A YJ 5.3 build without a clever name - Page 9 - JeepForum.com
 28Likes
post #121 of 2285 Old 03-26-2013, 11:20 AM
clintrivera
Doing engine swaps will make you an expert at the Summit Racing website.
clintrivera is offline
post #122 of 2285 Old 03-26-2013, 11:25 AM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
Haha yeah I can see that. Did you run a trans cooler and if so how did you plumb it up? Im on my phone so I dont feel like looking back through your build
Randonexplosion is online now
post #123 of 2285 Old 03-26-2013, 11:26 AM
clintrivera
From trans to radiator cooler to auxiliary B&M cooler back to trans.
post #124 of 2285 Old 03-26-2013, 02:14 PM Thread Starter
Randonexplosion
Deplorable
mine just came in, it looks pretty simple. My rad better come in today or im gonna be pissed. Superior said it was gonna be in Friday. Im anxious to get it plumbed up.
post #125 of 2285 Old 03-26-2013, 07:45 PM Thread Starter
Randonexplosion
Deplorable
Well no radiator. Ill be calling them tomorrow. I was working on the t case and trans shifters. I was almost done and I dropped the damn set screw for the splined arm and cant find it. I went and picked up another andd called it a night. Anybody use the AA t case shifter mount? I dont think it is gonna work with their trans mount unless im not seeing how it is supposed to mount. My t case was also missing a stud so I went to put one in and I thought the threads were just packed full of grease. After about an hour I finally got this out. It feels plastic but it wouldnt burn out with a little torch.
post #126 of 2285 Old 03-26-2013, 07:46 PM Thread Starter
Randonexplosion
Deplorable
Maybe its an insert for an alignment dowel from the old trans?
post #127 of 2285 Old 03-26-2013, 11:16 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
dude, bummer on the radiator
like clint said, you can swap over to aeroquip/summit/earls etc, -AN fittings pretty simple. I plan on using aluminum tube to make my runs. the jeep 4.0 line is only 5/16 and I wan to bump to 3/8. thinking of using the stock 5/16 as the return. you can also get just a tube nut and insert to slide on the hard line, flare it and connect directly to the fuel filter. ends up being like $3 a connection vs $10.... yep built a few race cars in my day lol.....
http://www.summitracing.com/parts/sum-220633-2b
http://www.summitracing.com/parts/su...4-2b/overview/
on the trans lines [for the hemi I did this too] for the ls swap, im going to use as much of the factory hard line as possible. at the soft rubber lines, ill switch to -AN stuff to plumb the rest.
with the TJ, im planning on getting [or making, my buddy has a cnc shop..] just the fitting that replaces the 4.0's regulator in the 97-04 fuel tanks from novak. then drop a return line into the tank with some -AN fittings and a down tube in the tank.
for your wiring, if you only have 2 wires then its most likely 'fuel level signal' and 'power to fuel pump' . I'd just put a 2 pin weather pack connector on it and call it done like clint suggested. I have those on the shelf
appreciate the offer/input on the trans.. I think I found one mated to a 231c case!!!
OH YEAH>>> PICKING UP A 2000 TJ TOMORROW.. $3500
putting my parts list together now...
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #128 of 2285 Old 03-26-2013, 11:30 PM Thread Starter
Randonexplosion
Deplorable
I guess I should have done a lot more research on the fuel lines. I didnt know where to start but I have a pretty good idea now. Run down to Superior Radiator and ask them where my **** is :: no problem on the adapter. I can find weather pack connectors at Napa? I have 3 wires now that I have a pump in the tank. I almost swear that my lines. Are 3/8 & 5/16. If I used those nuts yku said I have to flair the line? What flair?
post #129 of 2285 Old 03-26-2013, 11:45 PM Thread Starter
Randonexplosion
Deplorable
Flare not flair
post #130 of 2285 Old 03-26-2013, 11:50 PM
theGiantPanda
Swap This...
weatherpack... IDK about Napa, possibly? I know summit has them... I have a good selection of WP kits too. let me know if you want some. that's what I did on my hemi project. I had to use a 2005 tank and plug. I just mated it to the 2000 fuel tank wires with weatherpack.
let me see, when I am I going that way..hmmmm see if can get vito and tommy to come with y'kno wha im sayin' forgetaboutit'
-AN use a 37* the flare kit is $30 at summit. in the past I have gotten away with the stnd 45* flare and been ok, never had an issue to date. did that on my 70 stang the last time I changed things. im actually going to buy the AN flare kit tonight. its in my cart. figured I might as well have it!
http://www.summitracing.com/parts/sum-900311
the new shop...
shop email....
adding more daily
post #131 of 2285 Old 03-26-2013, 11:51 PM
theGiantPanda
Swap This...
flair/flare... I got it.. lol made me think about the movie 'office space' you need 30 pieces of flair..LOL
the new shop...
shop email....
adding more daily
post #132 of 2285 Old 03-26-2013, 11:55 PM
theGiantPanda
Swap This...
thinking about it... the stock 5.3 fuel filter.. uses a stnd efi fitting?? if you want to go that route, then just get [2] russel efi fittings to lock onto it and connect your hard lines to those. just an option would cost a few dollars more
the new shop...
shop email....
adding more daily
post #133 of 2285 Old 03-26-2013, 11:57 PM
theGiantPanda
Swap This...
as far as your stock fuel lines go, just mic' your lines. they maybe exactly what you think they are, carbed motors [YJ's] may have been just that.
the new shop...
shop email....
adding more daily
post #134 of 2285 Old 03-27-2013, 08:28 AM Thread Starter
Randonexplosion
Deplorable
That's what I'm thinking. Maybe the carb needed the volume of the 3/8 line but not the pressure.
post #135 of 2285 Old 03-27-2013, 08:31 AM Thread Starter
Randonexplosion
Deplorable
I was trying to attach a picture from my phone forever last night! this well have to do...
4 link , 5.3 vortec , engine swap
