The Yellowtail Build - Page 6 - JeepForum.com
post #76 of 2317 Old 12-23-2011, 11:41 PM Thread Starter
sjones26573
Originally Posted by WINGNUTT611 View Post
Love your Jeep man. Ive always liked the yellow and black color combo. Keep up the good work!
Thanks!
Originally Posted by rt4422 View Post
Just in case you need LEDs in the future, don't use radioshack. Try this http://www.oznium.com/led
Why?
And does anybody know where I can get round illuminated 120v rocker switches in green, red and yellow (or amber)? Im going to be adding some switches to my stop light at home and the yellow rocker is difficult to find.
The Offroad Club @ NC State; Founder
Jeep-Owner.com
sjones26573 is offline
post #77 of 2317 Old 12-24-2011, 12:04 AM
4wheelrampage
Stop light at home? Am I missing something? But you might be able call 12voltguy or someone similar and see if they can't whip you up something. But if all else fails, id get white or clear ones and put a yellow either film or transparent paint on them. Idk just my first thoughts.
Originally Posted by ApolloXIII
Tasting a drop isnt going to kill you.
And what doesnt kill you makes you stronger.
Therefore, tasting a drop of antifreeze actually makes you stronger :)
Mac users : control+option+command+8
4wheelrampage is offline
post #78 of 2317 Old 12-24-2011, 12:37 AM
rt4422
Why?
Check those prices! So much cheaper
My TJ Build:
rt4422 is offline
post #79 of 2317 Old 12-24-2011, 11:26 AM Thread Starter
sjones26573
Yea, big yellow street stop light. Runs off of 120v wall plug. I want to build a box on top of it with a SPDT switch and three SPST illuminated switches. The I on the SPDT switch would go to the controller that cycles the light, while the II would be wired to the three other switches. These switches would be wired to each light so i could turn on and off as i please. I want the SPST switches to be illuminated to match the color they control. This setup would give the option of cycling or steady on with each light controllable. Just a little home project to test my skills. Posted on here because alot of guys here know where to find switches.
Jeep-Owner.com
post #80 of 2317 Old 12-24-2011, 11:46 AM Thread Starter
sjones26573
Alright so I just got a Amazon gift card for $100 and definately will be spending it on the Jeep. I would like to get my Tcase skid back to flush. Should I get a Zone 2" body lift or MORE 1" motor mount lift? I was never clear on which was more important. I need at least a 1 1/4" body lift for my eventual UCF TT.
Jeep-Owner.com
post #81 of 2317 Old 12-25-2011, 08:43 AM Thread Starter
sjones26573
Woohoo! Got a Rampage bumper/tire carrier for Xmas! (I wanted a LoD, but it was a gift). Now I can do my led tail lights!
Jeep-Owner.com
post #82 of 2317 Old 12-25-2011, 04:04 PM Thread Starter
sjones26573
So I've gained $450, a $100 amazon card, and a $25 visa card. I would like to work on removing my tcase drop. What should I blow the dough on to get it gone?
Jeep-Owner.com
post #83 of 2317 Old 12-26-2011, 07:29 PM Thread Starter
sjones26573
2 JL Audio 10W3V3-4 subwoofers and a JL Audio XD600/1 monoblock amp installed today!
I had to tape over the vent because the sound was blowing out so hard it was rattling the vent.
Jeep-Owner.com
post #84 of 2317 Old 12-27-2011, 12:30 AM Thread Starter
sjones26573
I picked up the center cap for my spare wheel from the local wheel shop that i had ordered over a month ago. Grabbed an led and holder from RadioShack that were out of stock last visit. Then, i drilled the fake plastic bolts, put in the snap holders, and wired in the leds. The result is pretty awesome!
Jeep-Owner.com
post #85 of 2317 Old 12-27-2011, 03:50 PM
rt4422
Nice, pretty ingenious
My TJ Build:
rt4422 is offline
post #86 of 2317 Old 12-28-2011, 11:29 AM Thread Starter
sjones26573
Heres the pics of it installed
2 1/2" washers on each wheel lug to space the wheel enough to run the wiring.
The washers also helped move the tire off of the bumper a lottle so it won't rub the paint off anymore, although i wont have the stock bumper for very much longer
The wire runs through the holes for wheels with a larger bolt pattern and squeezes between the wheel and mount.
it was impossible to wire the light before mounting the wheel, but it was extremely difficult to wire it once the wheel was already mounted.
The black plastic snap in holders match well and hide the evidence of drilling.
The clear lights match the silver accents well
Lit!
From straight on.
Once i install my rampage recovery bumper/tire carrier, i can wire the floods as reverse lights and put 4" round led tail lights in. This mod will look great with those.
Jeep-Owner.com
post #87 of 2317 Old 12-28-2011, 04:55 PM
4wheelrampage
That is bar none the best way I've seen leds in the rear wheel. Well done sir
post #88 of 2317 Old 12-28-2011, 05:17 PM Thread Starter
sjones26573
Thank you! It could be done on about any black wheel that has a plastic cover. Just needs 5-6 evenly spaced flat surfaces. I was just lucky enough to have the fake bolts in a circle.
Jeep-Owner.com
post #89 of 2317 Old 12-29-2011, 07:59 PM Thread Starter
sjones26573
Anybody know where i can get a really cheap 4 1/2" holesaw? Theyre like $30 online and im only going to use it once to do led tail lights
Jeep-Owner.com
post #90 of 2317 Old 01-03-2012, 07:07 PM Thread Starter
sjones26573
Some pics of my new Rampage bumper
Finally convinced my dad to let me cut holes in the tub (yes i still have to do that). I picked up a pair of Blazer 4" 10 led STT lights from Walmart for $33. I used my in room 12v power source (aka rc battery charger) to light them.
For my backup lights, I want to install this (http://www.amazon.com/Backup-Reverse-Light-Utility-Trailer/dp/B002B8AUZO/ref=cm_cmu_pg__header) led light but im not sure it is going to fit. The red lights are slightly too wide but the white lights claim to be only 4".
Jeep-Owner.com
nc guys
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
