A YJ 5.3 build without a clever name - Page 10 - JeepForum.com
 28Likes
post #136 of 2285 Old 03-27-2013, 08:48 AM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
Thanks for all of the info on fuel fittings guys. I already bought the fittings that Clint linked to earlier. I might go ahead and pick up an AN flare tool.
So now Superior says that my radiator is at the local post office and might be delivered today or tomorrow. What happened to last Friday!?
Randonexplosion is offline
post #137 of 2285 Old 03-27-2013, 08:51 AM
clintrivera
You don't need a flare for the fitting I linked to. It is a compression fitting.
clintrivera is offline
post #138 of 2285 Old 03-27-2013, 09:12 AM Thread Starter
Randonexplosion
Deplorable
I realize that. I was just thinking it would be good to have.
post #139 of 2285 Old 03-27-2013, 09:13 AM
clintrivera
Oh ok. Is that thing running yet?
post #140 of 2285 Old 03-27-2013, 09:17 AM Thread Starter
Randonexplosion
Deplorable
I wish. If I had my harness and PCM back from Wayne I wouldn't be far off. By the time I get them back it should damn near drivable.
post #141 of 2285 Old 03-27-2013, 09:20 AM Thread Starter
Randonexplosion
Deplorable
Clint, what did you do for your intake? I have been reading on them a lot. $200 is a lot for something that im just going to hack up. I thought about piecing one together from intaketubes.com
post #142 of 2285 Old 03-27-2013, 10:02 AM
clintrivera
I used some pieces from Spectre. They have a bunch of different sized bends that worked well with my radiator hoses. I also used their enclosed filter element and will eventually run it into the cowl when I get rid of the factory PCM.
post #143 of 2285 Old 03-27-2013, 11:51 AM Thread Starter
Randonexplosion
Deplorable
Do you remember which filter you used? did you go with 3" stuff all the way? their website isnt wanting to load for me right now.
post #144 of 2285 Old 03-27-2013, 12:54 PM
clintrivera
I think it was this one.
http://www.summitracing.com/parts/spe-9831/overview/
post #145 of 2285 Old 03-27-2013, 01:45 PM Thread Starter
Randonexplosion
Deplorable
Cool that looks good. I measured the throttle body at 4" and the MAF at 3.75". Sound right? I'm working on parts shopping to put my own together here shortly.
post #146 of 2285 Old 03-27-2013, 02:10 PM
clintrivera
That sounds right.
post #147 of 2285 Old 03-27-2013, 04:46 PM Thread Starter
Randonexplosion
Deplorable
For those of you that used the Lokar shifter, I need some help. In Park the shifter arm just barely misses my t case shifter bracket. I cant get it shifted past reverse before it hits the shoulder of a mounting point for the old linkage or whatever it is.
Like an idiot I removed the shifter arm without marking its original orientation but I dont see how moving the arm would help. Like Whyj said "Dear Lokar, your instructions suck"
post #148 of 2285 Old 03-27-2013, 04:52 PM Thread Starter
Randonexplosion
Deplorable
Park
Reverse
post #149 of 2285 Old 03-27-2013, 06:59 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
Man that sucks you are dealing with that shifter issue. One of those things where it takes you 4 hours to set it up!!!
Yeah buddy I think ill stick with the stock auto shifter set up and aftermarket cable!!!!
Who's local post office? Yours or theirs? Hmmm
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #150 of 2285 Old 03-27-2013, 08:11 PM Thread Starter
Randonexplosion
Deplorable
The TJ auto shifter will work on the 4l60? Did you track down a 4wd one? I need to figure out a shifter cable as well. Did you talk to Vito and Tony? I need my damn radiator!
4 link , 5.3 vortec , engine swap
