YJ REDEMPTION, 93 Wrangler Build - Page 7 - JeepForum.com
post #91 of 828 Old 09-27-2012, 12:26 PM Thread Starter
CDW_327
Picked up a Xj front drive shaft from the local JY to use in the future with an SYE.
Also picked up a 3.55 geared dana 30 to go with my 8.25 res end I'm swapping in. She was ugly when I got her but after tearing it down to the housing and R&P, painted with some chassis saver she looks good as new!
Before
After
CDW_327 is offline
post #92 of 828 Old 10-06-2012, 09:42 PM Thread Starter
CDW_327
Went wheeling out in traverse last weekend, had fun was able to make a lot of lines I hadn't been able to before, the RC leafs are really breaking in and really flexing well that being said I still don't like em. On Sunday on the way home on the 250 mile trip out side of flint about 35 miles from home one of my trans cooler lines blew and I lost enough ATF to the point the jeep would no longer shift, it was about 11 at night and long story short I just put my AAA 100 miles towing into good use lol.
Got the jeep home and replaced all the lines the next day on Monday.
The hole that caused all the problems.
The PO had the old hard lines cut with out a flare so that eventually wore the hole into the soft line, I went ahead and put a nice flare in the lines so that can never happen.
Double clamped every soft line with fuel hose clamps.
On the high way anything over 60 mph gives me bad vibes so my next purchase will be a PORC SYE and cutting down my XJ shaft which will also include my c8.25 swap at the same time.
Have a couple pictures from last weekend that are just on my phone, I have a lot more on my camera and some videos that I will post up later.
This was a really cool spot along the trail, there was a creek on both sides of the trail about 30 feet down on each side, the trail was just wide enough to get half of each tire to stay on pretty sketchy. Have a lot more pics of this on my camera.
CDW_327 is offline
post #93 of 828 Old 10-08-2012, 01:17 PM Thread Starter
CDW_327
Heres a video i made real quick of some wheeling ive done lately
CDW_327 is offline
post #94 of 828 Old 10-08-2012, 01:40 PM Thread Starter
CDW_327
Couple more pics from last weekend.
Old cabins where the Mob used to hide out in back in the 20s, about 30 miles from anywhere out in the woods.
CDW_327 is offline
post #95 of 828 Old 10-08-2012, 02:30 PM
printingray
I love such kind of adventures. I love its peace and calmness. Such kind of places are very much suitable for hunting.
http://www.printingray.com/
printingray is offline
post #96 of 828 Old 10-08-2012, 03:21 PM Thread Starter
CDW_327
I've been back in and around that area countless times and I'm yet to see someone back there at the same time I am.
CDW_327 is offline
post #97 of 828 Old 10-09-2012, 11:24 AM
JEEP_Nut1218
Shoulda just drove a couple more hours to Houghton! Beautiful this time of year
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
post #98 of 828 Old 10-10-2012, 07:10 AM Thread Starter
CDW_327
Haha like 12 more hours lol, I bet it is!
CDW_327 is offline
post #99 of 828 Old 10-17-2012, 09:32 AM Thread Starter
CDW_327
Knocked out the next step for having an SYE and TT under my jeep. I didn't want a BL and i didn't want to spend the money on one, but i wanted to TT my jeep so i made my own LowPro Trans mount. The LowPro mount allows you to drop your trans and Tcase about an inch without actually dropping your skid plate. All i did was chop my Trans mount in half then weld the top back on about an inch lower, Not only does this allow you to run a TT with out a BL it also gets rid of your T-case drop if your not going to a SYE.
Started by removing the Trans mount:
Marked a line for the cut:
Cut out a piece of 1/4" stock for the top and drilled the two mount bolt holes.
Welded her up, not my best welds lol it was 6:30 in the morning haha.
Bolted back up to the trans.
Bolted the skid plate back up.
T-case does hit the skid by a tiny bit so i will have to trim the skid out slightly.
Before when i was running the RC 4" lift with 1/2" booms, I was using the 1.5" T-case drop that came with the RC kit and i had some vibes, now with no Tcase drop and the same suspention setup but with my LowPro mount i have slightly less vibes, but thats what a SYE will fix. Now i have plenty of room to puch my T-case up when i go to do a TT and all without a BL
CDW_327 is offline
post #100 of 828 Old 10-17-2012, 09:47 AM Thread Starter
CDW_327
Oh, Also got my used RE H&T kit. Only problem is on my XJ front shaft i have a open U joint and the RE kit used a flange to bolt to the drive shaft, so i need to buy a Spicer #211229x which is like $77 bucks + $140 for shortening/balance and rebuild from B&L Drive shaft so my Budget drive shaft just became not so budget lol.
