A YJ 5.3 build without a clever name - Page 28 - JeepForum.com
 28Likes
post #406 of 2285 Old 05-03-2013, 08:55 AM
snail81
Originally Posted by Ripper3494
I sit at 40 all the time. I believe the vette and Yukon pumps are the same. It will fit with a little work. But yea when I step on the gas it's a little slow revving up and a lot of times it will cutout before redline. That being said it's still pretty quick lol
Sent from AutoGuide.com App
Do you think some of it could be your tune?
snail81 is offline
post #407 of 2285 Old 05-03-2013, 09:00 AM
Ripper3494
I run a stock tune.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #408 of 2285 Old 05-03-2013, 09:05 AM
snail81
Not saying that it is the problem. But a performance tune ( a different timing curve, different rev limits) stuff like that might help
snail81 is offline
post #409 of 2285 Old 05-03-2013, 09:31 AM
clintrivera
LS engines need 55-60 PSI. 40 PSI is running lean, possibly lean enough to do engine damage, but certainly lean enough to make it run bad.
Thanks for the exhaust pictures, looks great.
clintrivera is offline
post #410 of 2285 Old 05-03-2013, 09:39 AM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
No problem, and thanks. He did an awesome job on the custom Y pipe. Ill try to snag a closer pic of it.
Speaking of fuel, I grabbed a "vented" gas cap but I am still building quite a bit of pressure in the tank (a lot of pressure releases when I remove it). It is still starting fine though. Think it will cause any problems? Panda mentioned his friend's engine being damaged from it.
Randonexplosion is offline
post #411 of 2285 Old 05-03-2013, 10:12 AM
clintrivera
Doesn't the yj tank have a vent line on it?
post #412 of 2285 Old 05-03-2013, 10:15 AM Thread Starter
Randonexplosion
Deplorable
It does. It ran from the charcoal canister to the tank, but since nothing was going to the canister I pulled it and plugged the vent line down by the tank to keep contaminants out. It is a tiny hose, do you think it would be ok to take the plug out and let it vent on its own?
post #413 of 2285 Old 05-03-2013, 10:18 AM
Ripper3494
mine was like that since i got it. i never had an issue with it. now i have a fuel cell. and i hooked my breather up wrong and the tank pressurized when it got hot out and drained the entire thing onto the lawn... sucked but it was funny as hell. my jeep hates me so much that it siphoned itself
build thread:
RC vs BDS
post #414 of 2285 Old 05-03-2013, 10:19 AM
clintrivera
Mine just goes up to my engine compartment. I'm going to put a little filter on it to keep crap out but I wouldn't plug it
post #415 of 2285 Old 05-03-2013, 10:30 AM Thread Starter
Randonexplosion
Deplorable
How is the lawn?
I was thinking the same thing, but just couldnt think if a filter that small. I guess I could be ghetto and use a little piece of cloth and a rubber band
post #416 of 2285 Old 05-03-2013, 10:43 AM
Ripper3494
How is the lawn?
Dead. Very dead
build thread:
RC vs BDS
post #417 of 2285 Old 05-03-2013, 04:07 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
The fuel tanks need to breathe in and breathe out freely or you guys will have more stories to tell to add to the above mentioned ones. The thing with fuel tank vent lines is that if you don't run them though a charcoal canister you will occasionally smell gas when the tank breathes lol. The little filters on the end will keep some dust out depending on your location but won't "filter out" the gas smell.
As stated above, the motors both the "
LS and Hemi's, need every bit of a reliable 59 psi to run correctly. If you run on to low fuel pressure you will burn up your engine. Maybe not immediately but sooner or later it's gonna happen.
Randon did you remove the evap solenoid from the stick 5.3 set up? The evap stuff pulls vapor from the tank back into the intake manifold.... But your tank still needs a vent LOL
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #418 of 2285 Old 05-03-2013, 04:09 PM
1slowhatch
1991 XJ Cherokee
Hopefully with a 300+ hp Jeep haha
Should be no problem with a 5.3!
1slowhatch is offline
post #419 of 2285 Old 05-03-2013, 04:55 PM Thread Starter
Randonexplosion
Deplorable
Jim, yes I did remove the Evap Purge from the Vortec. It was actually keeping me from closing the hood.
post #420 of 2285 Old 05-03-2013, 04:57 PM Thread Starter
Randonexplosion
Deplorable
I don't know what kind of power numbers I have. Wayne did say that he messed with the tune power wise but I don't think that he goes all out if you are running a stock tranny. At least he said something like that over on Pirate.
I just know that it squats like hell when I step on it
4 link , 5.3 vortec , engine swap
