A YJ 5.3 build without a clever name - Page 13 - JeepForum.com
 28Likes
post #181 of 2285 Old 03-28-2013, 11:57 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
Originally Posted by theGiantPanda View Post
tcm is in the ECU
Ok. I thought since they were each control modules they would be separate. Even though I knew Wayne could set shift points from the pcm.
Randonexplosion is offline
post #182 of 2285 Old 03-29-2013, 12:04 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
I thought that module has something to do with park safety switch etc... IDK what it does exactly yet.. haven't learned that part yet. thanks clint for the insight.
hey can you throw that old shifter cable bracket that mounts on the trans in the box headed this way...?? hmmm now your up to a t-shirt LOL as soon as I get them made
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #183 of 2285 Old 03-29-2013, 12:19 AM Thread Starter
Randonexplosion
Deplorable
Ill do my best. I think im up to a shirt, hoodie an Flexfit hat
What would be on them?
post #184 of 2285 Old 03-29-2013, 12:30 AM
theGiantPanda
Swap This...
ahh t shirt and hoodie... flex fit might take a minute. get me your size and ill make sure it comes out of the first batch.
funny thing is, I just talked to one of my buddies tonight in the garage, turns out he has a connection to a guy that has an embroidery shop
so something like this to start....
the new shop...
shop email....
adding more daily
post #185 of 2285 Old 03-29-2013, 12:35 AM Thread Starter
Randonexplosion
Deplorable
Sounds like my area of the country! Large and 7 1/4! Thats cool man
post #186 of 2285 Old 03-29-2013, 08:25 AM Thread Starter
Randonexplosion
Deplorable
Hey Jim, what exactly do you need from my old shifter? I dont remember pulling that stuff very well. Is it the black bracket in the pic at the top of the page?
post #187 of 2285 Old 03-29-2013, 08:33 AM
clintrivera
Yes, you don't need that. My aftermarket harness didn't even have provisions for it. I actually smashed mine to pieces when I was lowering it into the Jeep. The PCM will need to know if you are in park or neutral, but a simple switch will get you that. I couldn't figure out what output gave me ground in park or neutral so I used a switch that came with my shifter. (before I smashed it, that is)
clintrivera is offline
post #188 of 2285 Old 03-29-2013, 09:05 AM Thread Starter
Randonexplosion
Deplorable
Because of my hatred of wiring I'm sure im gonna need your help with that part! Would using my Lokar Neutral safety switch work?
post #189 of 2285 Old 03-29-2013, 09:17 AM Thread Starter
Randonexplosion
Deplorable
Can anyone tell me the easiest way to remove the clutch pedal? I have the slave assembly removed but the clutch pedal shares a hinge with the brake pedal. I see a nut on the end by the gas pedal, but no way to get a wrench or socket in there because of heater vents.
post #190 of 2285 Old 03-29-2013, 09:49 AM
clintrivera
That would be perfect.
I removed the whole thing to put my automatic pedal assembly on... I don't remember there being any issues?
post #191 of 2285 Old 03-29-2013, 10:02 AM Thread Starter
Randonexplosion
Deplorable
Do I need to replace it with an auto pedal? I figured I could use mine a d just pull the clutch pedal
post #192 of 2285 Old 03-29-2013, 10:14 AM
theGiantPanda
Swap This...
yessir... that one off the trans that the cable locks into.
just so happens, the retard I got parts from yesterday threw a yj auto brake pedal in my box of parts, NOT A TJ ONE. I didn't catch it till I was home going threw everything again. want it?
the new shop...
shop email....
adding more daily
post #193 of 2285 Old 03-29-2013, 10:33 AM Thread Starter
Randonexplosion
Deplorable
**** yeah ill take it. Bracket and all? I should be able to get all this boxed up and out this afternoon.
post #194 of 2285 Old 03-29-2013, 02:32 PM Thread Starter
Randonexplosion
Deplorable
My radiator came in. This thing is nice! I have way more clearance than I thought I was going to. I need to figure something out for a shroud, any ideas?
Even after talking to AA this bracket still doesn't make sense. He said it mounts on the studs at about 1:00 and 3:00.
post #195 of 2285 Old 03-29-2013, 04:43 PM
theGiantPanda
Swap This...
Pic two looks right for the bracket...
Awesome on the radiator!!!!
It's the pedal and bracket... Get me info and ill get it shipped.
I'd use a $30 aluminum shroud off eBay. Then if I wanted a shroud "around" the fan blades... I'd take a piece of 3" or 4" wide thin gauge aluminum and make my circle. Theni'd lay it out and bend about 1" of it, cut reliefs in it and then form my circle again. then insert it through the shroud. finally pop rivet the circle to the shroud face plate. Hiding the bends between the shroud and radiator.
Maybe that's something I'll include in my LS swap kit LOL..
the new shop...
shop email....
adding more daily
4 link , 5.3 vortec , engine swap
