XJ Cherokee half doors - JeepForum.com
post #1 of 10 Old 02-27-2010, 10:35 PM Thread Starter
tommy-xj
1990 XJ Cherokee
Ok, y'all, I've not come across much for write ups on Cherokee half doors so I'm diving into the project. I'll do my best too document it as I go. I've already got a lot of the work done so we'll start with that.
For starters I want to be able to have full doors in the winter time so I'm rigging the hinges to be quick release. I've taken pictures of that as well. I hope this helps anybody out there thinking of doing this. I have a parts jeep (listed in classifieds for parts if you're looking for anything) that I stole the doors off of that I cut up.
Here goes.
tommy-xj is offline
post #2 of 10 Old 02-27-2010, 10:54 PM Thread Starter
tommy-xj
1990 XJ Cherokee
When I started the hinges looked like this so I removed the doors from them.
tommy-xj is offline
post #3 of 10 Old 02-27-2010, 10:59 PM Thread Starter
tommy-xj
1990 XJ Cherokee
I tried to cut the doors with the hinges still bolted on but didn't have enough room for the Dremel cutter. After I got 'em off I was able to cut the hinges.
After the bottom arm of the hinges are cut the hinge pin needs to be cut as well. This'll take a bit and you'll go through a few blades for your Dremel.
tommy-xj is offline
post #4 of 10 Old 02-27-2010, 11:05 PM Thread Starter
tommy-xj
1990 XJ Cherokee
After I got that cut off the hinges pulled right out. A couple of them took a little sweet talkin' but they all came out.
The drivers side hing pins are stuck to the top arm of the hinge. Unfortunately the passenger side used the same hinges so the bottom arm has the pin stuck to it. On all the passenger side hinges, after I cut the bottom arm off, I had to weld the pin into the hinge so it wouldn't fall out with gravity and a few times opening and shutting the doors. The bottom picture shows half the hinges welded, it only took a little tack weld to the end of the pin.
tommy-xj is offline
post #5 of 10 Old 02-27-2010, 11:14 PM Thread Starter
tommy-xj
1990 XJ Cherokee
Now that I got the hinges rigged to work, I began cutting the doors. I started by gutting them of all the window mechanisms and door handles. All I left was the actual door latch.
I plotted the cuts with a yardstick and a sharpie.
I tried a few different cutters in this step. I used the Dremel cutter, a pneumatic rotary cutter, and a sabersaw. The sabersaw was the easiest and quickest but it tended to bend the door skin if it caught wrong. There were a few places I had to get out the Sawzall for it's longer blade. The red door I used the saber saw on and you can see how it's chewed up a bit.
That's where I'm at now. I need to borrow a welder to start putting them back together and get my Jeep back from the mechanic so I can cut it's hinges.
Stay tuned.
tommy-xj is offline
post #6 of 10 Old 03-13-2010, 06:19 PM Thread Starter
tommy-xj
1990 XJ Cherokee
After I got the doors cut out how I wanted them I welded in some 3/4" black iron pipe so it'd have rounded edges. I had to notch out the indentations in the interior door skin to get the pipe to lay flat. It turned out pretty good. I used .024 wire to help keep the body metal from warping. It still warped on me a bit. I got a little hasty.
Copy of IMG_3620.jpg   Copy of IMG_3622.jpg   Copy of IMG_3627.jpg   Copy of IMG_3628.jpg   Copy of IMG_3626.jpg
tommy-xj is offline
post #7 of 10 Old 03-13-2010, 06:25 PM Thread Starter
tommy-xj
1990 XJ Cherokee
After I got both pipes welded in place I cut some old diamond plate I had laying around to cap it off. To cap the open ends I cut the diapmond plate the correct width and height then traced out the curvature of the body. I cut the plate with a sabersaw. It was thin enough that it worked.
Copy of IMG_3629.jpg   Copy of IMG_3630.jpg   Copy of IMG_3631.jpg   Copy of IMG_3632.jpg
tommy-xj is offline
post #8 of 10 Old 03-13-2010, 06:31 PM Thread Starter
tommy-xj
1990 XJ Cherokee
I snagged a pair of inside door latchs out of a '98 Corolla to replace the bulky door handls/lock mechanism that came in the Jeep. I don't figure I'll need locks any more with these doors.
I traced out the footprint of the door latch and cut it into my diamondplate. I then took the rod from the old handle, cut it off and bent it to fit into the Corolla handle. It took me a couple times bending it to get it right but it works pretty slick.
I haven't got the door panels finished yet but I have them cut out. I plan to fold the vinyl around the cardboard and re-attach it to the door. It should look pretty good.
Stay tuned.
Copy of IMG_3634.jpg   Copy of IMG_3635.jpg   Copy of IMG_3636.jpg   Copy of IMG_3637.jpg   Copy of IMG_3638.jpg
tommy-xj is offline
post #9 of 10 Old 03-13-2010, 06:37 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Looks awesome. Reminds me that I have an extra set of doors in the garage.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #10 of 10 Old 03-13-2010, 08:38 PM
radar95zj
gives me bad ideas
radar95zj is offline
half doors with sliders or kahki jeeps with half doors JeepGirl411 Jeep Picture Requests 10 01-25-2011 07:19 PM
XJ half doors - cherokee son-of-england Jeep Picture Requests 8 02-28-2010 02:04 AM
YJ: pics of tan/spice hard top/half doors/and upper half window, please. myoung Jeep Picture Requests 1 02-20-2010 12:52 PM
Request: 08 4door JK in Steel Blue with "Spice" half-top+half-doors Brucifer Jeep Picture Requests 8 03-03-2009 12:13 PM
Mj/XJ with half doors/soft doors/ tube doors Comanche_ Jeep Picture Requests 2 02-27-2008 04:57 PM
