The Yellowtail Build - Page 7 - JeepForum.com
post #91 of 2317 Old 01-03-2012, 10:42 PM Thread Starter
sjones26573
Decided to use part of my $100 Amazon gift card
I bought a pair of http://www.amazon.com/Jeep-Wrangler-Roll-Grab-Handle/dp/B005HAYDR4/ref=pd_ecc_rvi_cart_3
And one of http://www.amazon.com/gp/product/B000JZ79NC/ref=oh_o02_s00_i00_details
And one of http://www.amazon.com/gp/product/B0013LBQBC/ref=oh_o00_s00_i00_details
The Offroad Club @ NC State; Founder
Jeep-Owner.com
sjones26573 is offline
post #92 of 2317 Old 01-04-2012, 06:18 AM
AdamH07
1981 CJ8
Originally Posted by sjones26573 View Post
Anybody know where i can get a really cheap 4 1/2" holesaw? Theyre like $30 online and im only going to use it once to do led tail lights
I bought one a few years back when I did led lights on my '03 Rubi. I am 99% sure I still have it. I will check tonight after work. You are welcome to borrow it and return it. I live about a mile from Concord Mills mall.
'81 CJ8 Scrambler
'07 JKUR
'12 GC HEMI Overland
AdamH07 is offline
post #93 of 2317 Old 01-04-2012, 08:19 AM Thread Starter
sjones26573
Ah that would be great! I could meet you at Concord Mills. But i still need to aquire my reverse lights before i take off the stock lights. But ill definately contact you when I have everything ready. Thanks!
Jeep-Owner.com
post #94 of 2317 Old 01-04-2012, 03:10 PM Thread Starter
sjones26573
Well today i got an email reply from the manufacturer of the led backup lights i was looking at. Turns out they are slightly larger than 4", like i suspected. This means i would have to mount them 2-3" back at the edge of the hole or trim the hole shorter to mount the lights closer to the bumper, or give in and buy the rampage bumper lights, which i really dont want to do. I put the red lights in the back of the holes to get an idea of how deep the lights would sit. I wasnt very pleased.
Jeep-Owner.com
post #95 of 2317 Old 01-04-2012, 08:57 PM
rt4422
That doesn't look too bad, it gives it a unique look. Plus you would never break them
My TJ Build:
rt4422 is offline
post #96 of 2317 Old 01-04-2012, 09:12 PM Thread Starter
sjones26573
Im going to cut the hole tubes down to about 1" in depth. It will still be inset but will sit closer to the bumper so the backup lights have a wider viewing angle.
Jeep-Owner.com
post #97 of 2317 Old 01-04-2012, 09:19 PM
rt4422
Ah good idea, I think that will look better than how they are supposed to look
My TJ Build:
rt4422 is offline
post #98 of 2317 Old 01-04-2012, 10:41 PM Thread Starter
sjones26573
Yea i think so too. I like the recessed look.
I placed the order on the lights. Ill install them next weekend when im back out at the farm.
Jeep-Owner.com
post #99 of 2317 Old 01-05-2012, 11:09 PM Thread Starter
sjones26573
Well, since im doing the flush mount mod, ill lose the rear side reflector required by law. Its probably unimportant, but id figure id find a way to fix it. After searching around, i made the discovery that people have been using amber led bolts as turn signals. I had previously thought light bolts only came in white for tag lights. So this discovery gave me the idea to use red led bolts for a rear side light. I didnt want to drill the tub again so ive decided i could drill a hole on the side of the bumper. I would either run a single led or a line of three. I think i might do the 2 to 3 wire mod. However, i want the turning light and running light without the brake light. But i dont think thats possible so ill probably just suck it up and make them STT lights.
http://www.superbrightleds.com/cgi-b...mini_tubes.htm
Jeep-Owner.com
post #100 of 2317 Old 01-06-2012, 07:12 PM Thread Starter
sjones26573
So im constantly making my led tail light mod more and more complex. I want to put a single pole double throw rocker switch in and wire it to the led backup lights. One part of the switch would allow them to act as normal reverse lights. The other position would allow them to be controlled by a single pole single throw switch that has a constant 12v feed. Then i could use the backup lights as intended or turn them on at my will for rear lighting. My question is: do i need to wire in a relay or can the lights hook straight into the switch? Since they draw less than 1 A together, i imagine a relay is pointless, correct?
Jeep-Owner.com
post #101 of 2317 Old 01-06-2012, 08:57 PM Thread Starter
sjones26573
I finally got my Youtube build introduction video up. Its 20 min.. Heres the link if anybody wants to watch.
Jeep-Owner.com
post #102 of 2317 Old 01-06-2012, 09:46 PM
LA-Sahara
I wished you lived down here man, not many people my age understand my addiction to my Jeep....
I fully understand. Where you ride at?
To the OP, love the jeep man! When I was little I always wanted a yellow vehicle and if I hadn't of gotten my jeep, Definately would have gone with a yellow one. Love the yellow and black look. I really enjoy messing with wiring and stuff too. Today I just got done wiring up some strobe lights on my four wheeler. You should look into wiring an in-cab winch controller. That was one of thefirst mods on my jeep. Very easy to do, especially for you. Keep up the great work!
LA-Sahara is offline
post #103 of 2317 Old 01-06-2012, 10:06 PM Thread Starter
sjones26573
Thanks man! I had the same want as a kid. I just acted on it! I plan on doing an in cab controller but i want a switch panel from 12voltguy.com with one built into it. Since i plan on getting that, the "cord swung over the mirror" tactic will have to work for now.
Jeep-Owner.com
post #104 of 2317 Old 01-06-2012, 11:02 PM
LA-Sahara
I gotcha. Yea, his stuff is pretty neat. Just a shot of my setup incase you change your mind. Another electrical thing I did was add step lights for when you're getting out, they light up the ground. And some pics of my trunk light and tailgate door trigger. Some easy, cheap, but cool mods.
post #105 of 2317 Old 01-06-2012, 11:46 PM Thread Starter
sjones26573
I was thinking of doing some door lights but i never have my doors in during the summer so the fuse is pulled. I thought about hooking it into pod light circuit, but since im using a roll of blue led strip lighting for lighting projects, i figured blue door lighting would get washed out by the white. And i dont have a trunk thanks to my subs. However, i did do this:
Jeep-Owner.com
nc guys
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
