A YJ 5.3 build without a clever name - Page 75 - JeepForum.com
 28Likes
post #1111 of 2285 Old 03-24-2014, 03:32 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
That's the 'Murican Spirit right there!
Cheers
So true. Make my $100 payment and put $300 back on it.
Black Magic pads, Centric rotors and calipers ordered
Anyone gut their proportioning valve after installing their 8.8? Or install one from a ZJ with rear discs?
Randonexplosion is offline
post #1112 of 2285 Old 03-25-2014, 07:11 PM
panaceabeachbum
who makes the transmission mount back on page 2 or 3 ? DOes it bolt directly to the cross member? Do you need a torque arm or is that it ?
panaceabeachbum is offline
post #1113 of 2285 Old 03-25-2014, 07:14 PM Thread Starter
Randonexplosion
Deplorable
I used the Advance Adapters transmission mount. It bolts to the skid from underneath instead of using studs. Nope, no torque arm.
post #1114 of 2285 Old 03-25-2014, 07:33 PM
panaceabeachbum
I like that mount, I used the one from Novak which uses the original torque arm and the entire stack is pretty darn tall. On the std skid it pushes the 4l60 trans right against the tub, I bet with that mount I can get at least a 1.5" tuck when we build the new skid plate. Your jeep build is awesome.
post #1115 of 2285 Old 03-25-2014, 07:47 PM
panaceabeachbum
Is the Barnes skid you used a 2"?
Youll be able to tell where I am in yiur build thread by the order in which I ask my stupid questions
post #1116 of 2285 Old 03-25-2014, 08:22 PM Thread Starter
Randonexplosion
Deplorable
Haha thanks man. Nowhere as clean or detailed as yours but I got dirty and got it done.
Yeah the AA mount is pretty low pro. I installed my 8.8 with my pinion angle set with my stock skid and stock trans mount. When I did the 5.3/4l60e the new mount landed on the 1" tall channel and the pinion angle was still high enough to give me vibes under throttle. A 1" skid would probably work perfectly but the 2" will do.
post #1117 of 2285 Old 03-25-2014, 08:25 PM Thread Starter
Randonexplosion
Deplorable
Here are some pics I took for Sparrows of my trans tunnel. Quite a bit of room still with no body lift.
post #1118 of 2285 Old 03-26-2014, 10:19 AM
panaceabeachbum
I may try the 1" skid plate then with the AA mount, assuming that mount will work with my Novak adapt, it looks like it uses the studs that hold the adpt on the transmission so I assume it will work
post #1119 of 2285 Old 03-26-2014, 11:05 AM
tecksjeep
Do you have all that room because of the new transmission on the back of your under hood beast? And did you have to do anything special after the swap to get it through emissions?
5.7 Vortec, D60 front w/ detroit,14 bolt rear w/spool. 16" FOA Coilovers in rear ORI struts in front, Barnes Enduro Joints, Daves custom boat sides/rear armor.
Check out my build here!
tecksjeep is offline
post #1120 of 2285 Old 03-26-2014, 11:10 AM Thread Starter
Randonexplosion
Deplorable
I think the short trans mount helps a lot. I saw your post in Sparrows thread, no I dont have emissions. Do you Scott? From what I have heard, if the engine is the same year or newer than your Jeep, and you retain all factory emissions equipment, you should be fine.
post #1121 of 2285 Old 03-26-2014, 11:43 AM
tecksjeep
Yeah I have emissions. And a guy with a CJ-8 failed because he didn't have the paperwork or something
post #1122 of 2285 Old 03-26-2014, 01:06 PM Thread Starter
Randonexplosion
Deplorable
Could make a call to them and see what the requirements are. Maybe you just need the VIN from the donor.
post #1123 of 2285 Old 03-26-2014, 01:20 PM
tecksjeep
Oh that's good advice! Im getting jealous of seeing these v-8's lol
post #1124 of 2285 Old 03-26-2014, 03:53 PM
youngjeepr
If you did that wouldn't you have to re register your jeep under that vin?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #1125 of 2285 Old 03-26-2014, 04:02 PM Thread Starter
Randonexplosion
Deplorable
I have never had to screw with emissions so I may be talking out of my *** here, but I just mentioned the donor VIN so they have verification of the engine and necessary emissions equipment. The VIN is attached to the chassis so an engine swap wouldnt change the VIN.
In other news, I just ordered a Prothane body mount bushing kit. I heavily debated on doing a body lift to make room for other things (flat belly, rear upper links) but my 35s already look a little small and I don't want to be any taller right now. I'm mainly looking to get rid of chassis noises and vibes. My stock rubber mounts are beat down.
4 link , 5.3 vortec , engine swap
