A YJ 5.3 build without a clever name - Page 61 - JeepForum.com
 28Likes
post #901 of 2285 Old 01-22-2014, 05:53 AM
84jeepcj7rock
Originally Posted by Randonexplosion
Just need to align it now
Good lookin set up. That is one heck of a long bolt with thick misalignment spacers on the pitman arm. Lots of sheer stress on that.
You may want to look into mounting the drag link to the bottom of the Pittman arm to level it out and then get some thinner spacers. You will have less bump steer and a stronger construct.
84jeepcj7rock is offline
post #902 of 2285 Old 01-22-2014, 09:32 AM Thread Starter
Randonexplosion
Randonexplosion's Avatar
Originally Posted by theGiantPanda View Post
Hey if you can make it happen... Weld in a Bar behind your seats between the main hoop. Locks that hoop together and get you a place to attach a harness when u go that route. Also put a rear spreader bar at the rear of the cage. You can make those really easy. It's simple and will at least help alittle bit to keep it from completely folding.
Looking good. I like cage work. Lol
Thanks buddy. I will definitely be adding some stuff to the back and a harness bar when I get new seats and harnesses. Do you really think my cage moved much from the heat? we had 4-6 tacks on each joint before we pulled it and tried not to heat up the metal too much beyond getting good penetration.
I was thinking about that too. I think if I mount it underneath the pitman arm its gonna hit the tie rod when the pass. side comes up. I was thinking about just grinding them down a bit. Not sure why RuffStuff sent such tall misalignment spacers.
Randonexplosion is online now
post #903 of 2285 Old 01-22-2014, 12:58 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
couple things...
1st sparrows.. 1800 for a 'running' full dress 5.3 motor trans wiring harness pedal ecu with 103k on it is about the average around here, especially if you don't have to pay a bs 'core charge.' if it comes from a reputable yard is important as well. I would want to know the year of said motor. you absolutely need to verify, by any means possible to you, that it is an actual 5.3l. the 4.8s 5.3s and 6.0s are all identical from the outside. its pretty common for a guy to get sold a 5.3 and it actually is a 4.8....
randon.... hopefully with all the tacks it will stay fairly well 'put' do expect some shifting. and if it didn't move, then you will be even more happy LOL...
on the steering, I think I would look into a few things... [1] put the heim joint at the pitman arm on the bottom, but re-install with safety washers vs high mis-alignment spacers. They still offer a quite a bit of degree change but aren't as crazy high/long/tall as what you are running. I would even consider running them at the knuckles as well. you don't need all that height coming off the knuckles... safety washers provide more than enough room for change during turning. I might consider keepin the 'high misalignment spacers' [ if not at least 1 of them] between the drag link heim and the cross over heim at the pass knuckle just to keep clearance between the 2 links. the closer you can get those to level, the more operating angle you have at your disposal.
another option... you can always put the cross over link on the bottom side of the knuckles, with safety washers. then put the drag link heim on the top side with high misalignment spacers, and then put the pitman arm heim on the bottom side as well, with the appropriate spacers [high/short] whichever gives you the best results.
some related pics
in all honesty, It comes down to how much flex you have, if you flex beyond the safety washers then yeah you need to run the high misalignment spacers or re-work your steering set up, if you don't, then the shorter spacers are the way to go.
there are a ton of rigs out there with the steering set up like yours. one thing that most don't add is some type of bracket to put the bolt in a double sheer set up. doing this adds safety and strength to the system. being that the front 30 has unit type bearings, you can easy fab a bracket out of 1/4" that uses a few of those bolts to mount. going to a double sheer set up you can even afford the luxury of increasing the distance between the 2 heims at the knuckle with a spacer, to move the drag link up into a more level position.
this is alttle extreme but you get the idea...
http://t3.gstatic.com/images?q=tbn:A...Wt--j-s-5fvNrA
http://t0.gstatic.com/images?q=tbn:A...po4dpXNtaFl3tS
hey these are my thoughts on it.... either way its better than stock and looks tough. nice.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #904 of 2285 Old 01-22-2014, 03:09 PM Thread Starter
Randonexplosion
I was curious about stacking both heims on top of the knuckle too, but once I put it together I don't think i'll have any problems with that big *** grade 8 bolt. I think once I take it out wheeling and get it flexed out I will have a better idea of where I can move each joint to or if I need to. I may just order some safety misalignment spacers from ruffstuff and get rid of the high misalignment.
post #905 of 2285 Old 01-22-2014, 05:00 PM Thread Starter
Randonexplosion
Got some paint on the cage. I was wondering why it looked so chrome. The cap was dark Grey but apparently the color was Aluminum. 1390435199952.jpg1390435212956.jpg
Went back and got some Grey. That's more like it
post #906 of 2285 Old 01-22-2014, 08:05 PM
theGiantPanda
Swap This...
shheeeeeeet! shoulda leffft it chrome playa' show how you be ballin' pockets so thick you running a chrome cage .....
at first when I saw the pics I was like 'this paint scheme is going to be interesting...' then I actually read the post.... I like the subtle grey.
the new shop...
shop email....
adding more daily
post #907 of 2285 Old 01-22-2014, 08:15 PM
Maertz
2009 JK Wrangler
Looking good bud.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #908 of 2285 Old 01-22-2014, 08:21 PM Thread Starter
Randonexplosion
I showed your post to my girlfriend and she laughed her *** off. Yeah I like they grey, matches my stock Jeep decals. Shoulda left it chrome though....
post #909 of 2285 Old 01-22-2014, 08:21 PM Thread Starter
Randonexplosion
Originally Posted by Maertz View Post
Looking good bud.
Thanks dude. I just hope it bolts right in. I think Jim jinxed me though...
post #910 of 2285 Old 01-22-2014, 08:30 PM
Maertz
2009 JK Wrangler
Yeah that was a dick move lol
Maertz is offline
post #911 of 2285 Old 01-22-2014, 09:54 PM
theGiantPanda
Swap This...
Hahaha.... Naaa you'll be good..... Lol Like I said expect it to move on you and you'll be happier when it goes right back in... I'm just thinkin about your happiness buddy.
the new shop...
shop email....
adding more daily
post #912 of 2285 Old 01-22-2014, 09:58 PM Thread Starter
Randonexplosion
Aww thanks buddy. I'm expecting setting it back in to be the hardest part. Does it just move every which way?
post #913 of 2285 Old 01-22-2014, 10:18 PM
theGiantPanda
Swap This...
Everything moves alittle. You might have to push and pull here and there. It's usually the windshield mounts that give the most trouble.
Don't you hate it when you pick some movie expecting it to be decent and it's boring as frock but you still watch the darn thing till the end hoping for something good to happen... Should have stayed at the shop.
the new shop...
shop email....
adding more daily
post #914 of 2285 Old 01-23-2014, 07:17 AM
84jeepcj7rock
I got my spacers from Ballistic. I think they are called safety washers.
post #915 of 2285 Old 01-23-2014, 07:19 AM
Maertz
2009 JK Wrangler
Thats correct. Also there common high misalignment spacers are not nearly as tall. Thats where i get all my stuff.
Maertz is offline
4 link , 5.3 vortec , engine swap
