A YJ 5.3 build without a clever name - Page 84 - JeepForum.com
 28Likes
post #1246 of 2285 Old 05-07-2014, 02:31 PM
skyj
I run the waggy springs in spring under configuration with a v8 and I don't get much axle wrap. I could definitely see the need for spring over though
build thread:
skyj is offline
post #1247 of 2285 Old 05-07-2014, 04:07 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
Originally Posted by ssyj94 View Post
You don't want to just get blanks and cut what you need?
I'm also in the market for corners to cover some repairs in the tub I have todo soon. Been looking at savvy and barnes blanks lately. I was comparing some of those "stretch" corners to what I chopped off to clear the tires at 3" back and they would cut out way more than needed. I'd put it all together and see where your at WB wise before ordering.
I've always been curious about the waggy springs and debated swapping to them for a longtime before the links. You may end up needing a traction bar with the V8 they are kind of thin/soft.
I guess I could do my own cutouts but if Barnes will do it for me then that is even easier. I called them today and he said that they would do it but they dont have any aluminum corners in stock right now. I gues it works out since it will be a while before I can afford them anyway.
I have been thinking about the axle wrap issue too. I don't know if it will be worse or not. I think I'm already getting some axle wrap because I can see where the yoke ears touch the 8.8 flange adapter and I doubt it is binding because of too much articulation
Worst case I will go with a RuffStuff anti wrap bar. Its not my DD.
Randonexplosion is offline
post #1248 of 2285 Old 05-07-2014, 04:25 PM
Maertz
2009 JK Wrangler
Doesn't rambo still have spare waggy springs as he went bds? Unless he tossed/sold them...
Are you dead set on links?
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #1249 of 2285 Old 05-07-2014, 04:28 PM Thread Starter
Randonexplosion
Deplorable
I'm not sure. Did he have stock waggy springs? I'm using the 2" lift to net me around 4".
What do you mean dead set on links?
post #1250 of 2285 Old 05-07-2014, 04:34 PM
ssyj94
Great.... I was going to try to order some blanks asap.
It's a leaf spring thing they all wrap it just depends how bad. I ran a bar like that when I was SOA rear for awhile and it kept everything where its supposed to be. With the 2" springs you'll prob be fine from the added arch.
My build:
ssyj94 is offline
post #1251 of 2285 Old 05-08-2014, 07:38 AM
Maertz
2009 JK Wrangler
I meant are you for sure getting links or still in the air on leafs?
Maertz is offline
post #1252 of 2285 Old 05-08-2014, 09:35 AM Thread Starter
Randonexplosion
Deplorable
I'm sticking with leafs right now. Linking is still the long term plan but I need to address it ASAP.
post #1253 of 2285 Old 05-08-2014, 09:39 AM
Maertz
2009 JK Wrangler
Ahh gotcha. If you need the waggy springs ask rambo he might still have a pair...?
Maertz is offline
post #1254 of 2285 Old 05-08-2014, 11:36 AM Thread Starter
Randonexplosion
Deplorable
I just looked at his build and he used stock waggy springs.
post #1255 of 2285 Old 05-08-2014, 02:03 PM
Maertz
2009 JK Wrangler
Pretty sure hes got bds leafs and had spare waggys he didn't need....
Maertz is offline
post #1256 of 2285 Old 05-08-2014, 02:13 PM Thread Starter
Randonexplosion
Deplorable
Yeah but the waggy springs that the BDS replaced are stock. I need the Rancho 44044 lift springs.
post #1257 of 2285 Old 05-08-2014, 02:23 PM
Maertz
2009 JK Wrangler
Ahh icic. I do remremember he unstretched it...
Maertz is offline
post #1258 of 2285 Old 05-09-2014, 09:28 AM Thread Starter
Randonexplosion
Deplorable
I ordered the springs the other day but Amazon only had 1 in stock. They still haven't updated and shipped my order so I think I'll cancel it and order through someone else. How weird is it that Amazon has them with Prime?
post #1259 of 2285 Old 05-09-2014, 09:17 PM Thread Starter
Randonexplosion
Deplorable
Screwed around with the brakes again this evening. I adjusted the booster rod a couple times to get rid of the slack in the pedal. It helped but I think i may need to thread it out a little farther. During some testing I can get the fronts to lock up quick in the dirt but the driver side locks up before the passenger. So I bled the passenger and didn't get any air out but I can definitely squeal them on concrete if I push hard enough. I don't think the 8.8 is grabbing much. I may follow The Goob's lead and mess with the prop valve.
post #1260 of 2285 Old 05-13-2014, 04:37 PM Thread Starter
Randonexplosion
Deplorable
A little update for anyone that is following. My 44044s should be here tomorrow. I think I am going to bolt them up with the short side forward so I can still run my driveshaft and pinion angle just to check them out. Once I get them broken in and see if I like my ride height, I will decide if I want to weld on my Ruffstuff hangers any farther back and get my driveshaft lengthened and re-weld my spring perches. Something interesting I found out: one end has bushings with a 1/4" flange to fit a 3" hanger, but the other end has 1/8" flanges to fit a 2.75" hanger. So I ordered some new bushings from Barnes4wd along with their rear crossmember bumper and frame tie ins. I figure I should get some recovery points in the rear before I regret it, and cover up my ugly crossmember. I think someone ripped a bumper off of it once upon a time.
4 link , 5.3 vortec , engine swap
