yj build - JeepForum.com
post #1 of 8 Old 12-22-2012, 01:28 PM Thread Starter
300gearhead
yj build
How hard would it be or is it possible to put tj coil over front end on Yu
300gearhead is offline
post #2 of 8 Old 12-22-2012, 01:30 PM
Ripper3494
if your asking the question your not there yet. not trying to be a dick but its not an easy thing, and if you were to do it i wouldnt put the tj system on it, id upgrade to something that you wont need to upgrade again for awhile like a radius arm setup. honestly i see no performance difference between the leaf springs on the yj and the coil setup that tjs use that makes it worth the work to run that setup
build thread:
http://www.jeepforum.com/forum/f22/9...-spud-1218315/
1997 ZJ limited - BONE stock
http://www.jeepforum.com/forum/f12/a...te-up-1301614/
http://www.jeepforum.com/forum/f12/t...ation-1417686/
RC vs BDS
http://www.jeepforum.com/forum/f12/r...s-bds-1461555/
Ripper3494 is offline
post #3 of 8 Old 12-22-2012, 01:39 PM Thread Starter
300gearhead
Ic ic well I was just wondering cuz there is no articulation with leaf springs
post #4 of 8 Old 12-22-2012, 01:52 PM
Ripper3494
Softer and longer springs will give you better flex
build thread:
RC vs BDS
post #5 of 8 Old 12-22-2012, 01:55 PM
Ripper3494
4" lift leaf springs
build thread:
RC vs BDS
post #6 of 8 Old 12-22-2012, 02:05 PM Thread Starter
300gearhead
I was wondering if a softer spring would do anything
What would be the best way to eliminate the vacuum on the front axle I know you can get a cable type for it but idk if there be a better way
post #7 of 8 Old 12-22-2012, 02:13 PM
Ripper3494
Softer springs would help, more thin leafs vs less, thick leafs will give you better flex.
I had a cable actuator for awhile but eventually i just put a tj shaft in it and blocked off the hole with a steel plate
No mods needed just stick the tj shaft in and run it
build thread:
RC vs BDS
post #8 of 8 Old 12-22-2012, 02:24 PM Thread Starter
300gearhead
Well that be an easy fix for the 4wd then
