A YJ 5.3 build without a clever name - Page 8 - JeepForum.com
 28Likes
post #106 of 2285 Old 03-25-2013, 11:37 PM
clintrivera
Oh good, I was thinking if there was any way to screw up the sound of an American made v8, that would be it.
clintrivera is offline
post #107 of 2285 Old 03-25-2013, 11:40 PM Thread Starter
Randonexplosion
Randonexplosion's Avatar
I guess thats why it was so funny to me
Randonexplosion is offline
post #108 of 2285 Old 03-26-2013, 12:40 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
thanks.. looks like I will be dumping the 4l60e I have and getting a 4wd unit. got a notification that the Camaro headers shipped.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #109 of 2285 Old 03-26-2013, 08:47 AM Thread Starter
Randonexplosion
Had you thought about using the Novak trans adapter? It is $600+ and it replaces the output shaft on the trans. I wouldn't use it but if you get stuck and cant find a 4wd 4l60 trans its an option. What did you end up paying for your manifolds? Them ****s arent cheap to ship!
post #110 of 2285 Old 03-26-2013, 10:31 AM Thread Starter
Randonexplosion
As I've said before, I hate wiring. What would be the correct way to hook up my new fuel pump? Of course the pigtail is different than the old sending unit. Do I need to order the correct pigtail and run new wiring , one up to the fuel guage and one to a newly installed fuel pump relay? I'm pretty sure there were only 2 wires...
post #111 of 2285 Old 03-26-2013, 10:38 AM Thread Starter
Randonexplosion
I also need some more opinions on fuel lines. I get some conflicting ideas. I have the hard lines from the Vortec down to the xfer case area. My stock lines are all good so my idea is just to connect them and put a filter in where they meet. The easiest thing would be to use fuel injection hose and hose clamps. Will that hold up to the pressure? Would I need a double flar? single flare? A guy at Summit recommended using regular brass compression fittings for plumbing (ferrule and nut). Will it be easy enough to find a fuel filter with those threads? I'm looking for low cost and ease of maintenance/filter replacement.
post #112 of 2285 Old 03-26-2013, 10:47 AM
clintrivera
You could just hard wire it, or get a weather pac connector to make it easier when you drop the tank, or cut one off a YJ at the junkyard.
You don't necessarily need a fuel filter. The Jeep fuel pump has one built into it. If you do want to run one, you can get a compression fitting that has an AN fitting on the other end, then just get a FI rated fuel filter, and go AN-to compression fitting again. For your rubber hose make sure it's rated for ethanol fuel and FI fuel pressure.
post #113 of 2285 Old 03-26-2013, 10:53 AM Thread Starter
Randonexplosion
Originally Posted by clintrivera View Post
You could just hard wire it, or get a weather pac connector to make it easier when you drop the tank, or cut one off a YJ at the junkyard. Junk yards around here arent that easy to work with and the closest one is over an hour away so I'll probably just hardwire is in one way or another.
I'll try to find that fitting on Summit. So a fuel filter with -6 fittings should be pretty common? I'm wondering what the fittings are like on the Silverado filter. If I remember correctly they are threaded. Pardon my fuel system ignorance
post #114 of 2285 Old 03-26-2013, 11:34 AM
clintrivera
Here's a filter. http://www.summitracing.com/parts/rus-650133/overview/
This is what you need for the fitting
http://www.summitracing.com/parts/ea...6erl/overview/
post #115 of 2285 Old 03-26-2013, 11:41 AM Thread Starter
Randonexplosion
Perfect! I saw those filters while browsing yesterday but wanted to stick with some thing that I could get locally. I dont know why. Since it isnt a DD I doubt I will ever have to replace the filter. Good man Clint
post #116 of 2285 Old 03-26-2013, 11:51 AM Thread Starter
Randonexplosion
They dont have any for 3/8 lines in black
I got it ordered. Should have that all hooked up for about $50.
post #117 of 2285 Old 03-26-2013, 12:01 PM
clintrivera
I thought YJ fuel lines are 5/16" supply and 1/4" return?
post #118 of 2285 Old 03-26-2013, 12:03 PM Thread Starter
Randonexplosion
No sir. I havent measured but mine appear to match up to the Chevy lines. Even if my supply is only 5/16 ill need to run a new 3/8 from the tank to get enough volume.
post #119 of 2285 Old 03-26-2013, 12:07 PM
clintrivera
Here is a black 3/8 in stock
http://www.summitracing.com/parts/su...075b/overview/
post #120 of 2285 Old 03-26-2013, 12:16 PM Thread Starter
Randonexplosion
Quit showing me up! I guess I just browsed through the Earls fittings
4 link , 5.3 vortec , engine swap
