The Yellowtail Build - Page 51 - JeepForum.com
post #751 of 2317 Old 12-27-2012, 01:04 AM Thread Starter
sjones26573
Originally Posted by mcannon111 View Post
Ohh okay I didn't see that option when I looked I thought it just came with the stock location one.
I have to say you had me thoroughly confused with that one. I should have realized when you said adj track bar. Yes, hi steer offset track bar mount is an option.
The Offroad Club @ NC State; Founder
Jeep-Owner.com
sjones26573 is offline
post #752 of 2317 Old 12-27-2012, 08:27 PM
LA-Sahara
So Seth, I'm now planning on swapping in a HP30. Probably going get it next week. Was wondering what balljoints, if replacing them, are you going with?
LA-Sahara is offline
post #753 of 2317 Old 12-27-2012, 08:58 PM
Jankoid
Somebody hasn't been keeping up with this thread!
He scrapped the HP30 idea a while back in favor of a waggy44. You should always stick with the spicer ball joints though.
Jankoid is offline
post #754 of 2317 Old 12-27-2012, 09:15 PM
LA-Sahara
Oh, I knew he ditched it. Just figured he was getting some for the 44, or he had researched them for the 30.
post #755 of 2317 Old 12-27-2012, 09:24 PM
Jankoid
The waggy 44 uses completely different ball joints than a Dana 30. Like I said though, stick with Spicers.
Jankoid is offline
post #756 of 2317 Old 12-27-2012, 09:39 PM
LA-Sahara
Gotcha. Thanks.
post #757 of 2317 Old 12-27-2012, 10:32 PM Thread Starter
sjones26573
Lol.
I've just been sitting here in WV for the last few hours looking at how I'll be setting up the 3-link, mostly how long my links will be. Looks like they will be around 30 in so I should be good with ordering 6' of 2" x .25" DOM for the lowers and 3' of 1.75" x .125" DOM for the upper, in addition to 1.5" x .25" DOM for the steering. I'm guessing I'm going to need about 8-9' for the panhard/drag link/tie rod.
Jeep-Owner.com
post #758 of 2317 Old 12-27-2012, 10:41 PM
Jankoid
Why not use the same size dom for the uppers as the lowers? They should be using the same size joint, use the same tubing and skip buying 2 different sizes.
Jankoid is offline
post #759 of 2317 Old 12-27-2012, 11:02 PM Thread Starter
sjones26573
For wanting to use 2" on the lowers but wanting to save on the upper which won't see abuse. They will use the same joint. Why does it matter if they are the same size? They are coming from the same place and 3' of 1.75 x .125 is cheaper than 3' of 2 x .25
Jeep-Owner.com
post #760 of 2317 Old 12-27-2012, 11:14 PM
Jankoid
The upper may not see as much abuse, but remember that you will only have one arm doing the same job that you used to have 2 arms doing. It is going to have a lot of pressure on it when flexing because of that. I would want the upper to be as strong as possible. If it fails it won't be pretty. Food for thought.
It also might not be a bad idea to order enough tubing to make at least one extra arm. Then you are covered if you mess one up while making your arms or ever damage one and need to replace it.
Jankoid is offline
post #761 of 2317 Old 12-27-2012, 11:26 PM Thread Starter
sjones26573
I do understand the extra forces on the sole upper. I have looked around and it seems 1.75 is sufficient for the upper. But don't get me wrong, I would rather do overkill than risk breaking it later. And thats not a bad point on the extra tube. Hate to spend the money but spares are always nice. I'd like to get all of the links close to the same length for that reason but I'm not yet sure how probable that will be if I play with the 3 link calc any. I know not necissary but I'd like to get it as smooth as possible.
Jeep-Owner.com
post #762 of 2317 Old 12-27-2012, 11:28 PM
mcannon111
I had 4 ft of 2x.250 wall for lowers, 2ft of 1.75x.120 wall for uppers, and 6 ft for a panhard and drag link. I had about 8 inches to spare on my lowers, 6 on the upper, and about a foot on the drag link/panhard.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #763 of 2317 Old 12-27-2012, 11:30 PM
mcannon111
And my upper is smaller, no real reason to get that big of an upper. Chris may runs that size tube in his race car with a 3 link front and sticky 40 treps. It holds up fine. But some people feel better with a larger upper. To each his own
post #764 of 2317 Old 12-27-2012, 11:36 PM Thread Starter
sjones26573
Wow. Those are some long lowers. I'll have to take a measuring tape to it when I get home.
Jeep-Owner.com
post #765 of 2317 Old 12-27-2012, 11:48 PM
mcannon111
No 4 ft for both lowers. My arms are like 24 inches eye to eye I think
Edit: never mind 26 and a quarter just remembered
nc guys
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
