YES, I know I'm on the WRONG side!!! Crazy thread redux - Page 8 - JeepForum.com
post #106 of 268 Old 03-10-2013, 07:35 PM
aw12345
Originally Posted by TJRHD View Post
You think it will wheel in 35s
Sure it might plow a furrow in the middle though
aw12345 is offline
post #107 of 268 Old 03-10-2013, 07:35 PM Thread Starter
TJRHD
Lol, it be about 2 inches off the ground.
NOT A HATER
TJRHD is offline
post #108 of 268 Old 03-10-2013, 07:38 PM
MO2500
You'll just have to pound the rocks into oblivion with it and it will eventually clear. If at first you don't succeed, just keep trying and it will make it when the rocks get small enough
Instagram: @omsmike
MO2500 is offline
post #109 of 268 Old 03-10-2013, 07:44 PM Thread Starter
TJRHD
Yep, there was a guy that comment on my 70 vs 14 bplt thread. He sail he had shaved everything you could without cutting into the pumpkin. He said he wished he hadnt because it clearanced itself. He said it was in a ultra 4 car now.
NOT A HATER
TJRHD is offline
post #110 of 268 Old 03-10-2013, 07:53 PM
mikeo
Very cool videos, love that terrain!
mikeo is offline
post #111 of 268 Old 03-10-2013, 07:54 PM Thread Starter
TJRHD
Thanks!
NOT A HATER
TJRHD is offline
post #112 of 268 Old 03-10-2013, 08:01 PM
aw12345
Here is some scoop for ya Andrew. My Pitbulls stand 37.5" tall inflated at 30 psi not much bigger than a true 35 at 6 psi, yet I did a whole slew of Hammer trails with them. It helps to learn where your diffs hang out under the Jeep
aw12345 is offline
post #113 of 268 Old 03-10-2013, 08:04 PM Thread Starter
TJRHD
I hear ya! Lots of practice helps. What rear axle are you running mike?
NOT A HATER
TJRHD is offline
post #114 of 268 Old 03-10-2013, 08:32 PM
MO2500
Sterling rear, it has the clearance of a shaved 14 bolt. It does have a pretty good lip on the bottom of the housing and gussets that might catch the edge of some rocks. I'm really careful with tire placement though and feel like I'm pretty good at reading and memorizing the terrain under me. I may attempt to address the lip on the bottom to smooth it out a bit by adding a little plate just to make it slide easier, we'll see.
Instagram: @omsmike
MO2500 is offline
post #115 of 268 Old 03-10-2013, 08:34 PM Thread Starter
TJRHD
Awesome, I have not seen a rig with one in this area but everything I read about them is good.
NOT A HATER
TJRHD is offline
post #116 of 268 Old 03-10-2013, 08:37 PM
MO2500
I've not seen many either but I think they will start becoming more common as newer trucks show up in the JY. The aftermarket is starting to catch up on them, most lockers and gears are available, and they are 35 spline. I'm installing a Yukon air locker and 5.38 gears
Instagram: @omsmike
MO2500 is offline
post #117 of 268 Old 03-10-2013, 08:40 PM Thread Starter
TJRHD
I heard that. I wonder if I can haul that thing in the back of my truck with the tailgate down?? I have a halfton cheby with the short/crewcab bed.
NOT A HATER
TJRHD is offline
post #118 of 268 Old 03-10-2013, 10:03 PM Thread Starter
TJRHD
I just put a bid in on an rci 2161a. I wasn't really planning on it, it just kinda happened.. It's easier to ask for forgiveness than permission right? lol
NOT A HATER
TJRHD is offline
post #119 of 268 Old 03-10-2013, 10:33 PM
aw12345
Strap it down good so it doesn't end up on the road, you most definitely do not want to try and lift that darlin by yourself
aw12345 is offline
post #120 of 268 Old 03-10-2013, 10:36 PM Thread Starter
TJRHD
yep no doubt.
NOT A HATER
TJRHD is offline
