yellow submarine build - Page 12 - JeepForum.com
post #166 of 415 Old 01-07-2013, 10:11 PM
AngryTJ
lookin real real good scott!
AngryTJ is offline
post #167 of 415 Old 01-07-2013, 10:18 PM
MO2500
x2
The stack of goodness in my garage will make it look better
Instagram: @omsmike
MO2500 is offline
post #168 of 415 Old 01-07-2013, 10:21 PM Thread Starter
ScottD16
Originally Posted by MO2500
x2
Your including the axles to!! Wow your the best
JEEP BUILD better late than never
I like to do the photography Flickr-
wheeling pictures and other random stuff Photobucket
ScottD16 is offline
post #169 of 415 Old 01-07-2013, 10:29 PM
MO2500
Ha, everything in my garage can be included*
*additional items subject to a $50k "handling and restocking" fee
Instagram: @omsmike
MO2500 is offline
post #170 of 415 Old 01-08-2013, 05:31 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
How do you plan on laying the sheet metal? tube exposed or more stock looking?
Anyways, love the build, crawled.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #171 of 415 Old 01-09-2013, 06:22 PM Thread Starter
ScottD16
Thanks! The plan is to have the sheet metal come down on the outside of the inner tubing so tube will be showing on the inside of the trunk. Then another piece will come from the outside tube to the top of the inside.
Friday or Saturday I should have a layout made for it, Didn't do any work on the jeep today because yesterday I went Snowboarding and Popped my shoulder out in the park, hurt to much to be fooling around in the garage. I did mess with it a little yesterday when I got home though. Worked on reinforcing the back of the body since it was all cut up and here is my solution.
Welded a piece of steel to the back of the body where the headlights where. Dad welded most of it since welding with one arm wasn't really working for me.
Picked up some goodies today thanks to MO2500
ScottD16 is offline
post #172 of 415 Old 01-09-2013, 06:41 PM Thread Starter
ScottD16
Anyone have any ideas on the best possible way to integrate a shock mount into the rear fenders? I thought maybe another straight tube across from the inside to the outside but not sure if that would be sturdy enough. The structure of the soon to be fender is welded to plate which is welded to the floor which will soon be bolted down as well I think that should be enough to keep some shocks from ripping it up.
ScottD16 is offline
post #173 of 415 Old 01-09-2013, 07:08 PM
MO2500
No problem bud, should look great on your Jeep!
If you run a tube straight across and tie the fender structure into the unibody you should be fine mounting shocks off the inner fender tube-work IMO. Once you add a cage you could do additional reinforcement.
Instagram: @omsmike
MO2500 is offline
post #174 of 415 Old 01-09-2013, 07:11 PM
AngryTJ
those wheels are going to look awesome on your jeep scott!
Why dont you run an upper mount like this one off the inner tube...
AngryTJ is offline
post #175 of 415 Old 01-09-2013, 07:15 PM
ibjeepin95
ERMAGHERD!
ibjeepin95 is offline
post #176 of 415 Old 01-09-2013, 07:18 PM Thread Starter
ScottD16
Yea I cant wait to get them mounted and crawl up walls!
I was thinking of something like that just need to see if it would stick out far enough to be on top of the leaf spring plate.
ScottD16 is offline
post #177 of 415 Old 01-09-2013, 07:54 PM
CDW_327
Haha hurt your arm boarding man? I completely tacoed my self on a 25 foot rainbow rail trying a switch front board on Sunday and I have some sore ribs now haha. Back when I was in high school it didn't matter if I got hurt but now with work it's getting harder and harder to ride at the level I used to.
CDW_327 is offline
post #178 of 415 Old 01-09-2013, 10:05 PM Thread Starter
ScottD16
That's probably what I will end up doing and throw on one of those brackets lu posted or make one of my own. I'll look at it all friday hopefully.
ScottD16 is offline
post #179 of 415 Old 01-09-2013, 10:10 PM Thread Starter
ScottD16
I just got back from boarding in Canada for a week which was amazing! Yesterday I go to a local resort and conditions kinda sucked but for the first hour I was playing in the park hitting the rails and jumps, last run I front board a slightly kinked rail and overcompensated and crashed down on my shoulder. Hit the rail perfect two other times and this last one got me. It sucked ha
ScottD16 is offline
post #180 of 415 Old 01-15-2013, 11:40 AM
AngryTJ
When are we going to see those rims mounted?
AngryTJ is offline
cherokee , comp cut , flowmaster , rough country , tube bender
build thread: yellow tj jeepy01 Jeep Builds 60 12-29-2011 06:32 PM
My 06 Solar Yellow TJ Build dylanvass Jeep Builds 52 10-19-2011 11:05 AM
My Lil Yellow TJ Build GroceryGetter01 Jeep Builds 130 04-20-2011 10:44 AM
yellow tj build kodykin Jeep Builds 5 02-04-2011 07:03 PM
Yellow TJ build 2002YellowTJ Jeep Builds 3 01-26-2010 04:50 AM
