Banks Header Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Exhaust Next Product
Banks Header
Rating:
Product Information
Average Price: $420.75
Manufacturer: Banks
Recommended?
Yes: 7 / No: 1
Will install upon receipt of block and head back from Hesco.
None
Willtallica
Willtallica's Reviews
11-13-2015, 06:30 PM
Price: $380.00
Pros: Good flow helps the engine breath
Cons: None
Recommended? Yes
Comments: Excellent product and so much better then the stock exhaust manifold
vernmc530
vernmc530's Reviews
11-30-2012, 03:51 AM
Price: $350.00
Pros: excellent response!
Cons: not known
Recommended? Yes
Comments: defined notice in HP, and throttle response! runs nice
smotrs
smotrs's Reviews
05-21-2011, 12:14 PM
Price: $240.00
Pros: Price was definitely right
Cons: None to date
Recommended? Yes
Comments: Header was installed by Banks along with complete exhaust system. This is a real header in that all downpipes are the same length before the coupler. Finish (silver) is holding up really well and I expect it to hold up for quite some time. Header was normally about $480 but they had stock they were wanting to get rid of which went for 50% off.
TheSlowDown
TheSlowDown's Reviews
01-08-2011, 01:01 AM
Price: $1,100.00
Pros: Nice design, mostly spotless welds, nice increase in airflow.
Cons: Too expensive for what you get. Gets a bit hot underfoot inside the cab from the heat generated by the header.
Recommended? No
Comments: Tough one - yes there is a difference in throttle response, in horsepower, in fuel economy, BUT ONLY AFTER YOU INSTALL ALL RELATED COMPONENTS. I bought the Banks "power pack" which includes the header, the intake, and the exhaust.
I put the intake on 1st for a couple of months. All I noticed was a huge sucking sounds when I stepped on the gas - nothing else.
Then I installed the exhaust. It made a bit of a difference now as the sucking sound from the intake was reduced and throttle was more responsive and the "butt dyno" was awakened from the typical Jeep slumber.
Then a few months later I installed the header. My holey cow, what a difference. Sucking sound from intake: GONE. increased power, increased throttle response, increase MPH, increased guttural exhaust note = ALL THERE.
Still, was it worth $1100 total? NO.... but... now with *hopefully* the supercharger coming in it the airflow can be used up to it's potential.
k1lr0y
k1lr0y's Reviews
11-29-2010, 12:08 PM
Price: $425.00
Pros: solid piece, the performance gains of increased torque and horsepower compared with the OEM exhaust manifold.
Cons: time-consuming part of the install was the removal and installation of the intake manifold assembly.
Recommended? Yes
Comments: I bought my '97 TJ with a cracked exhaust manifold. As this is a DD for me, this was the first of a couple of necessary fixes to perform.
I didn't have the time/place to perform the replacement myself so I took it to the local Jeep dealership.
The sound is deeper, and the increase in torque & power was immediately noticeable.
Jeep-AI
Jeep-AI's Reviews
12-04-2009, 12:47 AM
Price: $1.00
Pros: .
Cons: .
Recommended? Yes
Comments: ....................
YJWarrior
YJWarrior's Reviews
11-22-2009, 03:11 PM
Price: $375.00
Pros: Improved performance Lifetime warrenty
Cons: Expensive
Recommended? Yes
Comments: My header was cracked so I needed to replace it. I took my YJ to "Four To Go" service and repair and the price installed was slightly less than the Dealership quoted me but included a much better header for life!
The team there is awesome!
I did notice improved gas milage and performance although I bough the YJ used so I'm not sure what it was like prior to the cracked header.
blackdragonfish
blackdragonfish's Reviews
07-11-2009, 01:39 AM
Price: $495.00
Pros: Lifetime Warranty
Cons: Pricey
Recommended? Yes
Comments: This is a part you will eventually need. Unfortunately the Original Exhaust Manifold on your Jeep will crack. Cars just aren't made like they used to be. I recommend Banks because theirs is backed with a lifetime warranty. Now I was able to Install this product myself but it was no walk in the park. Would not recommend installing on your own unless, like me, you have some background in taking apart engines. If your experience is anything like mine this will take you a good piece of your day and the tools you used to take the old Exhaust Manifold off, example 3/8 socket wrench, will not fit with the new manifold. So have some ratcheting wrenches on hand your going to need them. Also remember all these bolts have exact torque requirements that must be followed or warranties could be voided.
ThreadForumRepliesLast Post
Banks Cat-Back MONSTER Exhaust 27 04-29-2017 10:28 AM
Banks Ram-Air Intake System Induction 44 04-29-2017 10:27 AM
Banks Monster Exhaust Exhaust 113 08-03-2016 07:13 PM
Banks Banks Ram Air Intake Induction 35 04-22-2014 11:31 PM
Banks Torque Tube header and Cat Back Exhaust 12 10-23-2011 11:47 AM
