A YJ 5.3 build without a clever name - Page 34 - JeepForum.com
 28Likes
post #496 of 2285 Old 06-12-2013, 11:23 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
I got the PSC hood louver on. There are 5 bolts that run through some hood braces but it was getting dark so I didnt take the time to drill it out from the underside and I just bolted it up. In daylight it matches better I started the engine and I could definitely feel the air pushing out of the hood. Instead of using a hole saw on the corners like they suggest, I just traced it out and took the grinder to it
Randonexplosion is offline
post #497 of 2285 Old 06-13-2013, 08:52 AM
clintrivera
Hood looks great. You think that will let water in?
clintrivera is offline
post #498 of 2285 Old 06-13-2013, 09:16 AM Thread Starter
Randonexplosion
Deplorable
Thanks I think the general consensus is, yes, but no worse than driving in the rain or hosing the dust/mud off. The main louvers open toward the windshield so water should pass over them while driving, but it would run right in if it was just sitting. But I live in the southwest so I don't need to worry about it much
post #499 of 2285 Old 06-18-2013, 11:26 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
hey man!!! whats up... hope you have been out there tearing it up.. the rocks, not the jeep LOL. i just picked up my shirt order. PM me when you get a second as we got some things to take care of. how is the radiator from superior working. do you think that has anything to with the heat. is your radiator a down flow or cross flow? if its a cross flow, is it the inlet tank on one side and output on the other..OR is is the top half bottom version i see that they make? i am about to order [2] conversion radiators from 'somewhere undecided' and looking for some real time feedback on it. the ebay radiator i used seems decent enough.
going thursday to get the donor 5.3 for the silver bullet. looks like its going to be a 2008 drive by wire with 65k. going to watch them pull it as i recently found out that the 5.3 i was sold from the last junkyard was ACTUALLY a 4.8. the guy who bought it found out when doin the ecu programming. soooo i will be a fricking hawk when i get any LS motors as the 4.8, 5.3 and 6.0 are all identical from the out side. WTF chevy? really. LOL just like ford and their 289, 302, 351 small blocks i suppose.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #500 of 2285 Old 06-18-2013, 11:29 PM
theGiantPanda
Swap This...
ps let me know when you decide to do some mods to that thing and drop in a fuel cell. i am working on abunch of stuff including some fuel cell straps right now with my cad guy. if you have any design ideas, let me know and ill see if i can throw them in the mix. figure they will cost a little more than the basic ones RCI offers but less than anything else out there.
the new shop...
shop email....
adding more daily
post #501 of 2285 Old 06-18-2013, 11:44 PM Thread Starter
Randonexplosion
Deplorable
Damn man, when you reply you dont mess around. Makes it hard to answer all of your questions! On the radiator, I think it is awesome. I cant remember, but I think it is a cross flow, the trans fittings are on the left side. The quality is great and I dont think my problem is with the radiator, I have no shroud and 85% of a fan. I haven't gotten to wheel it with the PSC louver but everything seems cooler on the tub now. You can feel the air flow out of the hood.
I cant believe they gave you a 4.8, I would have been pissed!
post #502 of 2285 Old 06-18-2013, 11:51 PM Thread Starter
Randonexplosion
Deplorable
Also both of the coolant fittings are on the right side. Id say buy local.
And dont ever compare an LS engine to a ford engine
post #503 of 2285 Old 06-20-2013, 06:56 PM Thread Starter
Randonexplosion
Deplorable
My Barnes 4wd skid came in today and it is freaking tough. It will probably be a while before I install it. I want to find a 231c donor and install a wide chain and 6 pinion planetary while I have the skid down, and replace the fluid screen/filter that I broke. I also need to work on my Novak shifter while I have it down and ill need to redo the exhaust bracket on the skid since the new one will be a bit higher.
post #504 of 2285 Old 06-20-2013, 08:13 PM
clintrivera
Looks good. Barnes 4x4 is awesome.
post #505 of 2285 Old 06-20-2013, 08:29 PM
G Beasley
Barnes makes a lot of neat stuff , and their prices are usually great . What are you going to use for a mount ?
G Beasley is offline
post #506 of 2285 Old 06-20-2013, 08:32 PM Thread Starter
Randonexplosion
Deplorable
I saw that you welded some channel in the skid for your trans mount. I might need to do the same thing depending on how much higher it needs to be.
post #507 of 2285 Old 06-20-2013, 08:34 PM Thread Starter
Randonexplosion
Deplorable
Ill keep my Advance Adapters mount. Im not sure what else I could use.
I was very surprised at Barnes prices
post #508 of 2285 Old 06-20-2013, 08:43 PM
G Beasley
We drove by their shop today , would have stopped if they were open . I didnt know if you were going to use a Turbo 350 mount or something of that sort .
post #509 of 2285 Old 06-20-2013, 08:52 PM Thread Starter
Randonexplosion
Deplorable
I believe the stock mount bolts to the OE adapter from 4l60 to transfer case but I replaced that with the AA adapter. I dont know if it has provisions for it. Clint?
Mine uses the t case studs but now that I think about it, there are holes on the underside of the adapter.
post #510 of 2285 Old 06-20-2013, 09:56 PM
clintrivera
I have the stock mount that bolts to the transmission adapter. It as studs, so I raised it up with the channel so the studs wouldn't hang below the skid. If Barnes had a 1" skid, I could have removed the studs and used a tapered Allen bolt up through the skid.
4 link , 5.3 vortec , engine swap
