A YJ 5.3 build without a clever name - Page 37 - JeepForum.com
 28Likes
post #541 of 2285 Old 07-01-2013, 12:24 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
i'd buy the reamer and do the GM tre's if i was in that situation. id do them flipped for sure as long as everything clears. probably the most cost effective way to go to go about it with the most practical benefits for the money.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #542 of 2285 Old 07-01-2013, 06:02 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
I think youre right buddy! Is there any point in going high steer if im still spring under?
Randonexplosion is offline
post #543 of 2285 Old 07-03-2013, 12:03 AM
theGiantPanda
Swap This...
tried to send this earlier but didn't go through... id say yes. reduce angles on your steering is always good in my book. better when your flexing if your starting at 'neutral.' if you are addressing/replacing the steering anyways.. I would do it if it was me.
I put up some progress pick of the silver 5.3 project... made a little.
be on the look out for a little box. sent it out USPS today. they said Friday.. we'll see.
good news, the auto trans and 241c have the same spline count.. was alittle curious.
the new shop...
shop email....
adding more daily
post #544 of 2285 Old 07-03-2013, 09:03 AM Thread Starter
Randonexplosion
Deplorable
I don't know how much room ill have for high steer. Since i'm only on 3.5" springs in the front I have a feeling it will be tight. I think all new steering flipped OTK will make it much more pleasant to drive.
Thats awesome man, I was checking out the build thread and your pics. Thats one thing I havent done to my Jeep, remove the tub. I think I have pulled every single bolt besides the tub bolts
I'll be looking for the package, you know I'll be repping you in the Southwest!
post #545 of 2285 Old 07-03-2013, 01:20 PM
theGiantPanda
Swap This...
sorry if I wasn't clear buddy, I wasn't talking going high steer 'high steer.' just agreeing on going OTK/flipping it if you have the room to do that.
you should pull those tub bolts and re-install them to feel complete...
hell yeah!!!! sport them' buddy.. sent you an extra, keep for yourself or give it to a friend.
the new shop...
shop email....
adding more daily
post #546 of 2285 Old 07-03-2013, 03:00 PM Thread Starter
Randonexplosion
Deplorable
Awesome bro. What size did you ship?
post #547 of 2285 Old 07-03-2013, 03:32 PM Thread Starter
Randonexplosion
Deplorable
For you LS guys, I have been curious about something. In regards to hp/tq specs for these engines, I think when they first started out in 99 (mine) they were rated at something like 285/300. Then a couple years later, and varying from truck to Tahoe/Yukon they went up to 295/310 and so on. Even the Chevy Colorado with a 5.3 is rated at 300/325 i think. What is the difference? Just the PCM tune from the factory? Shouldnt all gen 3 5.3 be the same mechanically except for the Aluminum block L33s?
post #548 of 2285 Old 07-03-2013, 04:06 PM
clintrivera
The L33 (and IIRC all the AL block LS truck engines) had flattop (higher compression) pistons and different cams.
I know a cam swap can really wake these motors up. There is power in the tune though.
clintrivera is offline
post #549 of 2285 Old 07-03-2013, 06:00 PM Thread Starter
Randonexplosion
Deplorable
Thanks for that info Clint!
post #550 of 2285 Old 07-05-2013, 10:19 PM
Sparrows
You need moar pics up in here!
Cheers bro!
June '13 YJOTM
Sparrows is offline
post #551 of 2285 Old 07-05-2013, 10:23 PM Thread Starter
Randonexplosion
Deplorable
I haven't done any wheeling lately or any more work on the Jeep. Im gonna get the 233 from my buddy this weekend so hopefully I can get the new skid installed soon. I have a friend with some 35" Maxxis that I can get for cheap but he works out of town so its hard to get a hold of him. It will look sweet with some bigger meats
post #552 of 2285 Old 07-05-2013, 10:27 PM
theGiantPanda
Swap This...
Oh no bigger meats.. Well while the t case is apart.... hmmmm maybe a fuel cell then a home brew long arm and slight stretch... That's how it starts.. Lol !!!!!
the new shop...
shop email....
adding more daily
post #553 of 2285 Old 07-05-2013, 10:33 PM Thread Starter
Randonexplosion
Deplorable
The wheels have already been turning in my brain Was thinking fuel cell and 4 link in the back with a 4-5" stretch. I dont know much about coil suspension though. How would you set it up? Arms couldn't be too long because I need my belly up high.
post #554 of 2285 Old 07-05-2013, 10:43 PM Thread Starter
Randonexplosion
Deplorable
I slide on my leafs quite a bit already but id like to have even more clearance
post #555 of 2285 Old 07-06-2013, 04:53 PM
theGiantPanda
Swap This...
I'm at dinner but ill add more later. Long arming and stretching is a project but it isnt bad at all. "Tentatively" I am going to be starting my shop tj build next week. I am going to long arm stretch and do Fox air shocks on all 4 corners, cheaper than coils. Going to comp cut the rear and run 37s.
It truly is fairly easy to do, time consuming it can be young Jedi. You order All the brackets from artec, joints from Gerald and shocks from downsouth msprts. Couple sticks of Dom... Done ...lol. Only if right !!!!
the new shop...
shop email....
adding more daily
4 link , 5.3 vortec , engine swap
