your typical 1 ton XJ build thread - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > your typical 1 ton XJ build thread
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Looking to re-gear?! CRAZY DEALS ON YUKON GEARS right here
Unread 12-01-2013, 02:19 AM   #1
Atmos
1993 XJ Cherokee
just got done beating my last xj build to death. D30 and no cage isn't gonna cut it. time to start over
the canvas for this project is a 1994 XJ / AW4 / np231
plans:
1 tons
3 link coils/leafs for now
cage
frame plates
hydro assist
37's for now
flat belly/ clocked 231
Atmos is offline   Reply With Quote
Unread 12-01-2013, 10:21 AM   #2
Atmos
1993 XJ Cherokee
pulled the jeep into it's resting place for the next few months. the rear seemed like a good place to start
went in to ruffstuff and grabbed some mid stiffeners to add to my HDO front/rear
then started tucking the gas tank. got the fitment perfect just need to pick up some steel today and box the floor in and bolt it down
if anyone is wondering, the size for the hole you need to cut is
31.75" across
19.25" vertical
and I did mine 1" away from the plastic piece surrounding the hatch latch
Unread 12-01-2013, 10:39 AM   #3
Atmos
1993 XJ Cherokee
went down to Fresno to pick up some axles from Robert. he was running them in his ultra4 Cherokee so they are ready to bolt-in
the width on these is about 67" and I plan to run a 5" back space wheel
rear 14 bolt
ballistic shave kit
T&T truss
full spool
5.38's
disc brakes
pinion guard
30 spline chromos
ubolt elim
front HP D60 from currie
Yukon grizzly locker
35 spline inner/outer
super joints
Yukon lockouts
5.38's
deadenbear kingpin C's/ stock ford knuckles
parts mike high steer arms
he even threw in the tie rod, drag link, and a ram
Unread 12-03-2013, 01:42 AM   #4
Atmos
1993 XJ Cherokee
well I thought for a good while on how to neatly secure the tank. decided to reuse the stock straps. started by bending them back and made a cut in order to shorten. just gotta make a tab so they can swing back. they will bolt down on the front side
here's my simple box for the tank. I think I'm going to fully weld it in. then put a 3/16" thick weatherseal inbetween the box and the tank so it seals tightly when bolted down.
and unfortunately that's it for awhile. my buddy is unavailable for the next 2 weeks on work and it's his shop
next up:
rear frame plates
gas tank skid
relocate leaf springs
and maybe pick up these rollers http://yubasutter.craigslist.org/pts/4214852649.html
oh yeah my lazy *** also ordered this clocking jig http://www.ironrockoffroad.com/Merch...tegory_Code=UP
Unread 12-03-2013, 11:37 PM   #5
Atmos
1993 XJ Cherokee
welp. I did get the H2's. set of 4 professionally powder coated. $250
and they even came with some rollers! 5.38's on 33's sure are going to be a hoot
Unread 12-04-2013, 12:32 AM   #6
MrSundays
Raptor Jesus
MrSundays's Avatar
This thing is going to be a monster. You need to put a bigger motor in it
Build thread coming soon
MrSundays is offline   Reply With Quote
Unread 12-04-2013, 01:46 AM   #7
Atmos
1993 XJ Cherokee
shhhh let me get it on the ground for now. engine comes next year
Unread 02-10-2014, 02:01 AM   #8
Atmos
1993 XJ Cherokee
guess this deserves an update. should I move this to the Cherokee section?
frame plates
more plates and making some room for rock sliders
Unread 02-10-2014, 02:03 AM   #9
Atmos
1993 XJ Cherokee
leaf hangers
rear axle in there
Unread 02-10-2014, 02:12 AM   #10
Atmos
1993 XJ Cherokee
clocking jig from IRO. tcase was clocked 11 degrees
here's a picture of the drilling
works much better with an SYE
Unread 02-10-2014, 02:23 AM   #11
MurdaJs
Is the city of trees irvine?
Oh yeah, nice jeep :haha:
Built one piece at a time, and it cost me many dimes
MurdaJs is offline   Reply With Quote
Unread 02-10-2014, 02:29 AM   #12
Atmos
1993 XJ Cherokee
Sacramento http://www.moneymatters101.com/travel/picts/ca/sac2.asp
actually I don't live there either. I live about 20 miles east of Sac
Unread 02-11-2014, 11:42 AM   #13
Atmos
1993 XJ Cherokee
front frame plates
