Yello - HEMI'd and LCoG TJ on 40's ~ A multi-year affair - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Yello - HEMI'd and LCoG TJ on 40's ~ A multi-year affair
VIAIR compressors at ROCKRIDGE4WD!! DEALS INSIDE!50" LED CREE Light Bar Pair With Wiring KitIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-12-2014, 07:30 PM   #1
gecko5
Yello - HEMI'd LCoG TJ
After much contemplation, flipping back and forth, reviewing finances, getting the blessings from the boss, checking my psyche, i have decided to go ahead with implanting the HEMI into the Yellow TJ that i bought Sept 2012. After selling O.D. in October 2010, i have been unable to sleep. Nightmares routinely ruin my nights and i randomly break out in sweats. At least that's the story i am going with....... I have decided that to ensure that the rest of the TJ will match up with the ponies i am adding to the 2004 Rubi i bought in Sept 2012:
- Tons
- An ATLAS 3.8.1
- Triangulated rear, stretched about 4-5", ORI's
- Hylined front and rear
- Drop down tailgate
- 40's on beadlocks
- Hydro Assist
My first concern were the axles. I did not want to go full width as i still want to fly under the radar on the roads with this and still make it through the narrow trails around here without having to climb up the sides of every tree. I kept my eyes open on most boards on a very regular basis. There was always something missing (Either the gearing, steering or width or carrier). I then pondered the notion of getting a set cut down (Not having the skills / tools to do it myself) and I even went so far as to buy a set of early '80's but as i researched more and more i found that to be too expensive and tedious. I considered buying new already built but once i started seeing the $$$, i said fakk that. I had pretty much given up, even had the custom frame and HEMI setup up for sale and then bam.... Found the axles off Pirates. 13hrs of driving later after less than 48hrs of coming across them online (As I had to re-act as the seller had a lineup to buy them), I had them in my possession.
- 1979 D60 Snowfighter, cut down to 65"WMS, dutchman 35 splines, detroit, 5.13's, setup for XJ, coils and hydro assist.
- Mid-80's CC 14 Bolt, disc's, detroit and 5.13's, setup for triangulated rear and coils
Still fit in the garage.... This is key. I had taken some measurements on Yello with the 35's and i had about 1/2" or clearance
I gotta say, at first i hated the yellow color but now after wheeling for a year, it's actually not that bad.
Current: Yello
Past: OD
gecko5 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2014, 07:35 PM   #2
gecko5
Some pics of progress to date:
Current: Yello
Past: OD
Unread 01-12-2014, 07:40 PM   #3
gecko5
Some goodies that i have been acquiring:
Current: Yello
Past: OD
Unread 01-13-2014, 07:28 AM   #4
bu5150
Nice...who's rear bumper is that?
'06 LJ, RJ 60's, 5.38's, TnT Customs Suspension, 40" MTR's,TG Creeper Locks
bu5150 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2014, 07:44 AM   #5
gecko5
Genright..
http://www.genright.com/ProductInfo....0#.UtP7rvviTNo
Current: Yello
Past: OD
Unread 01-13-2014, 08:48 AM   #6
csdilligaf
Oh, this is going to be a fun build to watch. What are the wheels? I run H1's and really don't follow the wheel market but I like those.
csdilligaf is offline   Reply With Quote Quick reply to this message
Unread 01-13-2014, 08:53 AM   #7
AngryTJ
AngryTJ's Avatar
All those amazing products and your doing a radius arm front suspension?
Tarantula_TJ Build
2015 Colorado Trip
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 01-13-2014, 09:00 AM   #8
gecko5
Point?
I personally have no issues with Radius arms and when you take into consideration clearance issues with the hemi, So far all the builds i have seem are sticking with Radius arms. I had the clayton kit on my last build and absolutely loved the flex and on-road characteristics. Lastly, the axles i had bought already had the radius arm mounts in place. I know that there are potential clearance issues running say a 3 link and the possible need for a truss on the axle. It works for me
Current: Yello
Past: OD
Unread 01-13-2014, 09:00 AM   #9
gecko5
Raceline AL Monster Beadlocks
Current: Yello
Past: OD
Unread 01-13-2014, 09:43 AM   #10
AngryTJ
AngryTJ's Avatar
Originally Posted by gecko5
Point? I personally have no issues with Radius arms and when you take into consideration clearance issues with the hemi, So far all the builds i have seem are sticking with Radius arms. I had the clayton kit on my last build and absolutely loved the flex and on-road characteristics. Lastly, the axles i had bought already had the radius arm mounts in place. I know that there are potential clearance issues running say a 3 link and the possible need for a truss on the axle. It works for me
Simply wouldn't be my first or second choice due to binding and unloading characteristics of a radius arm suspension.
