A YJ 5.3 build without a clever name - Page 43 - JeepForum.com
 28Likes
post #631 of 2285 Old 08-18-2013, 01:39 PM Thread Starter
Randonexplosion
Randonexplosion's Avatar
Here you go Jim.
http://www.jeepforum.com/forum/f12/h...lights-976895/
I know I need to get on the skid plate and t case. Headed to Moab in 2 weeks so ill get on it sometime this week.
Randonexplosion is online now
post #632 of 2285 Old 09-03-2013, 06:57 PM Thread Starter
Randonexplosion
A little update: I think I banged out my t case chain in Moab. After running Top of The World I heard a noise that sounds like someone swirling BBs in a coffee can. I'm guessing its the chain rubbing on the case. I guess I need to get on that 233c chain and Barnes4wd 2" skid.
I also picked up some 35" Maxxis Creepy Crawlers from a buddy. They should fill out the Cloaks well. Too bad I don't get to keep the beadlocks...
post #633 of 2285 Old 09-10-2013, 10:22 PM
Sparrows
When are ya going to get those meats on? I've been patiently waiting here bud....
Cheers
June '13 YJOTM
Sparrows is offline
post #634 of 2285 Old 09-10-2013, 10:34 PM Thread Starter
Randonexplosion
Haha I'm not sure bro. I kinda wanted to find an extra set of wheels to mount them on just for wheeling. Not that I drive the jeep much but these things are beasts. And soft as hell from what I've read. I need to take the time to break down the beadlocks and get them separated but its been raining since the weekend. Ill probably get impatient and just get them mounted
Don't know if they can be balanced for highway speeds (my buddy used them on his CJ buggy and they are a little chunked) so I may try some airsoft BBs.
post #635 of 2285 Old 09-10-2013, 11:54 PM
Sparrows
Ah gotcha. Well can't wait to see those bad boys in action!
Cheers
June '13 YJOTM
Sparrows is offline
post #636 of 2285 Old 09-11-2013, 12:16 AM Thread Starter
Randonexplosion
You're telling me! He siped them all too. Gonna be amazing on the rocks.
I can't decide what to do on my rear suspension. I want to get a few inches of stretch and definitely more flex than I have right now. I was all for 4 linking it, but now I'm wondering about SOA. I was trying to research how to keep SOA low, but didn't come up with much. I would like it to match my 3.5"/5/8 shackles up front. For springs I could do Waggys + offset perches to get 3"s of stretch. Ideas?
post #637 of 2285 Old 09-11-2013, 05:37 AM
Ripper3494
Btf rear stretch crossmember, french spring hangers into the frame and go soa on some stock springs. That should keep you about flat. But if you really wanna plant the tires there's no better way than a 4 link
Sent from AutoGuide.com App
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #638 of 2285 Old 09-11-2013, 08:17 AM Thread Starter
Randonexplosion
I need to put a pen to some paper and see what would be less work/more cost effective. By the time I french hangers into the frame, build an anti-wrap bar, install the BTF crossmember and possibly screw with my leaf pack I could probably have my links all dialed in. Then there would just be coil buckets.
Ripper, what was your cost on your 4 link project? I'd guess the biggest cost would be the DOM and joints. You went with heims right?
post #639 of 2285 Old 09-11-2013, 08:28 AM
Ripper3494
i went with heims yea, but i recommend JJ's or metalcloak's duroflex joints. they will run smoother for road driving.
i can tell you right now it will probably still be cheaper/easier to do everything to do with the leaf spring stretch than the links.
btf crossmember - $299
anti wrap bar - 150
new spring mounts - $50
driveshaft - x
i could probably do this in a day or so
my link setup cost me about 950 bucks along with
all new axle brackets + a truss is a good idea
4 new frame mounts
coil buckets
coil springs
i have a couple hundred hours in my link setup
build thread:
RC vs BDS
post #640 of 2285 Old 09-11-2013, 08:34 AM
Ripper3494
that being said i'd take a link setup over a leaf spring any day of the week even if it costs me over twice as much. i can dial it in and fine tune it to do exactly what i want it to, unlike leafs that will always have some amount of unpredictability
build thread:
RC vs BDS
post #641 of 2285 Old 09-11-2013, 09:24 AM Thread Starter
Randonexplosion
I think my girlfriend might leave me if I spent a couple hundred hours in the garage setting up links.
Mainly because she wouldnt be able to drive the Jeep for that long
post #642 of 2285 Old 09-11-2013, 10:01 AM
AZdEvilYJ
I've been thinkin about a 4" rear stretch and the way I think I'm going to go about it is to use the btf rear crossmember and cut the frame side spring mounts off and move them back 4" and reweld them back on. Then you can keep your same springs and the cost is still very cheap. Bumper and extended driveshaft would be your only major expenses.
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is online now
post #643 of 2285 Old 09-11-2013, 10:13 AM Thread Starter
Randonexplosion
I would need new springs because that is most of my problem, and I want to go SOA, but that's only a couple hundred bucks.
What are your plans for a fuel tank?
post #644 of 2285 Old 09-11-2013, 10:33 AM
AZdEvilYJ
Cut the floor out and move it up and build a new floor above it. I'm still a ways from that but I'm building it in my head so when time comes I know all the details lol
'95 YJ 2.5L
My Build Thread
post #645 of 2285 Old 09-11-2013, 12:42 PM
clintrivera
What are your goals? Personally I wouldn't bother stretching unless you are getting at least 10".
clintrivera is offline
4 link , 5.3 vortec , engine swap
