Woodsracer's Black TJ - Page 7 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Woodsracer's Black TJ
Regear now with Gear Packages from JeepHut.comSmittybilt M1 Fender Flares + FREE Machete$40 off over $400 + FREE SHIPPING!!!
Unread 04-07-2013, 11:00 AM   #91
woodsracer
Got to take the jeep out and play with it some yesterday. The quick disconnects are really nice.
image-3645853508.jpg   image-3944858570.jpg   image-1426943497.jpg   image-343410408.jpg
woodsracer is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 04:23 PM   #92
woodsracer
Here are some pics. Hopefully going to get it painted soon and get my flat fenders installed. I think it flexes pretty good for 2" of lift.
Unread 05-23-2013, 07:43 AM   #93
woodsracer
Flat fenders finally coated and ready to go on this afternoon.
Unread 05-24-2013, 09:31 AM   #94
woodsracer
Fenders installed last night. They came out great.
image-3222207997.jpg   image-3692009784.jpg   image-1963432739.jpg   image-280460553.jpg   image-1248471761.jpg
Unread 05-24-2013, 02:36 PM   #95
midnight_f150
Those new fenders look great.
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 10:09 PM   #96
woodsracer
Thanks they sat in the garage for about 8 months. Lol
Unread 07-29-2013, 03:31 PM   #97
woodsracer
Just ordered 4 Goodyear duratrac tires in 33x12.5x15! Ready to see how this thing is gonna look with the bigger meat in there. After the rebate is added in came in around $176 a tire.
Unread 07-29-2013, 11:48 PM   #98
midnight_f150
Nice deal!! My buddy has a set and he loves them.
Unread 08-02-2013, 04:17 PM   #99
woodsracer
Mounted and balanced my tires this morning. Then went and had it aligned.
Unread 08-18-2013, 03:32 PM   #100
woodsracer
Started working on a rear seat sub box. Doesn't look all that pretty but should get the job done. Specs will be listed when I'm done
The box is 29.75" wide, 14.5" long, and 4.25" deep. Resulting in 0.58 cubic feet of air space.
Obviously going to have to use a shallow mount sub. Debating between pioneer or a Rockford fosgate.
I cut roughly 4" of foam out of the seat cushion to fit over the enclosure. Then also cut the bulging piece of foam off the back support to gain some more up travel for the foam and sub enclosure below.
Unread 08-19-2013, 05:33 PM   #101
woodsracer
Decided on a Rockford fosgate r2sd4-10, 10" shallow mount sub. Not sure how well it's going to work with the air space I have. Going to have to poly fill the enclosure and go from there.
Then got some renegade rx62 6.5" full range speakers for the sound bar. Renegade is made by Rockford fosgate so I figured I'd try them out.
Also ordered a set of speaker adapters to fit 5.25" speakers for the dash. Haven't got speakers for it yet.
Unread 08-25-2013, 11:48 PM   #102
woodsracer
Got a chance to work on the jeep again and finally got everything all wired up and installed.
Unread 08-30-2013, 04:01 PM   #103
woodsracer
Alright here is the final product of my rear seat sub box install!
Everything test fitted and ready to be pulled back out and wired. Also since the enclosure was so small I poly filled it a little bit until most of it was loosely filled.
And here it is all in the back of the jeep!
The box was sprayed with plastidip to hopefully be water resistant at least, for those days caught in the rain with no top.
Unread 08-30-2013, 04:31 PM   #104
woodsracer
Alright here is a mock up for everything that I did. The measurements are a tad different than was I actually used on my box listed above. None the less this would still fit and accept the rockford sub I used as well. Rockford recommends .70 cubic of air space for this particular subwoofer. I had .58 cubic feet before installing the subwoofer in the box. Also on the 97 rear seat there are two supports in the center run from front to back of the seat that I cut out for the sub. The box rests on the rest of the frame of the seat that was there before, and is plenty sturdy. Had to remove four inches of foam out of the bottom of the seat and i removed around 2 to 3 inches of foam out of the back rest at the bottom of it.
This is all using 3/4mdf. measurements are from the outside of the box, taking into the account of the 3/4 of space taken up by the mdf sheets. The mounting depth at the listed specs would be 3.5"
The base cut here for the bottom of the enclosure would be 29.5 inches wide and 14.5 inches long
You will need to cut two of these. One for the top and the bottom.
The next pieces you will cut will be the front and the back of the box. They measure 29.5 inches wide by 2.75 inches tall. Two of these pieces are needed.
Next you will be making the side pieces. Which are 13 inches wide and 2.75 inches tall. Two of these pieces
Some general measurements again:
And the top piece that will be the same as bottom 29.5 inches wide by 14.5 inches tall.
The hole shown here is not centered. That is why there are no measurements. It also is a 10 inch round hole. The hole you will need to cut depends on the sub you are installing.
And as everyone is wondering on price!
4'x8' 3/4" mdf sheet: $17.28 (sheet was damaged on one end)
Liquid nail: $4.00
Rockford Fosgate R2SD4-10: $57.95
Terminal input for sub: $5.00
Amp wiring kit: $31.00
Amp: Used the amp of my truck for now. Older sony xplod 625watt
TOTAL: $115.23
Unread 09-08-2013, 11:10 PM   #105
woodsracer
Got to get out and do some wheeling for my birthday. Had a great time and the jeep really surprised me again. did a 4 star trail that I thought it would never make it up.
The rest of these pictures are from a trail called ultimate adventure at superlift.
arkansas