Your rig your money... I'll be watching the progress
Tarantula_TJ Build
2015 Colorado Trip
Unread 01-13-2014, 05:43 PM   #11
daddyjeep87
1987 YJ Wrangler
I will be following this one. I love the direction you are headed.
87YJ 5.2/46RH/NP231 D44/9in 4.56 4 link rear, radius arm front
My Build http://www.jeepforum.com/forum/f22/daddyjeep-121-day-87-yj-5-2-lcg-4-link-build-1479204/
Start planning for 2014, updated site http://www.bantamjeepfestival.com/
daddyjeep87 is offline   Reply With Quote Quick reply to this message
Unread 01-19-2014, 02:54 PM   #12
gecko5
Been busy!!!
On the D60.. I just decided to cut the brackets off. Ordered some replacements from TMR and got that in place. Man those existing brackets were a P I T A to get off:
http://lh3.googleusercontent.com/-q...Large%2529.JPG
http://lh3.googleusercontent.com/-9...Large%2529.JPG
http://lh5.googleusercontent.com/-7...Large%2529.JPG
Also finally got the 14 bolt rebuilt and put back together. Still missing a caliper (Gotta pick it up) and i want to add a pinion guard. But other than that, all the bearings, races and seals are good to go.
http://lh4.googleusercontent.com/-L...Large%2529.JPG
Got pretty much all of the grease and undercoating removed from the underside of the tub:
http://lh5.googleusercontent.com/-m...Large%2529.JPG
Then started mocking up the rear.. Since the tub wasn't on, i lay the stretch corners on the tub, found the center, then related that to the body mount at the back. Then transposed that to the frame for reference on where the center would be with a 4" stretch.
http://lh6.googleusercontent.com/-M...Large%2529.JPG
I started doubting myself a bit too much though and after a while i decided that i'd be better off just putting the tub back on for mock up. I would have needed to anyways for the next step of putting the motor in so....
I had so much problems though removing it with the cage and windshield on that i decided to first remove these.
http://lh6.googleusercontent.com/-I...Large%2529.JPG
Before putting the tub back on, i decided to also put the stretch tank in just in case there are issues with clearance on the 14bolt. Even though it didn't call for it, i decided to notch the rear crossmember as the tank was hitting this part when i had it tightened up. The tank has different mounting and i had to sleeve a hole through the frame rail. Not a big deal however I hope the fakk it does not interfere with the rear shock towers....:
http://lh5.googleusercontent.com/-d...Large%2529.JPG
http://lh6.googleusercontent.com/-x...Large%2529.JPG
Then i dropped the tub onto the frame. With the cage/windshield off, it was much easier than the removal
http://lh5.googleusercontent.com/-9...Large%2529.JPG
Once on, i bolted up / clamped on the body armor:
http://lh4.googleusercontent.com/-H...4/s720/001.JPG
http://lh6.googleusercontent.com/-J...s/s720/004.JPG
http://lh4.googleusercontent.com/-9...o/s720/006.JPG
http://lh4.googleusercontent.com/-O...g/s720/013.JPG
Next steps are:
- Get the rear panels properly lined up and then trim the sheet metal!!
- Once that's done, i'll then setup the rear suspension.
- From what i can see, i will have to trim the front of the rear crossmember to clear the 14Bolt
- Hoping that within the next few weeks, i should have my ORI's and can then mock them up.
- Then drop the motor in and see what fits!!
From what i have read, one needs a 1" body lift to clear the ATLAS. Not a necessity but a suggestion. I really don't want to run a body lift, mainly because that very well will push me over my threshold on height to get in/out of the garage!!!
Current: Yello
Past: OD
Unread 01-19-2014, 03:23 PM   #13
jeepwrangler97
Wow, I didn't even read who was posting this until I clicked on the link to the old build...
I liked the last build, can't wait to see this one
Sent by a messenger bird
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2014, 08:23 PM   #14
Shobes
What did you use to strip the undercoating from the underside of the jeep? I had mine undercoated ten years ago and it's the bane of my existence!
My "hard way" build - [URL="http://www.jeepforum.com/forum/f22/tj-rubi-9s-learning-hard-way-1483373/"]http://www.jeepforum.com/forum/f22/tj-rubi-9s-learning-hard-way-1483373/[/URL]
Shobes is online now   Reply With Quote Quick reply to this message
Unread 01-29-2014, 10:30 AM   #15
Cuder
I looked through your other build. You do great work.
My Build Thread:
http://www.jeepforum.com/forum/f22/c...-lift-1268317/
Cuder is online now   Reply With Quote Quick reply to this message
