XJ Lift/Large Audio Build. - Page 2 - JeepForum.com
post #16 of 42 Old 05-04-2013, 07:26 PM Thread Starter
LyferXB9s
Well other than a new amp for mids and a new alternator in the next few months the jeep is finished. Might tweak the box a little bit but nothing serious.
My homeboy doing trim panels for me.
Metal Smith from Hell in the US Navy. AM3(AW) 2008-present
LyferXB9s is offline
post #17 of 42 Old 05-06-2013, 07:13 AM Thread Starter
LyferXB9s
Check out these videos from this weekends show. A few of my jeep, a bad *** Durango and a grand cherokee.
http://www.youtube.com/user/lyferxb9s
post #18 of 42 Old 05-11-2013, 07:48 PM Thread Starter
LyferXB9s
post #19 of 42 Old 05-12-2013, 07:31 PM Thread Starter
LyferXB9s
My 4yr old son using my impact driver to install 2x6s
post #20 of 42 Old 05-12-2013, 09:36 PM
jforse
Your audio setup needs help. Lots of time spent on sub-par design, product, and materials.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #21 of 42 Old 05-13-2013, 05:44 AM Thread Starter
LyferXB9s
How so?
post #22 of 42 Old 05-14-2013, 02:13 PM Thread Starter
LyferXB9s
I'm all for constructive criticism but at least leave something to go off of?
post #23 of 42 Old 05-14-2013, 05:51 PM Thread Starter
LyferXB9s
Well I will continue to update this build log. Back seat dual battery tray/ stripper pole mount.
post #24 of 42 Old 05-15-2013, 08:18 PM Thread Starter
LyferXB9s
Four crescendo 10''s and a ppi 900.4 added to the mix
post #25 of 42 Old 05-17-2013, 10:55 PM Thread Starter
LyferXB9s
post #26 of 42 Old 05-20-2013, 06:24 PM Thread Starter
LyferXB9s
Final cuts on the battery tray. Rounding the corners.
post #27 of 42 Old 05-20-2013, 07:30 PM
jforse
Originally Posted by LyferXB9s View Post
How so?
For a build this large that SPL is the goal you should be using 1"HDF throughout the encloser. The metal brackets are awesome. Good work on those. Get a really good silicone caulk for the joint inside the box. Coat the exterior with fiberglass epoxy.
Drivers that large and horns are a waste in the doors. You should have for example some JL Audio ZR 8 + 6.5 components in the doors. Run two 15" RE Audio xxx in a large ported box. No bandpass. You are choking those subs in the bandpass.
jforse is offline
post #28 of 42 Old 05-21-2013, 05:14 AM Thread Starter
LyferXB9s
Without being rude I will have to kindly disagree with 99% of what you said. HDF/ MDF is crap for enclosures. the only reason I even used a little of it was because it was already in the garage. Choking subs with a bandpass is possible, if not properly designed or tuned. However this is not the case. My front stage is full active with the 10'' crossed from 50-400hz ported, 8'' sealed playing from 400-4000k and the horns playing 4k+ with an 18dbslope. This is not an SPL build either. This is just my daily driver. And silicone for the joints is also terrible as it does not bond to MDF/HDF well if a all. And incriminator audio will walk all over an RE audio **** today. 9-10 years ago they were neck and neck when David was running RE, now theyre straight chinese garbage. The new XXX is alright but still nothing compared to the old.
post #29 of 42 Old 05-21-2013, 06:12 PM
joshua106
Hey Lyfer,
Ignore the haters. When I get my build log up, you'll laugh at my setup.
But, its very nice so far! Looking forward to some more posts and pictures. I know I haven't heard it, but unless my eyes are deceiving me, I think it wouldn't hurt to maybe have some tweeters or horns in the dash?
But, its nice seeing a audio build like this, you dont see them too often up here, at least the ones who lift them too.
joshua106 is offline
post #30 of 42 Old 05-21-2013, 06:42 PM Thread Starter
LyferXB9s
Thanks man. I plan on running some dayton 4'' neo full ranges in the pillars soon.
