The Yellowtail Build - Page 147 - JeepForum.com
post #2191 of 2317 Old 07-08-2014, 05:26 PM Thread Starter
sjones26573
Yay! No hub caps!
Those things look huge on there.
Just for you... and the guys at DT.
They make dad's Nitto's look small.
The Offroad Club @ NC State; Founder
Jeep-Owner.com
sjones26573 is offline
post #2192 of 2317 Old 07-08-2014, 05:38 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Great tires
May TJ of the Month 2015
TexasTJ is offline
post #2193 of 2317 Old 07-08-2014, 05:40 PM Thread Starter
sjones26573
Originally Posted by Cavasar View Post
Great tires
We shall certainly see. They better be friggin amazing for what I paid. The 15-17 difference blows my mind.
Jeep-Owner.com
post #2194 of 2317 Old 07-08-2014, 10:18 PM
LA-Sahara
Might have missed it somewhere but why not the MTZs again? I thought you really liked them. Price? Availability?
Looks sweet though!
LA-Sahara is offline
post #2195 of 2317 Old 07-08-2014, 10:30 PM Thread Starter
sjones26573
Looks sweet though!
Wanted to see what all the fuss was about.
Jeep-Owner.com
post #2196 of 2317 Old 07-08-2014, 10:34 PM Thread Starter
sjones26573
Rock lights finally finished. Also put top/doors back on and packed it for Windrock.
Jeep-Owner.com
post #2197 of 2317 Old 07-09-2014, 04:16 AM
goldensahara00
Glad you got them on and hope you like them. I like siping mine for the winter and I'm looking at adding some grooves to this set once I get some miles on them first though. Looks good man. The difference in tire price for 17s over 15s in anything is almost always stupid.
American Jeepers Founder
Wheeling the East Coast
goldensahara00 is offline
post #2198 of 2317 Old 07-10-2014, 07:01 AM
JCJeep97
Looks nice. Rock lights are pretty much the biggest pain in the *** project ever.
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #2199 of 2317 Old 07-12-2014, 04:21 PM Thread Starter
sjones26573
Finished up day 3 of wheeling. Long ride home in the morning.
Jeep-Owner.com
post #2200 of 2317 Old 07-18-2014, 09:19 PM Thread Starter
sjones26573
After looking around for a week or so for an external locking draw latch for my CJ gate on sites like McMaster Carr and Grainger, I ended up stumbling across a trailer build forum with the perfect solution. Then, come to find out, we already had a brand new set sitting in a box in the garage. And best of all, they are a made-for-Jeep product, just not quite this application. Figured it out?
Rampage JK Locking Hood Latches. They are powder coated stainless instead of the powder coated zinc latches on the hardware sites, which would corrode in no time. Only extra step was to cut a 3/4" hole in the back of the tailgate to get the nut on.
Thread: http://tventuring.com/trailerforum/thread-309.html
In addition, I pulled the old tag light off my stock tailgate and wired it up until I find a solution I like. Also picked up a piece of 4'x4' 1/4" Steel Angle from the metal shop near my work to build the CJ cable brackets. Only wanted 6" but he found an 11" piece in the scrap pile so he just gave me the whole piece for $5. Picked up some stainless hex bolts for the hinges since the black oxide Grade 8 machine screws started rusting immediately. I have come to terms that I will have to settle for hex since I can't find another 5/16" 3 1/2" Allen Machine Screw like the PO gave me to save my life.
Jeep-Owner.com
post #2201 of 2317 Old 07-21-2014, 09:57 PM
Bedwell
1984 CJ8
Since your build thread is hundreds of pages / thousands of posts, would you mind sharing some more info about the wagoneer 44 swap?
From your first page post and some info I have been gathering:
1980+ Wagoneer Axle
TNT Truss
Chevy Small Bearing Spindles 706528x
Ford Hubs / Rotors
Chevy Brakes / Pads
Gears, Locker, Install Kit, etc.
Locking Hubs
What about steering? Are you planning to run hi-steer? Are different knuckles required?
Subscribe to my YouTube Channel:
https://www.youtube.com/user/RockCrawlinJeeps
Bedwell is offline
post #2202 of 2317 Old 07-23-2014, 09:53 AM Thread Starter
sjones26573
1980+ Wagoneer Axle
TNT Truss
Ford Hubs / Rotors
Chevy Brakes / Pads
Locking Hubs
Chevy flat top knuckles drilled for hi steer arms are required for hi steer. I'm thinking about doing an all OTK steering and welding a bracket to put it into double sheer, since that'd be a significant amount of stress on the bolt. I'll be using Ruffstuff 7/8" heim steering.
Jeep-Owner.com
post #2203 of 2317 Old 07-26-2014, 08:35 PM Thread Starter
sjones26573
Installed the new antenna mount and got my antenna back on. In the process I managed to accidentally drill an extra hole, slightly dent in the tub using a screw as a punch, and then majorly dent out the tub trying to get the first dent out but hitting too hard and too far over. Managed to mostly straighten it out with a hammer and paper booklet (padding) but the dents and cracked paint are pretty obvious if you're looking for it. It'll all be covered in armor before too long so I'm not beating myself up about it. Overall happy with the turnout. Best of all, I can now get in the garage without pulling the antenna.
While I had the grinder and cutoff out (had to trim the mount's reinforcement plate to fit it under the tub rail), I cut the end of one of my extra Fabtech LCA's off to measure the ID. Going to order some tube inserts and Duroflex joints to put on one end of the extra arms and swap them out in the front. The joints will eventually get recycled for my 3 link/axle swap later in the year.
Jeep-Owner.com
post #2204 of 2317 Old 07-28-2014, 09:26 PM Thread Starter
sjones26573
Death Wobble came back at full force. Hit about 40 and the slightest bump and it instantaneously went into bezerk mode. First I notice a lot of play in the tie rod and an odd dead/rough spot in it when twisting it. I could tell it was the outer plus the grease inside, which I had just recently greased, was black and metallic. So I swap that for the Napa TRE off my bent ZJ rod. Tie rod no longer had play and I thought I was out of the woods. Off for dinner and it's worse then before. Now I'm worried I'm not getting to work in the AM (I commute 1/2-1 hour, depending whose house I leave from, at 6 AM). I start checking bolts, only finding a slightly loose lower CA bolt and snugging up the others. Then we start thinking the tires look odd. Go to check alignment and it was over 1" toe-in (ironically we thought it was toed out looking at it). I hadn't bothered re-aligning it after mounting the MT/R's since it was dead on before. Glad the DW arose before it damaged the new tires. Adjusted it several times, taking it up the block and back each time to see where it'd settle. Got it to 3/16" in, adjusted it out a hair, and took it for a final spin out to the I-85 overpass and back (the area I had had repeated DW earlier), pretty much letting the wheel do what it wanted. It'd only occasionally lightly shimmy, and killed itself out with no input from me after only a second or two. I'm not convinced it won't return, but we got it for now and I can go to work in the morning.
Jeep-Owner.com
post #2205 of 2317 Old 07-29-2014, 03:28 AM
goldensahara00
Don't you love the random DW. I get a little wobble action from the trackbar bolt that always seems to loosen itself. Glad you get it figured out.
nc guys
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
