YJ RUSToration - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > YJ RUSToration
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-11-2012, 05:39 PM   #1
parkerm26
YJ RUSToration
As some may know, I started a 1 ton swap thread here: Another 1 Ton YJ I Guess
Well as I was building these axles, things got a little involved... and expensive. Just Empty Every Pocket right?
I am now doing a restoration on my jeep. I bought a frame to replace my patched/rusted/cracking frame and had it hot dipped in galvy
Pretty excited about it now. I'm determined to have a reliable, capable, rust free jeep. This is just the beginning. hoping to put a motor in it next year. Ideas being: 4.6 Stroker I6, Cummins 4BT with some goodies, or a 350 stroked to 383.
I put the rebuilt Dana 60 on the springs and mocked it under the frame. Next week I will be taking my jeep apart for the shackles, bushings, and 2 of the springs to complete the suspension on the chassis. Still waiting on the rear to come back from the gear shop.
Frame and the Dana 60 waiting for shackles. the frame is not at its final height yet.
From the rear...
New Daystar poly frame-to-shackle bushings front and rear...
More progress to come later in the week!
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2012, 06:07 PM   #2
parkerm26
got the motor pulled yesterday. what a task... the body and frame are on my trailer. going to cut the body mount bolts tomorrow and hopefully pull the sucker off, pressure wash the bottom, then POR15 the bottom of the body and firewall. I'm also going to POR15 the skid plate and the gas tank skid as well as some other misc. parts.
I still have to degrease the motor and possibly paint it. then i have to weld the cracked manifold and weld up the new 2.5in exhaust system. Finally i will have an exhaust with NO leaks!
Here is the motor in. BTW that is not my pinion angle; its not weled yet it just spun on me yesterday. More pics to come.
Unread 02-25-2012, 06:40 AM   #3
imcfarland93
I got really excited when I saw your thread. I can tell this is going to be a build done right. I'm gonna keep a close eye on this one. Check out my YJ build thread if u want. Her name is Sarah
My Build Thread:
[url]http://www.jeepforum.com/forum/f22/ians-1993-jeep-wrangler-yj-sarah-1225169/[/url]
imcfarland93 is offline   Reply With Quote Quick reply to this message
Unread 02-25-2012, 10:50 AM   #4
SnowYJ
1988 MJ Comanche
mmmm, looks like it's gonna be big man
I go to college and I drive a Jeep.
SnowYJ is offline   Reply With Quote Quick reply to this message
Unread 02-28-2012, 05:09 PM   #5
parkerm26
Cutting the body off this weekend. Then drilling out the remaining peices of bolts and re-tapping the holes. Going to POR the body underside, crossmember, and gas tank skid. Also still have to weld up the new exhaust and run new hard brake lines.
Got a new set of doors with no rust or rot. going to weld the window hoop/door seams and have them painted to match. new set of gaskets and whatnot are on the way soon for both doors.
Ordered new O2 sensor, CPS sensor, coolant overflow bottle, and dip stick tube.
UP FOR SALE: PM an offer if interested. Local pick-up only.
-(4) 33x10.5x15 Toyo Open Country Mud Terrains (~50% tread)
-15x8 American Racing Baja Rims with or without the tires above. 4.5 on 5 Lug pattern
-Set YJ doors. Red, may not include interior panels. No surface rust, Typical rot at exterior panel/window hoop area an Drivers door. All windows fully functional.
-Stock axles, D35 and D30. 3.07 gears, open, no mods. Calipers, rotors, drums included. Front needs u-joints, rear needs shoes.
Unread 03-02-2012, 09:34 PM   #6
littleblackjeep
Project looks good so far. What springs/suspension are you going to go with? I just picked up my D60's last weekend for a build for my girlfriend.
Here's that thread: http://www.jeepforum.com/forum/f22/m...riend-1327158/
littleblackjeep is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 06:23 AM   #7
parkerm26
I didn't really have the money for new springs so i used my existing 4in rough country springs in the back with the smallest leaf taken out in the rear. I had a replacement pair from rough country so i took the same leaf out of those and used them for the front. both are sprung-over with 1 inch shackles and all new poly bushings. I figure its about 9-10 inches of lift.
When I have some more money after i stop paying for school i'm going to upgrade to a BDS 2-3.5 inch spring.
Unread 03-04-2012, 01:19 PM   #8
parkerm26
Progress: Got the body off. haven't drilled the old bolts out though. got the gas tank and skid off and moveed the fuel lines over (they look like they're in good shape). The gas tank skid was in pretty rough shape so a new one is getting ordered tomorrow along with new straps. I got the trans skid and fuel filter mount painted with POR-15. Going to install them tonight. New fuel filter also. The old one poured out black gas haha
Unread 03-09-2012, 12:08 AM   #9
parkerm26
Just uploaded some old pictures before I got the rolling chasis together. These are from about 2 months ago
Unread 03-16-2012, 05:27 PM   #10
parkerm26
and with the body finally on with a 1 inch daystar full body mount replacement. These are a few of my buddies. took 5 of us to get it on.
Unread 03-16-2012, 10:03 PM   #11
2jeeps1stang
1987 YJ Wrangler
subscribed
87 yj wrangler, 4.0, lifted, 33s. Slowly taking jeep 'roids.
75 cj5 304, Fiberglassed, 4:56, lift, 35s
73 cj5 built 401
2jeeps1stang is offline   Reply With Quote Quick reply to this message
Unread 03-19-2012, 07:56 AM   #12
parkerm26
Got the E-350 master cylinder fully bench bled and installed, most hard brake lines installed, all new 12 inch braided brake lines installed, and OBA hooked back up.
Only things left to do:
-Flare + install passenger side rear axle hard brake line
-Flare and install hard lines from the master to the distribution block
-Bleed the brake system
-Pick up the rear driveshaft from the shop and install it
-Weld the rear spring perches to the axle
-Re-install the drivers side front fender
Then i'll take her out for the maiden voyage!
Unread 03-19-2012, 09:33 AM   #13
oalali
Impressive
oalali is offline   Reply With Quote Quick reply to this message
Unread 03-23-2012, 07:46 AM   #14
parkerm26
Latest picture. Just have to fix a brake line leak, bleed the system again and weld the rear spring perches and she's ready to drive.
Hope it starts/runs/functions right haha first motor/frame/body swap
Unread 03-25-2012, 10:36 AM   #15
parkerm26
Finished it up friday and took it out for a drive. put about 100 miles on it. Found a small coolant leak and I have to re-weld a shock mount up front because the steering arm was hitting it. still waiting for the rear shocks to come in from Quadratec. might have to order degree shims or use my old ones because I messed up the driveshaft angle a touch. doesn't vibrate though. rides really soft and smooth. once the rear shocks come in it should be real smooth.
