Notices
Catco Direct-fit Catalytic Converter for Cherokees Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Exhaust Next Product
Rating:
Product Information
MSRP: $99.39
Average Price: $69.68
Manufacturer: Catco
Recommended?
Yes: 5 / No: 0
Since you have to use a catalytic converter anyhow, you might as well use one that will last a long time, and maintain your vehicle's performance level in the process. Catco direct-fit catalytic converters not only outflow stock converters, but they also feature aluminized steel heat shields (many have dual shields), 409 stainless steel shells, 16-gauge stainless steel pipes and nipples, and a heat-resistant sealed mat, all of which help them last longer. These units are direct replacements for OE converters and will install with little or no modification. Some converters have steel air tubes with perforated holes to help distribute the airflow evenly, without robbing power. New flanges are included when necessary.
None
cfmiller58
cfmiller58's Reviews
11-23-2009, 12:28 AM
Price: $55.00
Pros: easy replacement for a bad stock converter
Cons: none noted
Recommended? Yes
Comments: easy replacement for a bad stock converter. increased exaust flow
ZJBallin07
ZJBallin07's Reviews
05-15-2008, 11:21 AM
Price: $49.00
Recommended? Yes
Comments: increase in sound if ya have a performance muffler.
great power and torque increase as well as increased gas mileage
88XJSport
88XJSport's Reviews
04-11-2008, 10:04 AM
Price: $70.00
Recommended? Yes
Comments: Compact design is perfect for my XJ.
itasor
itasor's Reviews
04-08-2008, 10:25 PM
Price: $75.00
Recommended? Yes
Comments: Cheap, quality converter that can be installed with simply exhaust clamps on a stock system. A little louder than stock. I noticed a bit more power with this installed in an otherwise stock exhaust system.
PhatJeeps
PhatJeeps's Reviews
08-04-2006, 09:29 PM
Price: $99.39
Pros: Easy installation and improved torque/hp
Cons: None to speak of.
Recommended? Yes
Comments: These are some of the best priced converters available for the Jeep Cherokee. Direct-Fit means just that, nothing special is required to install. I HIGHLY recommend replacing O2 sensors and using a liberal amount of anti-seize compound on the threads too! Welded on in under 15 minutes. Easy peasy!
ThreadForumRepliesLast Post
Magnaflow High flow catalytic converter Exhaust 45 09-19-2013 04:37 PM
Magnaflow Car Sound High Flow Catalytic Converter Exhaust 6 03-23-2012 09:57 PM
Magnaflow 3" y-back exhaust 14" muffler, Car Sound Catalytic Converter Exhaust 3 03-23-2010 12:13 PM
Random Technology High Flow Catalytic Converter Exhaust 2 12-10-2008 04:41 AM