Seal flange
Flange the DS bolts to
CDW_327 is offline
post #101 of 828 Old 10-17-2012, 12:03 PM
Kalimba
You don't need to balance the rear SYE shaft, just cut it to length and weld it. They shouldn't charge you that much to do that or if you have a welder you should do it yourself. Have you already installed your SYE kit? How long do you need your driveshaft to be? Mine's 16" and it was also off an XJ, I have a spare I made out of a 1994 Ford Explorer.
1988 WRANGLER-5.7L 350 CHEVY-700R4 TRANNY-WAGGY D44 FRONT & REAR-LOCKRIGHT LOCKER FRONT & REAR-2 - M.O.R.E. TRACTION BAR - HELLA RALLYE 4000 55W HID CONVERSION, CUSTOM LIGHT CAGE.- 35" PROCOMP XTERRAIN.
Kalimba is offline
post #102 of 828 Old 10-17-2012, 01:51 PM Thread Starter
CDW_327
I actually cut and lengthened a rear drive shaft for my CJ and it doesn't have any vibes, I was just thinking since this is my DD and it sees high way speeds but if you had good luck then maybe I'll try it.
The shop that quoted me the 140 said it was $50 for cut/balance and the rest for new u joints since I have to have a special flange pressed in to work with my RE H&T kit. And no I haven't installed the SYE yet.
Does anyone know if you can take a CV shaft apart and put it back together using the same parts or will I need a rebuild kit?
CDW_327 is offline
post #103 of 828 Old 10-17-2012, 02:47 PM
responder
Nice work! I kind of like the "black" look as well.
responder is online now
post #104 of 828 Old 10-18-2012, 04:58 PM
Kalimba
You can rebuild the CV part, there's a kit with the ball in the middle and the black dust cover that goes around the ball. That one has to be pressed into the yoke. I found it online for about $100.00. I figured it's cheaper to go to the u-pull it yard and but one in decent shape for 20 dollars. Try a front Ford Explorer, those are usually in good shape because they're never lifted and/or abused being a family, soccer mom car... If you get one with good U-joints then all you have to spend is $50.00 to cut it and weld it to your size.
Google "1310 cv rebuild kit" and you'll find more info.
Kalimba is offline
post #105 of 828 Old 10-27-2012, 04:52 PM Thread Starter
CDW_327
Havent done much to the jeep other then replace the water pump, fan clutch, some pulleys and the belt, sounds much better now. Sold the XJ shaft i had because i'm buying a Tom Woods shaft from the same guy i got the H&T kit from. Still collecting parts for the axle swap but it should happen withing the next couple weeks.
Planing on swaping my rear leafs with some stock XJ leafs to gain about 5"-6" of stretch, Will also be adding a RCI fuel cell behind the back seat to make room for the diff. Will have to cut out my stock rear frame cross member and weld in a 2x4 1/4" square tube to hang the rear shackle mounts off of for the XJ leafs. Planning on doing a mild comp cut, nothing, will be leaving the gas filler hole and rear body mounts, will also be fabbing some comp flares. The XJ leafs only give about 2" of lift and that is the most lift i will be running, i plan on running 35" tires, so the jeep will be true LCOG built (i hope lol)
It just so happens that my rear bumper is made from 2x4 1/4" square tube, so i went ahead and chopped it up into a rear cross member.
Notches to fit the frame rails and provide lots of good welding areas, it also has a 1/4" over hang on each side so i can plate the frame.
Stock cross member will get chopped off.
What my comp flares could look like.
Should have some work on the jeep starting soon.
The inspiration for my jeep, i wont be comp cutting nearly as far as these rigs though.
CDW_327 is offline
Redemption build Huntinbud Jeep Builds 13 09-06-2011 11:16 AM
wrangler cj7 build clemmotors Jeep Builds 0 08-30-2011 10:22 PM
97 wrangler build shawnconboy Jeep Builds 2 05-23-2011 10:27 PM
My 01 Wrangler build up rocketman121 Jeep Builds 86 11-02-2010 04:50 PM
97 Wrangler Build Up Rocky.ca Jeep Builds 7 07-31-2007 05:42 PM
