YJ REDEMPTION, 93 Wrangler Build - Page 6 - JeepForum.com
post #76 of 828 Old 09-16-2012, 08:34 PM Thread Starter
CDW_327
Went out and ran some trails today, Ive ran all these trails many times before but most of these obstacles i haven't. Thought a couple times I blew my D35 up b/c it was making some clunking noises when romping on it lol but it held up just fine and the LSD in it actually gets both tires pretty well. Overall it was a fun day and was happy that i actually did some mild wheeling so close to home
LOL, airing down
10 min later still airing down i really need to invest in those screw on deflate things
One of the obstacles
Hill top poser
Yup thats me real cool, real cool haha
And thats a deer
CDW_327 is offline
post #77 of 828 Old 09-16-2012, 08:51 PM
JEEP_Nut1218
Lol airing down for a lakeland run?
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
post #78 of 828 Old 09-16-2012, 09:03 PM Thread Starter
CDW_327
Lol yeah just wait for the videos haha it made a difference.
CDW_327 is offline
post #79 of 828 Old 09-16-2012, 09:04 PM Thread Starter
CDW_327
Some three wheelin!
CDW_327 is offline
post #80 of 828 Old 09-16-2012, 09:46 PM Thread Starter
CDW_327
Couple more videos
CDW_327 is offline
post #81 of 828 Old 09-16-2012, 11:23 PM
WidowYj91
I love your setup, functional and good looking.
WidowYj91 is offline
post #82 of 828 Old 09-17-2012, 10:26 AM Thread Starter
CDW_327
Thanks man! Her *** end sits a little high but some OME 14F leafs should fix that.
CDW_327 is offline
post #83 of 828 Old 09-17-2012, 04:13 PM
WidowYj91
A little front rake never hurt anything, and you said thats a 4"rc?
post #84 of 828 Old 09-17-2012, 05:40 PM Thread Starter
CDW_327
Yup, RC 4" springs, if anyone wants them there for sale.
CDW_327 is offline
post #85 of 828 Old 09-17-2012, 06:29 PM
WidowYj91
Pm me the info.
post #86 of 828 Old 09-18-2012, 06:11 PM Thread Starter
CDW_327
Picked up an rear axle for an rear axle swap, best part is, it was free! Everything but brakes are in good condition but no big deal, will probably throw some chromos and an Aussie in it.
Let's play guess the axle! I'll give you a hint it starts with an 8. (jeepfreak, your not allowed to play since you already know what it is lol.)
CDW_327 is offline
post #87 of 828 Old 09-18-2012, 11:14 PM
WidowYj91
Its an 8.25
post #88 of 828 Old 09-19-2012, 08:06 AM Thread Starter
CDW_327
Its an 8.25
Yup, sure is.
CDW_327 is offline
post #89 of 828 Old 09-19-2012, 08:51 PM Thread Starter
CDW_327
Got some work done on the 8.25. Stripped the whole thing down the the ring and pinion. Pulled the brakes off first, then moved to the carrier and pulled the retaining bolt and center pin, then off came the c clips and the axle shafts slid out. After getting the rest of the little junk off and got started on cutting the Xj brackets off and grinding the surface rust off the axle.
Pulled the brakes
Then the center pin, side and spider gears.
Counted the splines in the side gear to make sure it's a 29 spline c8.25, it is!
Pulled the axle shafts, man these things are beef compared to a D35 shaft!
Cut the old brackets off.
For no reason the 8.25 has a 1/2" lip that hangs down under the diff, so I went ahead and gave her a shave.
Gave it a quick shot of primer just to get the surface rust off.
Next things will be welding the tubes to the diff, Reassembling it, and getting perches and shock mounts welded on. I'll be doing my SYE as well, using PORC's SYE and a cut down Xj front driveshaft.
CDW_327 is offline
post #90 of 828 Old 09-24-2012, 05:18 PM Thread Starter
CDW_327
Went wheeling again over the weekend, pretty fun, open diffs suck but makes for more of a challenge, when in doubt stomp on the skinny Really looking forward to having Aussies front/rear and a little more gearing, should help out here in Michigan with all the sand!
Open diffs + sand just don't work very well
Not a posser, i was trying a new line lol
Yup, stuck hung up on a rock, nothing a winch cable to a tree can't fix
This incline doesn't look like it does in person, it's pretty steep spun all 4 up....
I made this line last weekend but i really tore it up so i didn't make it this time. I did put a nice dent and scratch in my front drivers side wheel at 1:30 in this video
CDW_327 is offline
Redemption build Huntinbud Jeep Builds 13 09-06-2011 10:16 AM
wrangler cj7 build clemmotors Jeep Builds 0 08-30-2011 09:22 PM
97 wrangler build shawnconboy Jeep Builds 2 05-23-2011 09:27 PM
My 01 Wrangler build up rocketman121 Jeep Builds 86 11-02-2010 03:50 PM
97 Wrangler Build Up Rocky.ca Jeep Builds 7 07-31-2007 04:42 PM
