Edge Products Trail Jammer 2005-2006 TJ ETJ4005 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Chips Next Product
Rating:
Product Information
MSRP: $750.00
Average Price: $498.68
Manufacturer: Edge Products Trail Jammer 2005-2006 TJ
Recommended?
Yes: 14 / No: 1
Well this weekend I installed the Edge Products Trail Jammer kit in my 2005. I did not do their intake, being I had my own built already.
The install was very straight forward, took about 30 minutes. They supplied the torx needed. After installed I reconnected the negative terminal and started her up. Idle was just fine. So I let her idle for about 10 minutes and took it around the block. It had amazing throttle response. I did have to adjust the throttle body due it closing a bit too much. When you hit the gas it kinda stuck closed. It is just a 3/16" allen key. Now there is no hang up.
Today I drove it about 50 miles. Off the line on the highway you can definately feel the response and added torque. It does pull better at lower rpm ranges, before I was downshifting alot.
Being I only have 55 miles on it I can not tell you about fuel gains or loses. According to Edge I should see an improvement.
Will post updates in a month or so after a few tanks of gas. Being it is not my DD, takes awhile to use a tank of gas.
None
mahoot207
mahoot207's Reviews
11-12-2009, 11:14 AM
Price: $440.00
Pros: Excellent responsiveness on throttle, extra HP and torque definately noticed
Cons: Check engine light occassionally, some whistling/vacuum noise occassionally
Recommended? Yes
Comments: I put this in about 6 monts ago and I have DEFINATELY noticed a difference in my Jeeps performance. I did notice that my check engine light would come on for a few days, then go off and it would do this occassionally. I hooked it up to the computer and apparently having the wider throttle body set off the O2 sensors for awhile. I haven't had any problems since though and the check engine light has been off. Also, there is a slight whistle sound/vacuum noise that is noticeable when you first start the engine, but does go away after driving a couple of miles - engine warms up.
oj707
oj707's Reviews
10-26-2009, 05:57 PM
Price: $400.00
Pros: quicker acceleration. a little better fuel milage
Cons: waaaaaaaaaaaaaaay too expensive for what you get. its a gaser!! dont put a chip on it!
Recommended? No
Comments: its pretty cool, but dont, too much money for like 30 hp
valacech
valacech's Reviews
09-15-2009, 11:46 AM
Price: $400.00
Pros: Improved highway mileage, throttle response and torque way up.
Cons: Pricey.
Recommended? Yes
Comments: It woke my 4.0 up. The combination of the edge trail jammer system (chip and throttle body w/ spacer), borla headers, borla catback and AEM bruteforce intake, she really woke up. It sounds unreal and has way more power than factory. The thing just breathes so much better and my highway mileage is up by about 3mpg. Not really worth it from a gas mileage standpoint, but totally worth it in terms of the power gains. Sick!
Ram4whldr
Ram4whldr's Reviews
06-06-2009, 07:22 PM
Price: $679.20
Pros: Quick and easy install.
Cons: none
Recommended? Yes
Comments: Just installed the entire package on Thursday. Added significant power. Can really feel it. I am guessing they fixed the whistling problem. Mine only whistles upon startup and goes away once vehicle is warmed up. Another bonus is since I am an Edge dealer I got the product at cost! If anyone needs one at a great price let me know!
jason0923
jason0923's Reviews
03-11-2009, 11:54 PM
Price: $650.00
Recommended? Yes
Comments: GOT THE WHOLE KIT FIGURED STAYING THE SAME NAME BRAND MIGHT EVEN HELP A LITTLE MORE. INSTALL IS A CAKE WALK AND TIMELESS. GREAT PRODUCT AND NOTICEABLE IMPROVEMENTS BUT THERE IS A LOUD WHISTLING. PAY TO PLAY
05jeeper
05jeeper's Reviews
12-18-2008, 11:31 PM
Price: $365.00
Recommended? Yes
Comments: Huge difference in power. No fuel savings, easy to instal. Great customer service. Factory replaced post warranty without questions.
goodnuff_17
goodnuff_17's Reviews
12-12-2008, 06:28 AM
Price: $500.00
Recommended? Yes
Comments: Really good low end torque and throttle responce. It was a simple 30 minute hook up.
Barton805
Barton805's Reviews
11-03-2008, 03:19 AM
Price: $600.00
Recommended? Yes
Comments: Night and day difference. Great impact to get up and go. Combined with the exhaust its a must have.
J_Thack
J_Thack's Reviews
10-13-2008, 07:07 PM
Price: $375.00
Recommended? Yes
Comments: The larger throttle body made my air intake sound like a hoover, it was kinda cool at first but I'm over it now. Whenever I let off the throttle it sounds like I have a blow off valve. The throttle response is a lot better over stock. As for performance, there is a difference but I added a cat-back at the same time so its not fair to say how much improvement I gained. The best part was about a 2 mpg improvement!
rubiconbill
rubiconbill's Reviews
10-06-2008, 11:33 PM
Price: $400.00
Recommended? Yes
Comments: this programmer is good for 20% increase in HP across the board. I am using it with the edge Throttlebody and a AEM spacer and AEM brute force intake. Expect a high pitched whistle from the IAC in the throttlebody, If you hone the edges down, it reduces the whine.
RubiCrawler_LJ
RubiCrawler_LJ's Reviews
08-11-2008, 08:34 AM
Price: $425.99
Recommended? Yes
Comments: Best money sent in HP modification. I even got back some MPG if I modulate the "skinny pedal" correctly.
Blackedoutrubi
Blackedoutrubi's Reviews
05-14-2008, 12:49 AM
Price: $750.00
Recommended? Yes
Comments: gives the jeep plenty of power to push though thing and not hesitate on the road either
HeiserM
HeiserM's Reviews
04-12-2008, 11:13 AM
Price: $495.00
Recommended? Yes
Comments: Big improvement in throttle response! Buy one now! Peice of cake install!!! Also picked up the edge throttle body!
Postal
Postal's Reviews
04-12-2008, 10:35 AM
Price: $600.00
Recommended? Yes
Comments: Easy install. Cold air intake, chip and 62mm throttle body. CAI has a nice gurgle to it at idle. Seat of the pants response is fantastic. Stop to 60 improved. Throttle response improved throughout. I think I will really get the benefit of this product when I replace the stock exhaust system and maybe some headers.
Rocky5
Rocky5's Reviews
04-09-2008, 11:37 PM
Price: $400.00
Recommended? Yes
Comments: love it! noise takes some getting used to!
ThreadForumRepliesLast Post
Edge Trail Jammer 62mm Throttle Body 25 08-03-2016 08:11 PM
Edge Jeep Trailjammer - 1997-2002 Wrangler Module, Throttle Body with Intake Chips 15 07-22-2012 07:11 PM
Edge Products Trail Jammer 2005-2006 TJ ETJ4005 Chips 8 05-04-2011 10:50 AM
Edge Jeep Liberty TrailJammer Module - 2005-2006 Jeep Liberty CRD EZ Module Chips 1 02-06-2008 09:06 AM
