Magnaflow High flow catalytic converter
Rating: |
Product Information
| MSRP: |
$150.00 |
| Average Price: |
$110.53 |
| Manufacturer: |
Magnaflow |
| Recommended? |
ThomasYJ's Reviews
Price: $100.00 Pros: High flow(allegedly)
stainless steel Cons: none Recommended? Yes
Comments: Seems like a pretty well made product. Got it to replace my factory one which was shot to hell. Price was pretty reasonable and a better choice than the $300 Random Tech cat I was looking at. I'd buy it again if I needed to.
05midnite's Reviews
Price: $4.00 Pros: cleaner and louder sound Cons: painful installation Recommended? Yes
Comments: great clean sound works great
DasFrettchen's Reviews
Price: $130.00 Pros: Relatively cheap, solid construction, bolt in application Cons: none Recommended? Yes
Comments: Works great, purchased to replace my stock cat that was falling apart at 124,000 miles. Would have bolted right into place if not for the fact that the pipe coming out of the cat going to the muffler is 2 1/4", but I have a custom cat-back using 2 1/2" pipe so I had to get an adapter. If you are using a Magnaflow cat-back or any muffler that will fit directly onto 2 1/4" pipe then it will all match up fine.
04wjBMR's Reviews
Price: $450.00 Pros: improved power, and fuel mileage Cons: no complaints Recommended? Yes
Comments: very nice product sounds awesome and definitely upped my power.
mmaibachjr's Reviews
Price: $200.00 Pros: Looks amazing, definitely increases flow Cons: none Recommended? Yes
Comments: Looks absolutely awesome under there. Stainless steel turned purple and colored after getting hot, looks real neat. Sounds nice, motor definitely runs cleaner and increase in power, better gas mileage too. Very easy to install.
I bought this with a Dynomax catback, and this kit came with the hi-flow cat as well as the downpipe. So i replaced my entire exhaust system at once (made it much easier. Get the whole thing in place (loosely), then position it as desired and tighten it down.
excellent product.
greenone's Reviews
Price: $1.00 Pros: High flow Cons: Problem passing CA smog in first gear (had to start in 2nd gear). Recommended? Yes
Comments: I got this as a replacement when my stocker went south. Has been good to me so far!
knightwolf654's Reviews
Price: $119.00 Pros: stainless steel, high flow Cons: upstream 02 sensor threads got screwed up from improperly tapped hole. Recommended? Yes
Comments: this system went in with not to much effort. had to cut the original cat and down pipe out with a saws-all since all the bolts were rusted in. went to put the 02 sensor into the upstream hole and ended up striping the threads on the 02 sensor. after i re-tapped the hole and replaced the 02 sensor it works fine now.
countrybuck's Reviews
Price: $80.00 Pros: Able to breathe Cons: none Recommended? Yes
Comments: Opened up exhaust to allow my jeep to breathe and also allows for a nice sound.
filippelli's Reviews
Price: $1.00 Pros: it was free and a high flow Cons: nothing yet Recommended? Yes
Comments: so far so good i crushed my stock one and got a good deal on this one
CorporalMojo's Reviews
Price: $92.00 Pros: Direct Fit, Stainless Steel Cons: None Recommended? Yes
Comments: Quality product. Works great.
JasonZ's Reviews
Price: $204.00 Pros: With my catback system, noticeable horsepower and torque increase. 50 state legal according to Magnaflow Cons: With my catback system, I lost gas mileage intil I added an intake. Recommended? Yes
Comments: The old exhaust was a pain to remove but the new one bolted right on in under an hour. When I first put it on I lost significant gas mileage. I also kept getting a trouble code for the rear O2 sensor which I replaced with the exhaust. I added a cold air intake and took the jeep in to have the trouble code checked because I didn't think my brand new O2 sensor would be sending the error. The shop replaced it with one from Jeep. So now, the trouble code is gone and I am back to factory gas mileage with extra power and great sound.
dukie564's Reviews
Price: $130.00 Pros: better flow and sound Cons: none - got me to pass the emissions fine Recommended? Yes
Comments: it even helped with the sound. Added it alongside a flowmaster super 40 muffler and custom 2.5" mandrel bent tailpipe
vicmorris's Reviews
Price: $139.00 Pros: easy installation Cons: none Recommended? Yes
Comments: wanted to upgrade cat so I bought this one
keaton's Reviews
Price: $200.00 Pros: Loud, flows good Cons: None. Recommended? Yes
Comments: Had my local exhaust shop install it after my old cat exploded. Was about 200 with the install. Added about 23.675 horzpowerzzz haha. JK but it makes the jeep sound sick and adds that 'jeep rasp' coupled with a fm 44. I like it.
ROADDOG516's Reviews
Price: $79.99 Pros: very solid construction Cons: not direct fit in my case had to cut 2" from outlet pipe Recommended? Yes
Comments: Just an FYI to fellow 4bangers but I just replaced my stock cat (what I thought was stock), with a Magnaflow HP cat, and felt a noticable increase in throttle response. I say stock cat because thats what I thought it was, it was even welded on the manifold pipe and looked like factory weld not aftermarket, but when I brought my cat to the scrap yard the guy told me the one I removed was definately a aftermarket, possibly a factory warrantied one, so all I got was 4 bucks for it. PS he even showed me the differanvce between stock and aftermarket so no I dont think I was dupped.. But who cares it was $ more dollars than throwing it the can. Anyways I would recomend the cat to anyone who thinks they may have a worn out cat. I can now use fifth gear on the highway again which couldnt do since the lift/tires. It even sounds as meaty as a 4 slugger can...
sp33dracerman's Reviews
02-05-2010, 10:49 AM |
Price: $99.00 Pros: cheap
easy to install
sounds good
adds power Cons: warranty is only 6 months
ugly welds
discolors metal fast Recommended? Yes
Comments: I got my cat from magnaflow direct and they told me all about how great their universal would be. They only problem was they did not mention the 6 month warranty thing they led me to believe it was lifetime....it was not. However any lage diameter high flow magnaflow catalytic converter is a very cost effective solution to cat problems
ElGuapoBond's Reviews
Price: $110.00 Pros: Great product came with the header pipe. Easy to install and was a direct fit. I coupled this with a Flowmaster Super 44 Offroad. Cons: None that I can see other than I painted it for corrosion resistance. Recommended? Yes
Comments: Great product for the price, also came with the header pipe and was easy to install.
mxboarder17's Reviews
08-22-2009, 08:05 PM |
Price: $113.00 Pros: Easy Install! Cons: None Recommended? Yes
Comments: Compliments my Dynomax Super Turbo muffler and tail pipe! I think without this converter I would not have the nice rumble I get when I step on it! Very pleased with this product!
DeansWings's Reviews
Price: $115.00 Pros: Increase in volume. Mild increase in performance Cons: Meh Recommended? Yes
Comments: A less noticable mod in my case. The zj perked up a bit and sounded off a bit, but thats about it. I don't regret it, but I dont brag about it.
