Power Programmer III Chips 5 05-17-2015 10:11 PM
