The Yellowtail Build - Page 131 - JeepForum.com
post #1951 of 2317 Old 12-09-2013, 03:19 PM
Kodiak17
Originally Posted by sjones26573 View Post
I don't mind the work, its the pricetag that makes me cringe, and the thought that it could be the trans again. I am not ready for trans #4.
Right. I'm always thinking of the worst when the jeep makes a noise, like how am I going to afford some type of powertrain or axle swap
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #1952 of 2317 Old 12-09-2013, 03:32 PM Thread Starter
sjones26573
If it's the 30 acting up (which is unlikely) I was looking to swap the 44 in over winter anyways. Just need wheels for the new bolt pattern.
The Offroad Club @ NC State; Founder
Jeep-Owner.com
sjones26573 is offline
post #1953 of 2317 Old 12-09-2013, 04:04 PM
Jankoid
I do remember my dad saying the truetrac would make a clacking noise from time to time, could be that.
Jankoid is offline
post #1954 of 2317 Old 12-10-2013, 07:44 AM Thread Starter
sjones26573
Yea, I was curious about that as well, but I've stomped on it thousands of times no problem and it just now becomes an issue, which is getting easier and easier to initiate.
Jeep-Owner.com
post #1955 of 2317 Old 12-10-2013, 09:36 PM Thread Starter
sjones26573
The popping is so bad now I can't move in first without it happening. It is rapid fire and doesn't affect power. I am deathly afraid it is the trans.
Jeep-Owner.com
post #1956 of 2317 Old 12-11-2013, 05:50 PM
mncdriver
1987 YJ Wrangler
I would pull front drive shaft and see if noise goes away, if not, then try and isolate it. Could be u-joint in front axle shafts, or even joints in rear drive shaft.
mncdriver is offline
post #1957 of 2317 Old 12-11-2013, 06:55 PM Thread Starter
sjones26573
Using this guide as reference
http://www.onallcylinders.com/2012/0...veline-noises/
It seems like the best explanation would be a chipped pinion gear tooth or 2.
Noise: Banging or heavy clicking every two to three feet during acceleration or deceleration, but not both
Cause: High spot or heavy chip on pinion gear tooth
Only thing is it isn't constant but is quickly becoming constant.
Jeep-Owner.com
post #1958 of 2317 Old 12-11-2013, 07:02 PM
Jankoid
That sounds very plausible now that you mention it. Very well could be a couple of chipped ring gear teethe in the front. As it wears more the ring gear will get stuck in that spot and the pinion gear will grind against it. I've seen it happen on the trail when a guy blew his front lp30 and had to drive off the trail afterward. Easy way to tell is to pull the front driveshaft. If that is the case you can drive home just fine.
Jankoid is offline
post #1959 of 2317 Old 12-11-2013, 07:06 PM Thread Starter
sjones26573
I don't suppose that would be Mason you are referring to as "a guy"?
However, how would removing the front shaft change anything if it's in 2wd? No locking hubs so the diff will still be spinning.
Plus it seems to me it'd be more likely to be the rear since it's 2wd/torque related.
Jeep-Owner.com
post #1960 of 2317 Old 12-11-2013, 07:11 PM
Jankoid
No, Mason is not who I'm referring to. I wasn't there when he blew his d30.
You said you could feel it in the shifter right? Removing the driveshaft would alleviate that. I seriously doubt it is the rear, you would've fragged the gears by now if it was. The problem would be much more obvious.
Jankoid is offline
post #1961 of 2317 Old 12-11-2013, 07:15 PM Thread Starter
sjones26573
You said you could feel it in the shifter right? Removing the driveshaft would alleviate that. I seriously doubt it is the rear, you would've fragged the gears by now if it was. The problem would be much more obvious too.
I can feel it in the shifter, which I wouldn't think I would be able to feel the front. And it has gotten really bad, really fast. Much worse than what you saw at URE. Bad enough that I can't drive it in fear if it fragging.
Jeep-Owner.com
post #1962 of 2317 Old 12-11-2013, 07:20 PM
Jankoid
You can try pulling the rear shaft and driving around fwd, but I find it highly unlikely that would be the problem. The front is spinning just as much as the rear, so you'll feel it just the same if something is wrong. Just try pulling the shafts seperately and see if you can isolate the issue.
Jankoid is offline
post #1963 of 2317 Old 12-11-2013, 07:21 PM Thread Starter
sjones26573
I'll do that, but it'll have to wait until tomorrow after my last final unfortunately.
Jeep-Owner.com
post #1964 of 2317 Old 12-11-2013, 07:25 PM Thread Starter
sjones26573
I hope it is the 30 because the 8.8 would entitle a hell of a lot more work.
Jeep-Owner.com
post #1965 of 2317 Old 12-11-2013, 07:31 PM
Jankoid
Nah, just a really good excuse to put those 4.88s in!
Jankoid is offline
nc guys
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
