A YJ 5.3 build without a clever name - Page 50 - JeepForum.com
 28Likes
post #736 of 2285 Old 11-14-2013, 06:53 AM
ssyj94
Thanks for the info SS. So you are running them not balanced at all and they are fine? My shackle bushing are pretty new, as far as mileage goes. Im gonna run over to the garange at lunch and check the torque on my shackle bolts. I have a feeling that it is all in my TREs. I am running the Rugged Ridge setup that I got from a friend. They don't have too many miles on them but quite a bit of wheeling, and the boots are toast. I have been doing a lot of reading this morning and I think I am going to go with the 3/4" heim setup from Ruffstuff.
Also on the PSI, The tire shop aired them up to 30 so I immediately dropped them down to 25, but they do wander a bit. If they are doing well for you at 15 I think Ill do that and see how they run.
Yea I've been running them unbalanced for awhile they vibrate just a little. On a long trip you can feel the balance shift since it'll shimmy at 50mph at one point and other times be smooth to 75mph. Once the flat spots are gone after 15minutes or so of driving they smooth out for me. I've been meaning to throw some BB's in them but haven't had time to break the beads. I run 15psi street and 3-5psi wheeling on 15x8's no beadlocks. I feel the tires dont even start working till single digits.
Can't go wrong with heim steering I run a similar homemade setup and only bent a shank cause I smashed a rock going fast (bent the solid 1.75" tie rod too).
My build:
ssyj94 is offline
post #737 of 2285 Old 11-15-2013, 10:47 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
Randon, how did you address the power steering HP hose. Just curious. Coming a cross some of the differences between the 08 LS Im finishing up and the 01 LS I'm doing now in the black Betty jeep.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #738 of 2285 Old 11-15-2013, 10:48 PM
theGiantPanda
Swap This...
Use good hiems in your steering. The cheaper ones don't last long at all!
the new shop...
shop email....
adding more daily
post #739 of 2285 Old 11-15-2013, 10:51 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
I just reused the jeep lines. I was surprised to find that they threaded right in to the GM pump.
What do you think of the Ruffstuff heims? That's what I was planning on using...
Randonexplosion is offline
post #740 of 2285 Old 11-15-2013, 11:01 PM
theGiantPanda
Swap This...
Yeah they thread in, but the 01 ps pump port is in the front and the stock tj lines are bent in such a manner that I don't like the final position of the hose. Just curious on the yj.
The 08 (port in the back) and jeep lines mated and aligned with a dam near perfect result.
the new shop...
shop email....
adding more daily
post #741 of 2285 Old 11-15-2013, 11:03 PM
theGiantPanda
Swap This...
And from what it have read ruff stuff has good ones and inexpensive ones iirc. Do some quick research.
I honestly haven't ordered anything lately regarding hiems. I'm supposed to be getting a high steer project soon and will be researching again to refresh my choices.
the new shop...
shop email....
adding more daily
post #742 of 2285 Old 11-15-2013, 11:12 PM Thread Starter
Randonexplosion
Deplorable
I take that back. I just went out and looked and I think I used the YJ high pressure line, but the pump has a built in line for low pressure with the GM clamps to a soft line, so I used that up to the hard line coming from the YJ gear box.1384582336667.jpg1384582369600.jpg
post #743 of 2285 Old 11-15-2013, 11:25 PM
theGiantPanda
Swap This...
Thanks buddy..
****... Your port is in the back too like the 08's. wtf is the story with this ps pump? Think it is about to get swapped. Idk why it has the hp port pointing forward other than it had a sensor off the back in it for some reason. Maybe I'll take a deeper look tomorrow and see if it's removable..idk.
Maybe a JY ps pump is in order and the best resolution.
the new shop...
shop email....
adding more daily
post #744 of 2285 Old 11-15-2013, 11:31 PM Thread Starter
Randonexplosion
Deplorable
That's odd. Maybe it is a replacement and they built it different? Mine is OE as far as I know. Unless someone changed it before I bought it at 70k. I wouldn't think the brackets would be different or anything if you found the pump that you need.
post #745 of 2285 Old 11-16-2013, 12:01 AM
AZdEvilYJ
Thanks buddy.. ****... Your port is in the back too like the 08's. wtf is the story with this ps pump? Think it is about to get swapped. Idk why it has the hp port pointing forward other than it had a sensor off the back in it for some reason. Maybe I'll take a deeper look tomorrow and see if it's removable..idk. Maybe a JY ps pump is in order and the best resolution.
I've never had good luck with JY PSPumps. Seems like everyone I get squeels and whines. I'd say go new if your gonna spend the $$. They're <$100 iirc
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #746 of 2285 Old 11-18-2013, 08:22 PM Thread Starter
Randonexplosion
Deplorable
I dropped the tank but didn't get to welding my access panel back in. I thought I'd be Ok leaving 1/4 tank in, but my stupid exhaust was in the way so the drivers side had to drop all the way down first. I didn't think it was smart to weld over a couple gallons of gas on the floor.
post #747 of 2285 Old 11-19-2013, 12:18 AM
theGiantPanda
Swap This...
Looks like your making progress buddy. Can't wait to see it done!
Regarding the ps pump on my 5.3. It appears under closer examination... That the sensor adapter can be removed and the forward facing port with it as well, leaving a stock rear facing port. I will mess with it tomorrow. Thanks again for the reference pics man I appreciate it.
the new shop...
shop email....
adding more daily
post #748 of 2285 Old 11-19-2013, 01:10 AM
theGiantPanda
Swap This...
Hey u still have your stock coolant overflow bottle? I'm curious about something.
the new shop...
shop email....
adding more daily
post #749 of 2285 Old 11-19-2013, 07:17 AM Thread Starter
Randonexplosion
Deplorable
Hope you get it figured out. Worst case scenario maybe pick one up for a 99?
I'll check on my old overflow bottle. When I sold my old engine I gave the guy a bunch of crap with it but I'll look around the garage.
post #750 of 2285 Old 11-19-2013, 12:58 PM Thread Starter
Randonexplosion
Deplorable
Got my access hole patched back in on my lunch break. Welding it in was a PITA.
My fittings should be in tomorrow so the fuel cell should follow shortly.
4 link , 5.3 vortec , engine swap
