XJAbuzer's 2000 XJ - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > XJAbuzer's 2000 XJ
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit1999-2003 Jeep Grand Cherokee Timing Cover Gasket Set for
Unread 04-13-2010, 10:48 AM   #76
XJAbuzer
The ACOS are working great. The only problem I have with them is being able to get the front end high enough to take the weight off the springs so i can adjust them. An engine hoist works good for this.
Abuzed 2000 Cherokee...black -n- blue build
My Youtube Channel
1979 CJ-5 304 V-8, T-150 3 speed, Dana 20, Dana 30 front, AMC 20 rear, Sold
Anyways, I wanna go wheelin'!
XJAbuzer is offline   Reply With Quote Quick reply to this message
Unread 04-14-2010, 04:59 PM   #77
XJAbuzer
Slowly getting more images from the shakedown run...
My Youtube Channel
Unread 04-16-2010, 09:54 AM   #78
XJAbuzer
I just ordered the Novak NP231 shifter assembly to resolve my issue with the linkage hitting the body mount when I attempt to shift into 4WL. Picking up a transfer case seal kit tonight so I can tear down my case and my parts case to replace whatever is jacked up in my 231 (it sounds like a lunchbox locker in 2wd and it is very hard to shift....when you can actually get it to shift). All that work should be happening next weekend.
My Youtube Channel
Unread 04-27-2010, 08:17 PM   #79
shark02
Sweet lookin' xj! what kind of road manners does the aussie in the rear have? I've read all kinds of conflicting opinions about that.
also,where is that place you did the shake down run at? I am going to school at OU and I've been lookin for some place somewhat close to wheel!
shark02 is offline   Reply With Quote Quick reply to this message
Unread 04-27-2010, 09:11 PM   #80
XJAbuzer
Thanks.
I read around quite a bit about the Aussie and was conflicted at the time I bought it. I couldnt be happier. Most of the funny handling and odd "unloading" times I read about were exaggerated. It is noticeable, but as long as you dont drive like Paul Walker, it is fine. I would make the same choice if I had to make it again.
If you would like, PM me your info and we could meet up in a couple of weeks and I will show you around. I need to get my shifter in and tear down the transfer case to find out whats the cause. Once I have that resolved, it will be ready to hit the trails again.
Luckily I have a parts case from a 1988 that I can rob parts from for whatever is broke. Getting a seal kit but wont be getting any work on it this weekend.
My Youtube Channel
Unread 04-27-2010, 10:39 PM   #81
XJRod
1997 XJ Cherokee
just great, even tje engine color, CHARGERS baby blue
XJRod is offline   Reply With Quote Quick reply to this message
Unread 04-28-2010, 12:17 AM   #82
XJAbuzer
Lol....its actually AMC blue. I went with that color because I wanted something that was easy to see leaks.
Looks different in this light....cellphone pics, gotta love em....
I think I forgot to mention the Brown Dog motor mounts...
My Youtube Channel
Unread 04-28-2010, 07:51 PM   #83
austinaubinoe
damn that blue looks alot different in those three pictures! Awesome looking cherokee, is it your DD?
What exactly was the point of replacing your rear shock mounts? didn't really understand what you did there.
austinaubinoe is offline   Reply With Quote Quick reply to this message
Unread 04-28-2010, 08:42 PM   #84
portcityXJ
1995 XJ Cherokee
New lower shock mounts come with the TNT UBE kit. they are high clearance. and beefier. so why not!
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2010, 09:17 PM   #85
XJAbuzer
Thank you
Yes its my daily driver.
I replaced the shock mounts...
a. because the stock ones hang down really low and catch on everything
b. because they came with the u bolt eliminator kit
c. because I had already torn off the axle shock mount on the passenger side
d. because I could
My Youtube Channel
Unread 04-28-2010, 10:20 PM   #86
3vze28
great rig. i have the same front and rear bumpers, but i noticed a lot of internal rust with my rear bumper...have you had any similar issues?
3vze28 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2010, 10:22 PM   #87
XJAbuzer
Thanks.
No, I have not had that problem. We dont see nearly as much salt on our roads in the winter that you probably do in Jersey though.
My Youtube Channel
Unread 04-28-2010, 10:27 PM   #88
1990JEEPXJ
1990 XJ Cherokee
nice XJ man. like you, i am not pleased ONE BIT with my RE lift. the springs are horrible after about 18 months. how do you like the BDS leafs now that theyre broken in? do you wish you wouldve gone with 4.88's with the 35's?
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2010, 10:46 PM   #89
XJAbuzer
Thank you. The BDS leaves are great. I wouldn't hesitate to buy them again....not to mention they have "Made in the USA" on them, not "Made in India" like the RE leaves had.
35s and 4.56s are fine. I dont regret it. If it wasn't a daily driver that sees a lot of the highway, I would have gone with 4.88s. 4.56s seem perfect with 35s on a daily driver. I finally have my passing abilities back....lol.
My Youtube Channel
Unread 04-28-2010, 11:03 PM   #90
1990JEEPXJ
1990 XJ Cherokee
im gonna have to look into BDS leafs then when i can afford them. im not a fan of my RE 3.5" leafs, they dont have much arch left in them.
well im sure you will like the 4.56's more than others with the same tire/gear combo. you have a little more power than most.
My POS
